AGM Batteries in ur Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by wandering_boy, Apr 20, 2021.
  1. Apr 21, 2021 at 10:45 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I wouldn't spend money on an AGM until you investigate post #11 above.
  2. Apr 21, 2021 at 12:02 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    Odyssey Batteries are about the best you can buy and should last 10 years no problem. LA batteries have jumped in price and make the AGM batteries an easier choice.
    My Odyssey died in my Rock Buggy after one of the nephews pulled the headlight switch and left the lights on for about 2 weeks. It charged up but didn’t last much longer. Battery was 6 years old and would sit without a tender for months and months and would always fire right up with no issues.
    I’m planning to run a group 31 odyssey in the Tundra sometime in the future.
    I’ve heard of 2nd and 3rd gen Tundras having issues with not charging the AGM’s but not the 1st gens, may have to look into that.
  3. Apr 21, 2021 at 1:38 PM
    wandering_boy
    wandering_boy [OP] Junior Tech Wizard
    California
    2005 AC SR5 TRD
    Don't let a kid out smart you.
    @onesojourner I will try to find that guy who used the voltage mod. @FirstGenVol In the meantime I kinda already have an Optima red top on order so when that comes in tomorrow I will go pick up a battery charger along with it, and I will wire up 2 digital voltmeters so I can keep an eye on all the volts for the alternator and the battery. Just need to know if I need a special charger for it the AGM. As for the battery weirdness some of the water probably came out during some wheeling so it may not have boiled but my alternator is only 3 years old. I knew the old owner so i got the full service record on the ol tundy.
  4. Apr 21, 2021 at 1:46 PM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    Northstar (and the batteries plus brand x2power) are both on par. Northstar was recently purchased by odyssey. I expect there to be some more rebrands coming soon with that arrangement. The only modification I had to do for the group 31 was to ditch the battery tray.
    Diablo169[QUOTED] likes this.
  5. Apr 22, 2021 at 7:30 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    @Coupe's battery tie-downs work great for offroad use but won't solve leaking. :thumbsup:
    I'm probably one of the people others are mentioning. I have been running a NorthStar 27F for over two years now no problem. I did drain it very low once but got it surge charged/ load tested afterwards.
    I recently put in an HKB voltage booster and a voltage meter to easily check. With the engine running, battery is getting anywhere between 14.1v-14.5v. I never measured voltage with the engine running prior to this mod so I can't speak to the numbers beforehand, but if I had to guess they weren't in the optimal range.
    I can say however that the battery voltage after the engine is shut off is higher now after adding the HKB booster. I do think there is something to be said about using the boosters if you're running an AGM.
    Additionally, I started putting the truck on a trickle charger whenever I'm not using it which can be weeks at a time.
  6. Apr 22, 2021 at 8:32 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I have run AGM batteries since 2009 in my truck. The first one (diehard platinum agm) lasted around 8 years and may have only died because I let my truck sit for several months. I replaced it with a diehard gold agm and haven't had a problem yet.
    The main reasons I went agm is no maintenance and no spillage. Plus I used to enjoy the drive in movies and after 4 hours of a stereo and subwoofer playing it was pretty common for vehicles to not start. I never had that trouble with the agm, in fact I found myself jump starting people at the drive in practically every weekend.
    I have an agm from vatozone in my wifes car. They're not all created equal, if I let her car sit for 2 months its a coin toss on if it starts or not. My truck can sit that long and fire up immediately.
  7. Apr 22, 2021 at 9:25 AM
    wandering_boy
    California
    2005 AC SR5 TRD
    I found the one that doesn't have the dip witches and it was $390. Is that what you paid for yours. because for something that looks like a fuse 400 buck a roos is a lot
  8. Apr 22, 2021 at 9:35 AM
    des2mtn
    SW
    Tonto cover
    Not really sure what you mean. My battery was in the mid $200's from a battery store I've gone to for years that also warranties, load tests etc.
    This is in AUD. I bought from here after reading their posts on T4R. It came with literature which is something I like to have... I also don't expect to replace this. https://www.hkbelect.com/product/434-mk3-mini-blade-75a-electronic-fuse-version-2006/
    I would have tried this but it was out of stock. https://www.hkbelect.com/product/439-mk4-adjustable-alternator-voltage-booster-2006/
    The simple GM Diode fuse is cheaper but electrical wizardry is beyond my knowledge.
    619Tundra likes this.
  9. Apr 22, 2021 at 9:42 AM
    des2mtn
    SW
    Tonto cover
    Like I said, I also ran the AGM two years without modifications and no problems. Experience similar to @Darkness. These mods were done mainly for piece of mind, whatever that may be.
    I also vote to investigate post #11 first.
  10. Apr 22, 2021 at 9:47 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Ouchole! Thats too high. The one in my truck was $260 and I got a slight discount that brought it to $240. The one in my wifes car was $190 (different size so price doesn't apply here).
    des2mtn likes this.
  11. Apr 22, 2021 at 9:52 AM
    wandering_boy
    California
    2005 AC SR5 TRD
    The one on the actual website is 60 for just the fuse style. the $400 one was from a taco world link. last time I trust those dudes
  12. Apr 22, 2021 at 9:54 AM
    des2mtn
    SW
    Tonto cover
  13. Apr 22, 2021 at 9:55 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I think he was worried he would need to adjust things for the correct voltage. It turned out that the fuse would have been spot on. I intend to explore the GM diode. I have it in the glove box. I wont do it until I have monitored where the voltage is at before and after.
