Aftermarket front bumper on 2019 Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by rrod, Dec 1, 2019.
  1. Dec 27, 2019 at 10:08 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I had to vertically slot the the mounting holes and chamfer lower edge of mounting plates (mating side). I measured 3 trucks and gap ranges from 13mm - 15mm. I ended up with 14mm.
  2. Dec 28, 2019 at 8:52 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    that’s insane for how expensive that bumper is
  3. Dec 28, 2019 at 9:12 AM
    matictundra
    Franco
    AZ
    I agree. I told them what to do, for free may I add, since they are local to me. My recommendations allows for virtually no gap or factory gap, but they didn’t want to listen.
  4. Dec 31, 2019 at 10:11 AM
    cooper4x4
    cooper4x4 New Member
    2016 Tundra SR5
  5. Jan 1, 2020 at 5:58 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    I should have one of first demello bumpers front and rear here shortly. I have been waiting over 6 months. Was fortunate enough to get on the presale. Once fitted I will report back.
    rockmup likes this.
  6. Jan 2, 2020 at 9:47 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Looking hard at that rear bumper, can't wait to see it on your truck.
  7. Jan 6, 2020 at 2:09 PM
    cooper4x4
    2016 Tundra SR5
    My buddy had his come in...just needs to get it powdercoated.
  8. Jan 10, 2020 at 4:45 AM
    turkeycreek29010
    turkeycreek29010 New Member
    Chuck
    Bishopville SC
    2019 Cement Tundra Crew Max
    3/1 Level Kit, 20 inch Gear Wheel, 285/65/20 BFG
    Did this bumper come with the "grill" for the center section where the light bar would go?
  9. Jan 10, 2020 at 8:39 AM
    salmonfacesalad
    salmonfacesalad New Member
    No. I had the grill custom made on a water jet with aluminum. It mounts utilizing the LED bar mount tabs. My friend works at the shop and patterned the grill close to the Pro grill.
  10. Mar 4, 2020 at 11:37 AM
    Broverland_tundra
    Broverland_tundra New Member
    Lee
    2016 Toyota Tundra Platinum
    Did you attach the front parking sensors in the holes by the fog lights?
  11. Mar 11, 2020 at 8:57 AM
    2a_TX_Tundra
    2a_TX_Tundra New Member
    2020 SR5 CM TSS in Quicksand
    Do you think your friend would be willing to make one and ship it to me? Also did you use the Westin Light mount kit to mount your Rigid lights or did you make a custom mount for those? Westin refuses to sell just the Light mount kit without the lights.
  12. Jun 11, 2020 at 4:57 PM
    Lockmonster00
    Lockmonster00 New Member
    Dallas, Tx
    2015 Red SR5 4x4
    Did you figure out a light mount for the outlaw bumper fog lights? I have ss3 fogs from diode dynamics and need a way to install them on a bracket...
    Anyone else have a solution to mount lights on the outlaw bumper?
    @salmonfacesalad
    @Vizsla
    salmonfacesalad likes this.
  13. Jun 11, 2020 at 5:12 PM
    2a_TX_Tundra
    I ended up making my own light mounts and mounted one 8 inch light bar on each side as fog lights and a 30 inch RC light bar in the middle. Ill upload some pictures in a minute.
  14. Jun 11, 2020 at 5:16 PM
    2a_TX_Tundra
    The light is dirty as fuck that's why it looks hazed but its not.
    Watson and salmonfacesalad like this.
  15. Jun 17, 2020 at 9:17 AM
    salmonfacesalad
    i used the fog light kit from Westin. Specifically the square ones. I then used Rigid lights instead of the supplied ones.
    2a_TX_Tundra likes this.
  16. Jun 17, 2020 at 9:55 AM
    salmonfacesalad
  17. Sep 11, 2020 at 7:15 PM
    wdevit1
    wdevit1 New Member
    I’m getting quotes for 3600-3800 for front and rear outlaw bumpers, skid plate, lights, and hitch. This includes 9 hrs of labor and tax (9.5%) does this sound about right?
  18. Sep 13, 2020 at 10:29 AM
    2a_TX_Tundra
    Sounds to expensive to me.
  19. Sep 13, 2020 at 10:33 AM
    #49
    2a_TX_Tundra
    Parts are around $2700. Install for both should only take about 4 hours. They are charging to much on labor. I did my front bumper by my self on my garage floor in about 3 hours.
  20. Jan 7, 2022 at 8:25 AM
    #50
    BAPPO
    BAPPO New Member
    2017 superwhite tundra trd 4x4
    6112 front rear airlift bags with cradle and 5112
    Hey quick question what skid plate did u run is it the whole thing or half
  21. Jan 7, 2022 at 8:26 AM
    #51
    BAPPO
    BAPPO New Member
    I just got the rear bumper how did u do it if u have any pictures of the brackets on the rear?
