Agm battery charging..
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mrf1987, Nov 2, 2021.
  1. Oct 9, 2022 at 6:28 PM
    #121
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    Just saw this and contacted SOB Fabrication. Looking forward to getting mine. For weeks I had driven by a Tacoma parked in my old neighborhood with this exact bumper design and have always meant to ask the owner where he got it. Now I know.
    Mrf1987[QUOTED][OP] likes this.
  2. Oct 17, 2022 at 6:19 PM
    #122
    AZTundra
    Paul
    Phoenix, AZ
    Just thought I'd post an update. So I drove to Batteries Plus last Saturday (10/8) and they checked the battery (9 months old). They stated the battery was too low and needed to be 12.5v for them to fully test it. I couldn't leave the battery with them to charge since I used it to drive there. I drove home and put my own charger on it overnight. Next day installed it and everything seemed fine so I left it at that. Fast forward to today and the truck wouldn't start again. I drove back to Batteries Plus and the lady just gave me a replacement without testing it. I hope this one lasts longer than 9 months. I did see that the X2 batteries no longer have a 5 year warranty, they are only 4 years now.
    RitcheyRch and 1lowlife[QUOTED] like this.
  3. Oct 17, 2022 at 6:21 PM
    #123
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    When I bought mine, 24 and 27s 4year, 31 5 year
    AZTundra[QUOTED] likes this.
  4. Oct 17, 2022 at 6:28 PM
    #124
    AZTundra
    Paul
    Phoenix, AZ
    Ok, not sure when they changed. My original was a 24F bought December 2021 and it was a 5 year. Now they are only 4 yr.
  5. Oct 17, 2022 at 10:32 PM
    #125
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Thanks for the update.
    I hope things work out in your favor..
    Mine had died twice within 5 months of purchase using an HKB boostrer.
    The second time Batteries Minus gave me a loaner, kept it for 3 days, and after testing they said it was fine.
    They also said if it died again, they would replace it, no questions, no more testing.
    A month later it dies again.
    They had no loaner and said they needed the battery for 3 days to test it.
    That was from the same manager that made the above promise to replace, no questions and no testing..
    I told him to go f*uck himself and traded that X2 Power AGM in on a $25 core charge for an Interstate MTP...:thumbsup:
    WILLINH and texasrho83 like this.
  6. Oct 25, 2022 at 8:09 AM
    #126
    MogwaiBoogie
    MogwaiBoogie New Member
    Justin
    TEXAS
    2020 Tundra Platinum
    In one of the many threads I have read about using an AGM, it was said that in 2018+ Tundra's the ECU controls the voltage output. Does this mean the Diode wont work in said model years? Seems some of you are running the diode in 18+ models and are not not having any issues.
  7. Oct 25, 2022 at 8:24 AM
    #127
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    From looking at one of the wiring diagrams, the ALT-S fuse is between the battery+ and the ECU. I believe this is the fuse that is replaced. So in this case it should work because the ECU is reading lower voltage due to the resistance and tells the alternator to step it up.
    Saltyhero13 likes this.
  8. Oct 25, 2022 at 8:26 AM
    #128
    MogwaiBoogie
    Justin
    TEXAS
    Yep, it the ALT-S fuse that is used for the diode. Thanks for the response. SemperFi
    Sonicbluerider likes this.
  9. Oct 30, 2022 at 11:43 AM
    #129
    DanTundra
    DanTundra Danny
    Wilmington, NC
    2015 Ribbon Blue Tundra SR5 4x4
    TRD sway bar, airbag kit, Diamondback HD, LED headlights, Pedal Commander, Bilsteins 6112's up front with shims (2.5 inch lift), 5160s in the rear with CB +2 shackles (1.5 inch lift), Falken Wildpeak AT3W 285/75/18, TRD Pro Grill insert, MattGecko under hood and bed light kit,
    I've had the HKB fuse in my truck for about 4 months now and its doing its job (14.7 volts then will adjust), but I'm thinking about switching back to a standard battery. The truck does turn over, but there was a little hesitation one morning when it got cold (38 degrees). I live in an apartment so throwing it on a trickle charger is tough, and the truck gets driven at least 5 days a week for about a 40 minute commute round trip.
    Any disadvantages of leaving the HKB fuse in with a standard non AGM battery? I'm still undecided about going to a standard battery, but I want to feel confident in the battery whether it is a standard battery or AGM battery.
  10. Oct 30, 2022 at 11:48 AM
    #130
    Yzed608
    Yzed608 New Member
    Wisconsin
    If you did go back to standard I would take it out.