  14. Apr 22, 2021 at 10:05 AM
    wandering_boy
    California
    2005 AC SR5 TRD
    Those little down syndrome truck mfs sent me to some scam. so happy to know its actually 60. as for #11 if figured out that I'm dumb and dumber. I'm dumb because when I put the water in the first time I over filled it so thats why it sloshes out. and I'm dumber because I realized that some of the shit that also got spilled was coolant. Us kids have to be dumb sometimes.
    des2mtn, bmf4069 and Darkness like this.
  15. Apr 22, 2021 at 10:24 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Well that's kinda making me question thinking about the possibility of buying one. My truck tends to sit around quite a bit and after 3 weeks it's a guaranteed jump.
  16. Apr 22, 2021 at 10:40 AM
    wandering_boy
    California
    2005 AC SR5 TRD
    Let me know what kind of results you get
    onesojourner[QUOTED] likes this.
  17. Apr 22, 2021 at 11:08 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    onesojourner and bmf4069 like this.
  18. Apr 22, 2021 at 11:15 AM
    Wallygator
    The X2 power battery from batteries plus in the link I posted is made by Northstar. It's the same battery
    onesojourner likes this.
  19. Apr 22, 2021 at 12:27 PM
    #49
    duerrs
    duerrs Semper Fi!
    2008 Tundra TRD Off Road & 2020 Tundra TRD Pro
    General rule of thumb when buying AGM over lead acid flooded...twice the cost, half the life. BTW, "Absorbed Glass Mat" (AGM) is also lead acid. Difference is that the electrolyte is absorbed in the mat making it "maintenance free" or non-spillable.
    CodyP and Barrett50 like this.
  20. Apr 22, 2021 at 12:29 PM
    #50
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    My nova has an optima. The smallest/lightest i could get to turn over at 11:1. Never had any problems, but the nova had a toggle switch electrical system, and a battery tender.
    Wallygator likes this.
  21. Apr 22, 2021 at 1:40 PM
    #51
    Professional Hand Model
    Hand Protectors
  22. Apr 22, 2021 at 2:55 PM
    #52
    Wallygator
    Simply not a true statement.
  23. Apr 22, 2021 at 3:06 PM
    #53
    Hand Protectors
    Provide an in depth analysis supporting your Thesis.
    Black Wolf, 1lowlife, bmf4069 and 2 others like this.
  24. Apr 22, 2021 at 3:22 PM
    #54
    wandering_boy
    California
    2005 AC SR5 TRD
    To register a complaint please do so in a 5 paragraph essay with a clear thesis statement and cited sources. :rofl:
  25. Apr 22, 2021 at 3:23 PM
    #55
    Hand Protectors
    Yeah! You’ll never hear back when you ask it that way. :thumbsup:
  26. Apr 22, 2021 at 3:26 PM
    #56
    wandering_boy
    California
    2005 AC SR5 TRD
    Thats the point. I don't want to hear that shit. AGM positivity only *insert snowflake*
  27. Apr 22, 2021 at 3:40 PM
    #57
    Wallygator
    Hilarious....you can simply look at the warranty of a regular battery (usually 2 years) and the warranty for an X2 power AGM (5 years). More than double the warranty of the cheaper battery, more than double the life of the cheaper battery, and double the price. ;).
  28. Apr 22, 2021 at 3:44 PM
    #58
    Wallygator
    It seems only one *insert snowflake* present here, but I digress, the AGM is not for everyone and completely stupid to buy if you are not going to use it for what it's meant to be used for. Again, YMMV *insert snowflake*
  29. Apr 22, 2021 at 5:05 PM
    #59
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I did a deep dive over the span of three weeks absorbing the info found here:
    https://batteryuniversity.com/learn/article/lead_based_batteries
    It cleared up some of the misconceptions I had developed concerning lead acid battery failure.
    "Charging a lead acid battery is simple, but the correct voltage limits must be observed. Choosing a low voltage limit shelters the battery, but this produces poor performance and causes a buildup of sulfation on the negative plate. A high voltage limit improves performance but forms grid corrosion on the positive plate. While sulfation can be reversed if serviced in time, corrosion is permanent. (See BU-403: Charging Lead Acid.)"
    Saltyhero13 and bmf4069 like this.
  30. Apr 22, 2021 at 7:19 PM
    #60
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    The line "Your mileage may vary" comes to mind. Mine certainly did. I replaced two X2 Power AGM batteries that were well within warranty (Batteries Plus weaseled out of honoring the warranty) in order to make sure the vehicles started. I paid a premium price for a product that was allegedly correct for the vehicles, but it turns out that additional maintenance and special charging is required. If regular lead acid batteries required this, people would be hounding the battery companies to improve their product or the car manufacturers to correct the charging system. If I buy a product, I expect it to perform as advertised. If I park a vehicle for an extended time, I expect the battery to need an occasional top up. The battery on a daily driver shouldn't run down unless it's defective. I'll never buy another AGM battery. They're a waste of money.
