AFE Filter Size
Discussion in '3rd Gen Tundras (2014-2021)' started by ArXane, Aug 27, 2020.
  1. Aug 27, 2020 at 7:40 PM
    ArXane
    ArXane [OP] New Member
    I purchased a Pro Dry S filter, 31-10146, that says it fits my 2019. However, it's about an inch taller than my current filter and will not fit. Anyone else experience this?
  2. Aug 27, 2020 at 7:43 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I’ve been using mine with a diff part number for a while in my 2015 and it fit perfect. As long as the air box hasn’t changed try this one.
  3. Aug 27, 2020 at 8:16 PM
    ArXane
    Ugh, two different size airboxes? Dang
  4. Aug 27, 2020 at 8:30 PM
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Not sure but I don’t think they changed. The size I posted worked in my stock air box and also works in the trd air box
  5. Aug 27, 2020 at 8:34 PM
    ArXane
    Just two different part numbers? This is why I got the one I got:
