Again...TRD PRO grille
Discussion in '2.5 Gen Tundras (2014-2021)' started by TXRailRoadBandit73, Jul 25, 2016.
  1. Jul 25, 2016 at 8:40 AM
    TXRailRoadBandit73 [OP] YOTAS,RAILROADIN',RÖKnRÖLLN',BEER,MAX/GEMMA
    Does anyone out there have the TRD PRO grille with chrome bulge on top AND chrome bottom???...cause toyotaofdallas.com says they don't come that way only color matched but I want the chrome bottom do a Google search 2014 Toyota Tundra TRD PRO grille look at images ther is a few pics with chrome top n bottom has anyone done this cause that's what I want I've removed my SR5 grille n I see 4 screws with lots of plastic tabs
  2. Jul 25, 2016 at 8:54 AM
    ToyotaTundraMike
    2015 Tundra
    What you are seeing is people who originally had chrome surround and swapped it onto the new trd pro grille. They come in only a few different colors but you can take off the surround that comes with it and replace it with your original surround if that makes sense.
    The actual grille portion and the color matched surround are only held together by tabs.
    If you want the chrome surround and bulge you will have to order that separate from the pro grille (doubt they will even sell ya a surround with no grille) or find one on the forum classifieds more than likely. Or you could always have yours painted the way you want.
  3. Jul 25, 2016 at 8:58 AM
    I took mine off mine behind it has 4 Phillips screws and lots of tabsseems to me I can put TRD one on but I need to go to dealer to see one cause I wana keep chrome
  4. Jul 25, 2016 at 9:01 AM
    ToyotaTundraMike
    2015 Tundra
    Yeah if you already have chrome surround and bulge than just order the pro grille with any color surround and swap your chrome one onto it, that would be easy.
    Thats what others on here have done, and more than likely what your seeing on google.
    Remove the whole thing by taking out the screws on top and popping out the tabs on the sides and bottom and you will see how the 2 pieces fit together.
    Believe its just some more tabs that hold the surround onto the grille but either way the pro grille will for sure fit into your existing chrome surround.
  5. Jul 25, 2016 at 9:14 AM
  6. Jul 25, 2016 at 10:02 AM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    Yes, just as ToyotaTundraMike said ... You'll need to purchase the TRD grill in any one of the available colors and remove the insert from the colored bottom and then connect it to your chrome bottom. If I remember correctly there are 11 tabs in all holding the insert to the bottom.
    I broke just one.
    Separating the insert from the bottom is probably the hardest part to do. Extra care is required to prevent braking the tabs. Go slowly, it can be done.
    SouthBoundSteve likes this.
  7. Jul 25, 2016 at 10:24 AM
    Tophergt99
    Tophergt99 Back in black
    Weston, Wisconsin
    2015 SR5 Black TRD Crewmax
    In progress....
    You can sell the black part (if you get black), always someone looking for them. I like my stock center better so got the black part :)
  8. Jul 25, 2016 at 11:22 AM
    Thanks to all!
  9. Jul 25, 2016 at 11:24 AM
    Thanks!
  10. Jul 25, 2016 at 3:47 PM
    r4z0r51o
    Dave
    I got black and I've had my black surround with chrome insert for sale now over 2 months for dirt cheap and no takers which surprises me. I'd get white, you might have better luck selling it.
  11. Jul 25, 2016 at 3:57 PM
    Tophergt99
    Weston, Wisconsin
    In progress....
    I got my black part for $50 :p I also think most don't know you can take them apart.
  12. Jul 25, 2016 at 3:58 PM
    Black insert??
  13. Jul 25, 2016 at 3:59 PM
    Tophergt99
    Weston, Wisconsin
    In progress....
    No outside part
  14. Jul 25, 2016 at 4:01 PM
    Oh ok
