AFE air intake installed , CEL and traction control light came on & returns after re-set :(
Discussion in 'Performance and Tuning' started by trailmaster, Feb 13, 2016.
  1. Feb 13, 2016 at 7:27 AM
    trailmaster
    trailmaster [OP] 2014 Toy Tundra 1794
    Ogden, UT
    leveling kit, (3" front, 1" back) after mkt wheels, carpet kit, bed cover, tinted window visiors, S&B air intake, Sylvania ultra headlight bulbs, Nokya Artic White fog bulbs, Spyder LED tail lights, 320 lumen reverse light bulbs, 275 65 20 Michelins.
    Installed the AFE Momentum Air Intake and my CEL & Traction Control Off are both illuminated. Any idea on a fix?? Yes, i have reset multiple times and CEL returns within 30 min. of drive time.
    Called AFE and they a supposed to be sending me a different throttle body tube. They think it might be a problem with the crank case vent (CCV) hole diameter being too small on the aFe tube; BUT they really don't know. Dis-appointing to spend $425 and create a problem you didn't have prior. Performance seems improved and sound is improved...but that damn annoying CEL! Will return to Realtruck if i can't get this resolved.
    Any other recommendations for other intakes for 2014 5.7L Toy Tundra??
  2. Feb 13, 2016 at 8:25 AM
    Welcome from CO. Sorry to hear about that. I left my factory air box alone (which is a CAI) and dropped in a K&N. S&B makes very good CAI's and for some reason not mentioned here a lot. S&B makes military spec dust particle separators/filters for tanks and aircraft and usually kicks butt over the competition. Not sure how S&B sounds but probably has the best filtration.
  3. Feb 13, 2016 at 10:06 AM
    trailmaster
    Ogden, UT
    thanks for the intel
  4. Mar 13, 2016 at 9:27 AM
    trailmaster
    Ogden, UT
    Ordered a S & B, sent the aFe Momentum back for refund. Will post results of the install, performance, CEL status, etc. as soon as i install it and run it a few days
    Hbjeff and Black Wolf[QUOTED] like this.
  5. Mar 13, 2016 at 11:51 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Those s&b look pretty good. I'd like to know what you think of it after its on your truck about 500 miles
    Black Wolf likes this.
  6. Mar 13, 2016 at 1:11 PM
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    2021 Tundra SR5 Crewmax ~ ARMY GREEN
    I have the exact same intake, AFE Momentum and have had no problems since date of install. Hopefully just a small defect as you've mentioned.
  7. Mar 13, 2016 at 4:37 PM
  8. Mar 13, 2016 at 6:02 PM
    trailmaster
    Ogden, UT
    will do.
  9. Mar 13, 2016 at 6:08 PM
    trailmaster
    Ogden, UT
    interesting, maybe they just had a bad lot of non-conforming intakes. on mine the MAF interface allowed air to leak around the MAF causing the CEL. aFe sent me another and it had the same discrepancy. I told aFe customer service to notify me when they came up with a solution. Did not hear back for a few weeks, so ordered the S & B based on reviews and MATLUTH's recommend
  10. Mar 13, 2016 at 6:14 PM
    I prefer my stock CAI with K&N, (for now) but I would definitely go with the S&B if I were to change things. Definitely S&B. Good enough for military, good enough for me.
  11. Mar 13, 2016 at 6:30 PM
    Ditto on that^^^. You see a lot of S&B's on semi's too. Usually that is a good sign.....
  12. Mar 14, 2016 at 11:02 PM
    tat2ude39
    tat2ude39 MYota
    Robert
    San Tan Valley, AZ
    I have read good things on S&B also, of course after I bought the AFE. Would be interested in hearing your feedback on that system.
  13. Mar 21, 2016 at 7:00 PM
    trailmaster
    Ogden, UT
    Had the S & B on for a week now. very pleased. Really howls when you get on it. Not sure on gas mileage yet. Need to quit putting my foot in it! :)
  14. Mar 21, 2016 at 7:28 PM
    Thanks for the update. You probably want to forget about gas mileage. heh heh.
  15. Mar 21, 2016 at 8:05 PM
    trailmaster
    Ogden, UT
    Bought it on your recommend, plus all the positive posts on S & B and RealTruck websites...Thanks.
    Tundralicious likes this.
  16. May 17, 2020 at 11:38 AM
    Tundralicious
    Tundralicious New Member
    Toytoy
    2020 Tundra TRD Sport Premium
    Stock for now
    You should put a video and let us know how it performed after all of that time.
