AGM Batteries in ur Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by wandering_boy, Apr 20, 2021.
  1. Apr 20, 2021 at 9:12 PM
    wandering_boy
    wandering_boy [OP] Junior Tech Wizard
    California
    2005 AC SR5 TRD
    Don't let a kid out smart you.
    Recently had my battery take a shit on me and before I go buy a new one I wanted to know/ see if anyone runs an optima or other AGM battery. I hear that there could be problems with just dropping it just in and I've heard it works fine. I was looking at the Optima red top group 35. Any recommendations or what I need to run an AGM would be super helpful. I really don't want to go back to lead acid since my old one leaked a bunch of nasty water out during a long road trip. Had to do some painting and buy a lot of new hose and shrink wrap, such a PITA.
  2. Apr 20, 2021 at 9:20 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    AGM batteries cost a heck of a lot more and you really don't gain anything with them. Warranties are typically the same. Unless you run a lot of accessories I would just save your green and buy another lead acid battery.
    I've never had a battery leak on my though so I'm not sure what happened to you there. I have heard that you need to do a small mod to get the truck to charge the AGM batteries or something....I really don't remember.
  3. Apr 20, 2021 at 9:26 PM
    wandering_boy
    California
    2005 AC SR5 TRD
    I think the water inside started boiling or something. I topped it up before and I had to put "a lot" more in when I got there. It was super weird. My two reasons behind going for an AGM is for that extra capacity because I plan to do a bunch of camping out of it this summer and I go off to college in the fall in AZ and wont be able to bring it with me (I'm heart broken) so it's going to sit for a while and Iv'e heard the AGM's hold a charge a bit better. and then it going to live in AZ with me so I won't have the same time to check the battery water level all the time. And $275 (after fees and core charge) isn't bad for a battery that could last me 7-10 years. Plus if I ever decide to go for a dual battery setup I can stuff it sideways somewhere or even upside down and backwards :)
    Wallygator likes this.
  4. Apr 20, 2021 at 9:32 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    My truck came with an AGM and it lasted 5 years. Most lead acid battery warranties are 3 or 4 years so you would have to get 10-12 years out of an AGM to break even according to costs. Also, not sure if you would have access to an outlet but a battery tender while not being driven would do wonders. An AGM won't give you more capacity unless you get a bigger battery, but you can do the same with the lead acid too...
    RitcheyRch and KNABORES like this.
  5. Apr 20, 2021 at 9:59 PM
    wandering_boy
    California
    2005 AC SR5 TRD
    It's all so complicated. and I wont have access to a trickle charger since it going to be left out on a street. And it only $100 more after fees and taxes compared to a LA battery before fees and taxes. So besides the potential compatibility issues it just seems like so much less of a PITA.
  6. Apr 20, 2021 at 10:00 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Up to you. I would still take either battery out of the truck and put it in the garage/house on a battery tender.
    FrenchToasty likes this.
  7. Apr 20, 2021 at 10:01 PM
    wandering_boy
    California
    2005 AC SR5 TRD
    I'll probably end up doing that.
  8. Apr 20, 2021 at 10:02 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    If you have access to Costco, they sell the interstate AGM batteries for a lot cheaper than Optimas
  9. Apr 21, 2021 at 3:15 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Solar charger an option?
    DSLKSL and wandering_boy[OP] like this.
  10. Apr 21, 2021 at 3:49 AM
    Wallygator
    I have this one in my Tundra now. Brought it over from my 4Runner when that vehicle was traded for the Tundra. Used the 10% off code by ordering online and it was also on sale at the time I purchased it. Battery has been great but it's only around 3 years old now, so hopefully a lot of life left.
    I do put it on a battery tender around once a month but I also do that with just about every vehicle battery I own. This practice seems to help with the longevity. If you are thinking about AGM, check this one out.
    https://www.batteriesplus.com/produ...ndra/2019/v8-5.7l-710cca-optional/sli27fagmdp
    EDDO likes this.
  11. Apr 21, 2021 at 3:57 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    These two statements are telling you your battery is being overcharged. A properly filled battery (with care taken not to overfill) should never leak electrolyte if the charging system is functioning properly. It sounds like your regulator is not sufficiently tapering off the charge current as the battery gets full. As a result, it's boiling the electrolyte which will cause the water to evaporate at an accelerated rate.
    If this is indeed the problem, it'll ruin your new battery too.