  11. Oct 30, 2022 at 11:57 AM
    #131
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Nope take it out or you'll overcharge your non-AGM battery.
  12. Oct 30, 2022 at 2:20 PM
    #132
    daveeasa
    David
    This. Lead acid on stock voltage. AGM on boosted if possible but stock is still safe.
    DanTundra and NewImprovedRon like this.
  13. Nov 2, 2022 at 8:00 AM
    #133
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I had the HKB and there was just something off about it as it would never get high enough to charge an AGM. Ended up just buying the cheap GM diode on Amazon and it performs a lot better for a lot cheaper.
    With AGMs you can safely take the battery down to 50%. Anything more than that you’ll end up damaging the battery to the point where it doesn’t hold onto its charge. 12.05 volts is about the 50% mark. Make it a habit to check your battery level every once in a while before it’s first engine start of the day - would help a lot if you have a digital readout of your battery. This way you get a chance to save your battery if levels were trending downwards.
    Vr0ck and texasrho83 like this.
  14. Nov 2, 2022 at 9:06 AM
    #134
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    X2
  15. Nov 12, 2022 at 6:40 PM
    #135
    DanTundra
    DanTundra Danny
    Wilmington, NC
    I put my AGM battery on a trickle charger for 24 hours yesterday. The tickle charger (Noco Genius 10) on AGM setting said it was completely charged, and when I put a voltmeter on the battery it said 11.6 volts.
  16. Nov 12, 2022 at 6:57 PM
    #136
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Your battery may be kaput
    Wallygator and Saltyhero13 like this.
  17. Nov 16, 2022 at 3:07 PM
    #137
    DanTundra
    DanTundra Danny
    Wilmington, NC
    That is what I'm thinking and debating to try another AGM since I already have an HBK or go back to normal battery. First time trying an Advance Auto brand AGM battery...I've had good luck with Optimum batteries in the past.
  18. Nov 16, 2022 at 3:10 PM
    #138
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Do you think the HBK isn't working up to snuff?
  19. Nov 16, 2022 at 3:14 PM
    #139
    DanTundra
    DanTundra Danny
    Wilmington, NC
    I think I killed the battery as I had the AGM battery in the truck for well over 1 year without any issues and knowing what I know now about the Tundras and AGM batteries.
  20. Jan 15, 2023 at 8:28 AM
    #140
    Dawoofles
    Dawoofles New Member
    Cheyenne, WY
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    When using the rago group 31 battery tray, did the stock J hooks still fit? Or did you need longer ones?
  21. Jan 15, 2023 at 8:46 AM
    #141
    IowaGuy
    IowaGuy New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    Any truth that the AGM + the diode fuse will not work on 18+ tundras? I thought I read somewhere that the trucks charging system will not work on this setup with newer trucks?
  22. Jan 15, 2023 at 8:51 AM
    #142
    Saltyhero13
    Saltyhero13 Throbbing Member
    I have a 2020 and the HBK product works fine.
    WillTunBlack20 likes this.
  23. Jan 15, 2023 at 9:10 AM
    #143
    dkrou
    dkrou New Member
    dan
    2019 tundra
    I have a 19 and mine has worked fine for a few years...I do hook it up to a charger from time to time.
    Saltyhero13 and texasrho83 like this.
  24. Jan 15, 2023 at 11:23 AM
    #144
    Saltyhero13
    Same. I throw my battery on a tender just for precaution as well.
  25. Jan 15, 2023 at 3:32 PM
    #145
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
  26. Jan 21, 2023 at 8:26 AM
    #146
    dkrou
    dkrou New Member
    dan
    2019 tundra
    If you have an AGM battery highly suggest you hook up a battery monitor with bluetooth app on your phone...that way if you ever do need to hook your battery up to your charger(even with an HKB I occasionally do and I use a CTEK) this will be a great way to know when...like 50% before you kill an expensive battery. If my truck is going to sit for long periods I leave my charger on....https://www.amazon.com/dp/B07GP1RXYZ
    Saltyhero13 and Wallygator like this.
  27. Feb 10, 2023 at 4:23 AM
    #147
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Leo's first likes this.
  28. Feb 10, 2023 at 4:37 AM
    #148
    Dawoofles
    Cheyenne, WY
  29. Feb 10, 2023 at 1:46 PM
    #149
    raketemensch
    raketemensch New Member
    NEVADA
    HulkSmurf14 likes this.
  30. Feb 10, 2023 at 2:45 PM
    #150
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
