Agm battery charging..
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mrf1987, Nov 2, 2021.
  1. Nov 6, 2021 at 12:26 PM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    I ended up picking up a littelfuse 1amp from o'reilly auto for $4 and change to use with a diehard agm 24F.
  2. Nov 10, 2021 at 8:18 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    my UltraGauge shows 14.3V typically, never seen it over 14.7V.
  3. Nov 10, 2021 at 8:24 AM
    Mrf1987
    Mrf1987 [OP] New Member
    2020 Trd sport tundra
    finished up the install
    I installed the fuse you provided a link for off of ebay and everything is working appropriately. I am seeing about 14.6/14.7 at startup and it levels off around 14.2-14.4 until the battery demands more than it goes back up.
    PWMDMD likes this.
  4. Nov 10, 2021 at 8:44 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Wait...
    Are you saying the charge voltage never goes below 14.2?
  5. Nov 10, 2021 at 9:20 AM
    Mrf1987
    Correct, the agm batteries need a higher voltage to recieve a full charge. It says right atop of the x2 battery i have. This is a known modification to perform to get the most out of your agm battery without having to use a plug in charger every now and then.
    Vr0ck likes this.
  6. Nov 10, 2021 at 11:00 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    If the battery never reaches saturation then I suppose its OK.
  7. Nov 30, 2021 at 10:23 AM
    F0X672
    F0X672 Durability Tester
    NEPA
    2016 Tundra TRD Pro
    Needing some clarity here, doing the GM diode/fuse swap with the ALT-S fuse, is the GM diode also fused or is it strictly a diode? Looking at the wiring diagram for my 2016 and knowing where the fuse is and how the sense wire is run down to the regulator on the alternator, I'm sure as soon as I pop in that diode is the day that wire chaff's, grounds out, catches fire and burns my truck down lol. This concern is also aside from forcing the charging system to work a little "harder" chancing an earlier failure. Ultimately, anyone have insight if the GM diode 12135037 is also fused?
  8. Nov 30, 2021 at 12:15 PM
    Mrf1987
    From what i have gathered the gm diode is not fused it is just A diode. I purchased this fused diode off ebay and it is working just fine.
    https://www.ebay.com/itm/164706700869
  9. Nov 30, 2021 at 4:33 PM
    F0X672
    NEPA
    2016 Tundra TRD Pro
    Looks like someone just cut the pigtail off an add a circuit and added a diode, making a series circuit with the fuse and diode.
    I had my doubts on the GM and one but everywhere you look up it's part number, it's listed as multifunction. At first I was wondering whats multifunctional about it but I'm thinking it's multi application, usable for other various circuits and electrical components.
  10. Dec 8, 2021 at 9:57 PM
    daveeasa
    David
    What a great grinchy trick!
  11. Dec 8, 2021 at 10:11 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    daveeasa likes this.
  12. Dec 9, 2021 at 1:08 AM
    F0X672
    NEPA
    2016 Tundra TRD Pro
    I got a little creative, soldered 2 ATM fuse holders lying around, soldered in a low pro fuse tap, and bought the GM diode. Gave myself extra length on the wire so I can tuck it in the open pocket of the fuse box. I'll give this a try in the morning.
    Yzed608, Rodbolt and Gunship Guy like this.
  13. Dec 9, 2021 at 6:48 AM
    Ericsopa
    Ericsopa Old man and the sea
    HulkSmurf14 and Vr0ck[QUOTED] like this.
  14. Dec 9, 2021 at 7:32 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
  15. Dec 9, 2021 at 8:18 AM
    Paulismydog
    Paulismydog New Member
    2020 Black Limited Double Cab
    My 2020 limited has the 5 amp alt s fuse. I assume I can use a hkb diode. I see two options. The micro blade and the mini blade. Any suggestions as to which of the two I should get. Thanks. Bob
  16. Dec 10, 2021 at 11:32 AM
    F0X672
    NEPA
    2016 Tundra TRD Pro
    So far so good. I probably have about $25 total invested into this little upgrade including the diode. Didn't grab a picture but the alternator is originally charging at 13.87v. A .55 volt gain, good enough for me. Going to keep an eye on it, just mildly concerned about the longevity of the alternator in the end.
    NewImprovedRon and Vr0ck like this.