  12. Apr 21, 2021 at 4:58 AM
    KarmaKannon
    Utah
    Some junk
    I'll check, but I think the standard wet battery in my tundra had a 14 date on it. Still going strong. I thought I'd replace it after the winter of 2019 and I didn't and then I thought I'd replace it after this year and we'll see. It all depends on if the battery fits in one of my other vehicles that I don't drive often. I'd like to do a bigger battery though. Seems like an easy upgrade considering batteries don't seem to vary all that much on price within a certain range of sizes.
    wandering_boy[OP] likes this.
  13. Apr 21, 2021 at 5:01 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    If that's the case, it may not hurt to put a voltmeter on it while it's running.
  14. Apr 21, 2021 at 5:41 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    speedtre likes this.
  15. Apr 21, 2021 at 5:57 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The only other benefit I've heard is that if you offroad a lot, the AGM battery won't leak. Apparently if it gets rough enough a normal battery can leak. I still don't know that the AGM battery is worth the price tag though.
    Darkness and des2mtn like this.
  16. Apr 21, 2021 at 8:24 AM
    wandering_boy
    California
    2005 AC SR5 TRD
    thanks for the link! I was already looking for an external regulator but the s terminal trick seems interesting. need to figure out if it will work on the first gen tho.
    It's probably a bit of both. My battery is from 2012 which doesn't help but I've never seen my stock volt meter spike or sit any higher than normal. But I will run an electronic voltmeter which every way I decide to go.
  17. Apr 21, 2021 at 8:27 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I have not done the voltage booster, but it will work and it has been done on the first gen. I have the GM booster ready to go in I just want to test everything first. I just stick an agm charger on once a month.
  18. Apr 21, 2021 at 9:10 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    :eek:
    Darkness and CodyP like this.
  19. Apr 21, 2021 at 9:17 AM
    wandering_boy
    California
    2005 AC SR5 TRD
    So are you running an AGM with modifications to the truck at all or did you HAVE to do some stuff?
  20. Apr 21, 2021 at 9:24 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    I've been using a Deka Intimidator AGM in the Tundra and Jeep, no modifications... excellent battery. Gives me many hours of blasting redneck music when the truck is parked and I'm dewing stuff.
  21. Apr 21, 2021 at 9:25 AM
    wandering_boy
    California
    2005 AC SR5 TRD
    *2014
    Darkness likes this.
  22. Apr 21, 2021 at 9:31 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    :eek:
  23. Apr 21, 2021 at 9:38 AM
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    So no voltage mod or even top off once and a while? Was thinking about that Deka
  24. Apr 21, 2021 at 9:38 AM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    I switched out a failing flooded cell battery for a Group 94R AGM by ACDelco almost 3 years ago and no problems. I didn't bother to "mod" anything in the process. I've had interior halogen lights left on for 24 hours and it doesn't phase this battery either. It's more accommodating to these types of mishaps than flooded cell batteries. I do put a harbor freight battery charger/conditioner on it every 6 months or so for added peace of mind. I probably would not have made the switch to AGM for $275 but this one only cost me $175 which seemed worthwhile.
  25. Apr 21, 2021 at 9:46 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    No need to do anything. I use AGM for marine stuff too, it rules. Requires AGM-friendly charger for marine or powersport use if slow discharge is desired. Good technology.
  26. Apr 21, 2021 at 10:03 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
  27. Apr 21, 2021 at 10:16 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    There is plenty of people complaining about early failures on tacoma world. The common denominator is none of them topped them off or did the voltage mod. To get the best lifespan you have to boost the charging voltage at least every once in a while.
  28. Apr 21, 2021 at 10:23 AM
    wandering_boy
    California
    2005 AC SR5 TRD
    Alright lets make sure I got everything figured out-
    I should be able to just drop an agm battery in with no problems but it could last not quite as long if I don't fuck with it. But if I either top the charge off with a trickle charger or run a battery booster/ external voltage regulator I should enjoy long battery life.
    Right?
    Also does anybody on this forum run a booster or external voltage regulator or does it seem like everyone just drops it in?
  29. Apr 21, 2021 at 10:29 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I have seen lifespans under 2 years. I would not do this without a plan to top off.
    The voltage mod has been done by a first gen guy in the last 3 months I think. Who was that?
  30. Apr 21, 2021 at 10:32 AM
    Never used an add on voltage regulator on any of my Optima's. Driven daily. No issues. FYI....you can't deep cycle lead acid batteries like you can with AGMs.
