Aftermarket Remote starter
Discussion in 'General Tundra Discussion' started by 35chaser, Sep 26, 2017.
  1. Sep 26, 2017 at 5:28 PM
    35chaser
    35chaser [OP] New Member
    Kenny
    Central Massachusetts
    2019 Super White Platinum
    Color match mirrors and door handles RetraxOne MX Tonneau cover WeatherTech Visors Ionic Gladiators Running Board White LED lights
    Hi everyone, i just ordered my Viper 5602v security and remote starter unit. Does anyone know what bypass transponder unit ill need for the G-key? Been having a hard time searching for an answer. All i can find are the fortin units. looking for one from Xpresskit or something similar. any help is greatly appreciated. Thanks!!
  2. Sep 26, 2017 at 5:29 PM
    35chaser
    Kenny
    ah man.. i posted this in the wrong section.. how do i fix that?
  3. Sep 27, 2017 at 4:27 AM
    GavinG83
    GavinG83 New Member
    Gavin
    Wilmington, NC
    2000 Tundra SR5
    DBALL2 is by XpressKit and covers the G key
    35chaser [OP] likes this.
  4. Sep 27, 2017 at 6:15 AM
    35chaser
    Kenny
    Thank you for the help. Do you know if theres a link to wiring diagram for the 2017 tundra?
  5. Sep 27, 2017 at 6:54 AM
    crishard
    crishard Occasional Member
    Cris
    2014 Barcelona Red CM
    3" level in front, ICI Bumper & Skid, 12k lb winch, UCAs, Radtech 2.5s, Kenda 35s, Dual Batteries, 3500w inverter
    Took a pic the last time I was behind the dash. I would love to have a wiring diagram as well. I need to track down some problems.
  6. Sep 27, 2017 at 8:03 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Are u installing urself? Idk if this is for all trucks but on my 17 sr5 we had to cut 2 wires from the passeneger side panel. I believe they were for the TPMS. We installed everything and wouldnt start with remote untill we double cheked and we had missed those 2 wires.
  7. Sep 27, 2017 at 8:50 AM
    35chaser
    Kenny
    Yes I'm installing it myself. I don't think the Limited or SR5 would have different wires for remote start. Parts are ordered, just waiting for arrival and nice weather to install. I never heard of tapping into the TPMS wires, but I've been out of the game for quite some time now. I'll keep everyone updated on how this go.
  8. Sep 27, 2017 at 8:54 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    It was definetly kind of strange but maybe im wrong that they were for tpms. But defiently it was 2 wires on the passeneger side.
  9. Sep 27, 2017 at 10:15 AM
    35chaser
    Kenny
    You are right fisherman, you do tap into the TPMS wires. I found a diagram from Fortin unit that somebody posted.
    Post #4 second diagram
    https://www.tundras.com/threads/fortin-evo-one-remote-start.16061/#post-341574
    Lots of good info on that instruction. Will follow that as a guide but i still need to find me a wiring diagram.
  10. Sep 27, 2017 at 10:31 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    Im still confused on what the hell the tpms has to do with allowing the truck to start but thats what allowed the remote start to turn on truck lol
  11. Sep 27, 2017 at 12:21 PM
    GavinG83
    GavinG83 New Member
    Gavin
    Wilmington, NC
    2000 Tundra SR5
  12. Sep 27, 2017 at 4:10 PM
    35chaser
    Kenny
  13. Sep 28, 2017 at 8:53 AM
    crishard
    Cris
    Would anyone have a suggestion as to why my Viper remote starter thinks it has started the truck, the truck thinks it has started but it isn't running. When I use the starter it starts the countdown, the truck locks & dash lights come on, etc. If I try to manually start the truck it won't allow me because it thinks it's running. I have to cancel with the remote first. What could have happened?
  14. Sep 28, 2017 at 9:25 AM
    GavinG83
    GavinG83 New Member
    Gavin
    Wilmington, NC
    2000 Tundra SR5
    Does the truck crank when you remote start it?
  15. Sep 28, 2017 at 9:26 AM
    crishard
    Cris
    not at all. it does everything but crank.
  16. Sep 28, 2017 at 10:44 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Either a wire connection came off to the starter wire or the relay in the brain has failed. If you are asking this question, you should take it to a professional to have it troubleshot.
