Aftermarket Stereo wiring harness issues
Discussion in '1st Gen Tundras (2000-2006)' started by 02TundraCJ, Sep 2, 2022.
  1. Sep 2, 2022 at 10:18 PM
    02TundraCJ
    02TundraCJ [OP] New Member
    Cole
    2001 Tundra Access Cab
    Lifted 3.5”. 35” Nitto Mud Grapplers. Aftermarket door speakers and Apple Carplay stereo.
    I’ve been looking forward to installing a new aftermarket stereo in my 01 Tundra, because the factory one is very staticky. I’ve got the new stereo, wiring harness, etc. i didn’t buy a dash kit because it fits well with the old brackets. But I’m having an issue with finding the correct receiver harness, as the one they gave me was incorrect fitment. The plugs from the stereo to dash are too small of a pin count to fit the factory ones in the dash. Any help is welcome, because I’m stuck and haven’t found a solution or correct part yet.
  2. Sep 3, 2022 at 2:51 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    You probably have a factory amp you need to pull out. It sits behind your HVAC controls. 2 bolts to pull the amp out. The connectors on the bottom side of the amp are most likely the ones you need. Post pics of what you have though to confirm.
    04EbonyTundra likes this.
  3. Sep 3, 2022 at 3:51 AM
    kgsweb
    kgsweb New Member
    Greg
    Agree with previous poster that you likely have the Toyota amp in the way. Crutchfield, and many others, sells wiring harnesses that will plug directly into the factory harness so that you don't have to cut existing wires. The factory harness in these Tundra's was used in a lot of Toyotas over the years and these aftermarket harnesses are available in abundance.
    Good Luck.
  4. Sep 3, 2022 at 6:45 AM
    04EbonyTundra
    04EbonyTundra New Member
    Rick
    2004 Access Cab Black
    K&N intake, flowmaster muffler
    Yes I ran into the same issue. Factory amp it's set down under the radio hole inside the dash, and the harness the store sells connects to the harness that goes into that.
  5. Sep 4, 2022 at 1:28 PM
    shifty` All my rowdy friends have settled down
    @02TundraCJ check this for more details on what they're speaking of: https://www.tundras.com/threads/project-double-gnar-adding-stereo-camera.96839/page-2#post-2486086
    ThatYeti likes this.
