After-market radio issues
Discussion in 'Audio & Video' started by phrozenice06, Jun 4, 2018.
  1. Jun 4, 2018 at 2:40 PM
    phrozenice06
    phrozenice06 [OP] New Member
    Gary
    2010 tundra crew max tdr
    Hey there, I have just bought my first truck ever and I made it a 2010 Tundra Crew Max. I wanted to change the stock radio to a touch screen. So I bought a Kenwood DMX7704s with all the brain to hook up to my steering wheel. A couple of days later, the radio started to shut off and back on. It started doing this every 8 to 10 minutes. So I called crutchfield and they sent me the next version up and it still does the same thing. I change the brains that talk to the truck and made sure everything was properly connect and still keep happening. Can anyone give me a couple of tips? I really appreciate the help.
  2. Jun 4, 2018 at 2:48 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Welcome!
    Couple questions:
    When you say "brain" do you mean the Maestro integration kit?
    Is it shutting off 8-10 min like clockwork, or is it when you hit a bump?
  3. Jun 4, 2018 at 2:52 PM
    phrozenice06
    Gary
    Yes, the integration module. And I can be sitting still and it still turn off like it it rebooting itself. Almost like u are turning the truck off then back on. Its so frustrating and crutchfield can't even tell me anything.
  4. Jun 4, 2018 at 2:55 PM
    Danimal86
    Daniel
    Sacramento, CA
    Thats a bummer. There are plenty of people here with kenwood decks with the maestro kit. Hopefully they will chime in.
    Since they replaced the deck, i wonder if its the Maestro module shorting it out when it cycles.
  5. Jun 4, 2018 at 2:57 PM
    phrozenice06
    Gary
    Crutchfield even sent me a new one and I change it out as well with no help. Thanks though....
  6. Jun 4, 2018 at 3:31 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    First thing I'd do is check for loose connections in the harness
  7. Jun 4, 2018 at 3:44 PM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
    Where is it located, is it overheating?
    (I don't know anything about this specific system)
  8. Jun 5, 2018 at 12:13 AM
    phrozenice06
    Gary
    Hey ninjajay, the harness is fully secured, I had crutchfield put it together. The wiring was check thoroughly. TFT, I don't seem to have a overheating problem. I just placed it where the factory radio was. It just terrible to have a great radio and can't listen to it.
