AgentCox000's White Tank Build
Discussion in '2.5 Gen Builds (2014-2021)' started by agentcox000, Jan 23, 2018.
  1. Dec 29, 2018 at 5:57 PM
    #91
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    Thanks for the referral @agentcox000 :fistbump:
    The BD discount is 5% now? Dang, used to be 10%. Their lights are amazing though! I have a squadron sport for the headlight on my DRZ and it’s incredible how bright it is!
    That switchpro will be so nice. I’m envious, I want one haha.
    @WildBean :wave:
    I see your PM, I’ll get to it on Monday when I’m back at work. Until then :cheers::drunk:
  2. Dec 29, 2018 at 6:01 PM
    #92
    agentcox000
    agentcox000 [OP] "Skin that smoke wagon and see what happens"
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    I am mistaken and you are correct, @Baja Designs discount is 10% with $5 shipping!!!! @WildBean
  3. Jan 9, 2019 at 9:22 PM
    #93
    TheBeast The Beach
    @agentcox000 easy to install ?
    Rica25 likes this.
  4. Jan 10, 2019 at 5:21 AM
    #94
    agentcox000
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    Definitely. To get enough slack in the lines you do have to flip the hard brake line’s mounts upside down. It will make sense once you start. Probably 20 minute install.
    TheBeast[QUOTED] likes this.
  5. Jan 14, 2019 at 5:30 PM
    #95
    TheBeast The Beach
    just installed mine. I only flipped the 2 mounts closer to the pumpkin. no need to touch the 2 below the leaf pack right ? seems ok this way.
    @agentcox000
  6. Jan 14, 2019 at 5:40 PM
    #96
    agentcox000
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    Yup I should’ve been more specific, I only flipped the inner two as well
    Rica25 and TheBeast[QUOTED] like this.
  7. Jan 15, 2019 at 7:06 PM
    #97
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    How ya liking the k37's with those triples?
    Rica25 likes this.
  8. Jan 16, 2019 at 6:03 AM
    #98
    agentcox000
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    Absolutely love the ADS trips! The whole truck feels more solid. As for the K37s I’m not a fan, they’re just too soft and yielded little to no lift, shackles are doing the only lifting as the K37s are flat. I have more Tundra lean than I did stock, and any weight in the bed gives me California “bro” rake.
    As soon as I get thru this busy month at work I’ll be taking it Valley Spring Service for a custom leaf pack that works with my other suspension components, not against them.
    Erichudgins and PLC721[QUOTED] like this.
  9. Jan 16, 2019 at 6:04 AM
    #99
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    IG: PLC721
    Hell yeah Valley Spring does awesome work!
    Rica25 likes this.
  10. Jan 16, 2019 at 7:31 AM
    #100
    Stormtrooper81
    Stormtrooper81 Slow and steady
    Lost coast
    2011 DC
    Great build thread:cheers:
    agentcox000[OP] likes this.
  11. Jan 16, 2019 at 8:11 AM
    #101
    agentcox000
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    Thanks for all the love :thumbsup:
    TheBeast likes this.
  12. Jan 16, 2019 at 12:06 PM
    #102
    agentcox000
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    Testing the ADS Triples the other day. So smooth!
    Krezz and Juddrussell like this.
  13. Jan 16, 2019 at 12:12 PM
    #103
    TheBeast The Beach
    smooottth ! :) what settings do you have them on ? i.e. how many threads you got showing on the rebound and compression settings ? still playing with mine.
  14. Jan 16, 2019 at 12:17 PM
    #104
    agentcox000
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    Honestly I haven’t touched the settings that ADS shipped them with. I’ll be getting new leafs shortly, want to wait for those until I start playing. Admittedly I have no idea what I’m doing and will have to ask a bunch of shock tuning questions before I start.
  15. May 1, 2019 at 7:41 PM
    #105
    agentcox000
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    Installed the Victory4x4 bed accessory mounts and mounted my Pro Eagle jack to it. I used Quick Fists for the handle. Pretty straight forward install and it turned out looking really clean. Here are some notes if you want to repeat this project
    • You will have to source your own hardware as the Victory4x4 kit is designed for a HiLift
    • Drilling your own holes required. 4 for the quick fists and 2 for the jack mount (two existing holes are reused). Measure twice, drill once!
    • Use 3/4” long hardware to attach the Pro Eagle mount. 1” long hardware is too long and contacts the side of the bed
    • Be sure to tighten the torx bolts on your Toyota bed rails. Mine were barely hand tight from the factory. There’s going to be a lot of weight on them so loose is no good.
  16. May 1, 2019 at 7:59 PM
    #106
    Vizsla
    Vizsla 2 = 2.5
    That’s cool!:thumbsup:
  17. May 1, 2019 at 9:45 PM
    #107
    TheBeast The Beach
    looks great. you should patent it. first time I see someone carrying the jack that way.
    Blkdmax and Rica25 like this.
  18. May 2, 2019 at 8:26 AM
    #108
    Xyleff
    Xyleff New Member
    NorCal
    ‘16040CMSR5
    That’s awesome right there. Nicely done!
    Rica25 and agentcox000[OP] like this.
  19. Jul 19, 2019 at 9:58 PM
    #109
    greggm
    greggm New Member
    Gregg
    Los Gatos, CA
    2019 CM TRD 4x4
    What a great build!
    Rica25 likes this.
  20. Jul 20, 2019 at 8:44 AM
    #110
    Helipilot2
    Helipilot2 New Member
    2019 Cement Limited CrewMax 4x4
    Nice truck!
  21. Aug 30, 2019 at 11:02 PM
    #111
    lbcdan
    lbcdan Zip it up and zip it out
    Daniel
    Long Beach, CA
    2018 Toyota Tundra CrewMax 4x4
    Toytec Boss Coilovers, Total Chaos UCA, Icon 57720P Shocks, Toytec Shackles, TRD Off-Road Wheels, SpiderTrax Spacers, BakFlip MX4, Clazzio Seat Covers, Rough Country Light Bar, BajaDesigns Foglights
    what kind of bed cover are you running?
    Rica25 likes this.
  22. Sep 7, 2020 at 4:30 PM
    #112
    AZ_Tundra1
    AZ_Tundra1 Gold member
    Phoenix, AZ
    2020 White Tundra SR5
    Bilstien 6112 front shocks set at 1.9"
    I am looking at getting a custom spring pack with them,are they good?
    Rica25 likes this.
  23. Sep 7, 2020 at 4:33 PM
    #113
    Vizsla
    Vizsla 2 = 2.5
    They fixed my Deaver springs, very happy with their service/work.
    Rica25 and AZ_Tundra1[QUOTED] like this.
  24. Sep 7, 2020 at 5:15 PM
    #114
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    ^^^^ that gotta be kool to have.
    Rica25 likes this.