  17. Jan 14, 2022 at 11:42 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Does anyone have a rule of thumb as to when you know you need an agm? I'll be running a winch, lightbar, couple light pods and a few low power goodies, I'm pretty sure nobody would argue the additional load on the truck but is frequency of usage the main factor?
  18. Jan 15, 2022 at 1:31 AM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    I ran a load similar to that on my old 91 suburban with an Interstate battery and an anemic 105 amp alternator. I had a couple of long winch pulls with it too.
  19. Jan 19, 2022 at 5:30 PM
    #49
    DanTundra
    DanTundra Danny
    Wilmington, NC
    2015 Ribbon Blue Tundra SR5 4x4
    TRD sway bar, airbag kit, Diamondback HD, LED headlights, Pedal Commander, Bilsteins 6112's up front with shims (2.5 inch lift), 5160s in the rear with CB +2 shackles (1.5 inch lift), Falken Wildpeak AT3W 285/75/18, TRD Pro Grill insert, MattGecko under hood and bed light kit,
    Any issues with your set up @F0X672 ? Thinking about creating this instead of purchasing the HKB one.
    HulkSmurf14 likes this.
  20. Jan 21, 2022 at 9:04 AM
    #50
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    @F0X672 where did you find that low pro fuse tap with two wires. All the ones I’m finding locally only have one wire? Thanks in advance.
    F0X672 likes this.
  21. Jan 21, 2022 at 10:10 AM
    #51
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Maintenance and depth of discharge are my primary factors.
    AGM doesnt require water additions and generally tolerate deeper discharge cycles without permanent damage. Some AGMs feature higher capacity (fatter, more buxom amperes) than a flooded battery of the same group size.
    For me, I like AGM because they dont leak gasses that corrode your terminal clamps. And they're spill proof. And the ones I buy have moar capacity.
  22. Jan 21, 2022 at 10:18 AM
    #52
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
  23. Jan 22, 2022 at 2:38 PM
    #53
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Tough to get my phone to capture the LCD screen in this light, but I’m up to 14.4 in this photo, from typical 13.7. At start, it hits as high as 14.8 now.
    Did the GM diode trick this morning in about 3 minutes. Sand it down with a Dremel and slip it in. Easy. Arrow faces the front of the truck.
  24. Jan 22, 2022 at 2:40 PM
    #54
    Chad D.
    Chad D. New Member
    Western Oregon
    More importantly, why didn’t Toyota ever give us outlets in the bed? I added a dual USB, 12V socket, and a dual Anderson plug outlet for the beer fridge.
  25. Jan 22, 2022 at 4:04 PM
    #55
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Is your bed-setup weatherproof when canopy isn't on?
  26. Jan 22, 2022 at 4:24 PM
    #56
    Chad D.
    Chad D. New Member
    Western Oregon
    dunno. My canopy is never off. I don’t think I’d be concerned about a little rain, but probably would t submerse it. If it were an open bed, I’d maybe skip the volt meter and switch. Just do the outlets with covers. FYI, the outlet is the same as my boat dash. Water wasn’t an issue for it.
    HulkSmurf14[QUOTED] likes this.
  27. Feb 3, 2022 at 4:43 PM
    #57
    F0X672
    NEPA
    2016 Tundra TRD Pro
    Sorry for the long wait. Found the low pro tap off scamazon.
    Specialized ECU Repair Car Fuse... https://www.amazon.com/dp/B09G7C37JL?ref=ppx_pop_mob_ap_share
    I just chopped the tap end off and soldered in 2 weather proof fuse taps (weather proof is unnecessary but it's what I keep in stock in my shop).
    W3agle, AGSport and bfunke[QUOTED] like this.
  28. Feb 4, 2022 at 1:40 PM
    #58
    BCTRD
    BCTRD New Member
    B.C.
    2021 MGM Tundra TRD Sport
    18"BBS Forged wheels, factory running boards, VLED's, Rigid Pro Led mod (D2 SAE), diff breather mod, Husky mats, DIY Cquartz UK 3.0, Husky liners, OCD organizers,
    Could you supply the P/N and source? Thanks
  29. Feb 4, 2022 at 2:14 PM
    #59
    timsp8
    NY
    BCTRD[QUOTED] and HulkSmurf14 like this.
  30. Feb 9, 2022 at 7:14 PM
    #60
    BCTRD
    BCTRD New Member
    B.C.
    Great, thanks.