  17. Sep 28, 2017 at 2:01 PM
    crishard
    Cris
    Tried to do that. The local Viper installer said that they won't touch someone else's work but they would be glad to rip it out and install another one for $850!
  18. Sep 28, 2017 at 2:05 PM
    35chaser
    Kenny
    Does your light flashes an amount of times to show any error message?
  19. Sep 28, 2017 at 2:10 PM
    crishard
    Cris
    I'll verify but I don't think so. You mean the one that indicates that the system is armed, around the rearview mirror?
  20. Sep 28, 2017 at 3:15 PM
    crishard
    Cris
    nope. no lights. does everything it's supposed to except start.
  21. Sep 28, 2017 at 3:32 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    They suck. Go somewhere else. That's not the way to win business.
  22. Sep 28, 2017 at 4:16 PM
    crishard
    Cris
    It has to be something simple related to the tie-in to the ignition. I'll look into it. It's just kind of hard to tell what's factory & what's not. There's sooo many wires :confused:
    I wish I knew how to disable the chirp when locking & unlocking. I feel like a yuppie
  23. Sep 28, 2017 at 6:01 PM
    35chaser
    Kenny
    Has this remote starter works fine before or has it been like this since you got it installed?
    I found this but it may not be the same case as yours.
    PRODUCT (if applicable)
    Viper 5702V
    BYPASS MODULE (if applicable)
    SYMPTOMS
    Remote start runs its course but car will not crank. (system re-attempts 3 times
    CAUSE
    the 5702v is security and remote start meaning it has built in starter kill. The wires are purple and green (purple output green is the key side of the interrupted crank wire
    RESOLUTION
    Reverse the Purple and green wires on the vehicles crank wire
    IMPORTANT NOTE
    This article requires a basic understanding of the installed system. Please contact your local Authorized Directed Dealer or Retailer if you require additional assistance.
  24. Sep 28, 2017 at 6:13 PM
    crishard
    Cris
    Thanks very much. It worked flawless when I got the truck in summer '15 until winter '16. This Viper system was dealer installed in '14. Mine even stays running when you open the door to get in. From what I've read that is something that not all systems or installers can do.
  25. Sep 28, 2017 at 7:34 PM
    GavinG83
    GavinG83 New Member
    Gavin
    Wilmington, NC
    2000 Tundra SR5
    I would bring it back to installing dealer and have them take a look at it. The wonderful part about viper is the warranty. If it was installed by the Toyota dealership as an add on you should be able to ask in the service department what company did the work. I have installed a lot of systems and if a customer brought the vehicle back and it was altered yes I may charge to look at it. If you want to disable the alarm chirp it can be done one time by pressing the F button one time and then pressing the lock or unlock if I remember correctly. You can always go onto the DEI website and download the users manual.
  26. Sep 29, 2017 at 7:44 AM
    crishard
    Cris
    Gavin,
    Thanks for the suggestions. I would take it to the dealer but I drove 4hrs to get it so that wouldn't work for me.
    I found the function to disable the chirp each time you unlock or lock but that, to me, is ridiculous. I would like to disable & have it stay that way.
    I'll try to sort this out when I get some time off work.
  27. Sep 29, 2017 at 8:57 AM
    GavinG83
    GavinG83 New Member
    Gavin
    Wilmington, NC
    2000 Tundra SR5
    Don't blame you for not wanting to bring it 4 hours back. I can take a look at the install guide and see if there is a way to disable the chirping. What model system is it that you have in your truck?
  28. Sep 29, 2017 at 8:57 AM
    35chaser
    Kenny
    Do you have the model number number of the viper? I might be able to help find an install manual. There is a setting to turn off all chirps. There are many settings that we can change but you will need to know how to use the valet switch and reprogrammed it. Or a bitwriter will be the easiest.
  29. Sep 29, 2017 at 10:48 AM
    crishard
    Cris
  30. Sep 29, 2017 at 7:58 PM
    GavinG83
    GavinG83 New Member
    Gavin
    Wilmington, NC
    2000 Tundra SR5
    It's a bit of a PITA to turn off the chirps without a bitwriter but can be done. Check out the install guide page 16 is where the programming options you are looking for begin. Feature 3 specifically. Hopefully this at least helps you out with one thing.
