Advice on travel trailer
Discussion in 'Towing & Hauling' started by DM 2018 Tundra, Aug 10, 2019.
  1. Aug 10, 2019 at 12:05 PM
    DM 2018 Tundra
    DM 2018 Tundra [OP] New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    Good evening Tundra towers. My wife has informed me that she has went and looked a some campers as I am on a fishing trip. She send me a picture of the ones she liked along with how much they weigh. So she has found one that weighs at 5200 pounds empty. 23 feet long. They have single and tandem axles. My question is I have a 6 inch lift. So what else will I need? Will I be safe towing? How much weight does folks usually put in the camper when in tow. Thanks for any any any help on this. I am driving home today. Thoughts from the professional towers!!! Please
  2. Aug 10, 2019 at 12:17 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Your wife sounds awesome!
    The one suggestion i have is to think about your rear suspension. How is it lifted? If it is blocks, consider full lift springs to eliminate blocks
    Melikeymy beer and ColoradoTJ like this.
  3. Aug 10, 2019 at 12:17 PM
    nowayout
    nowayout New Member
    NY
    17 CM
  4. Aug 10, 2019 at 12:30 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Blocks. I have ordered some spring helpers.
  5. Aug 10, 2019 at 12:32 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Yes she is pretty awesome!! She wants to camp when it’s cold cause in the summer we’re on our boat.
  6. Aug 10, 2019 at 1:47 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Lucky man. Spring helpers are good for the load, but the blocks are very tall and with a trailer you might have some bad axle wrap. Look into that
  7. Aug 10, 2019 at 2:42 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Will do. Thanks I will. But it should tow fine with the lift?
  8. Aug 10, 2019 at 2:59 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    There are some great long threads about gears and big tires.
    Your trailer plans sound pretty reasonable, but I personally would regear the axles properly for towing and eliminated rear blocks
  9. Aug 10, 2019 at 3:02 PM
    Have you re-geared?
    With that light of a load, having a good LDH and set up right, should be good to go.
    The advice on the lift blocks is solid. Look into that.
  10. Aug 10, 2019 at 3:31 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Thanks guys!!! I have not re-geared. I will look into the new springs. I also haul a 26 pondtoon to the lake but not far. I love about 8 mins from a lake then maybe an hour to the other lake. I think the boat weighs 3000. I was just worried due to my truck being lift and haul 5-6000 pounds would be an issue?? Thanks
  11. Aug 10, 2019 at 3:37 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The lift height is affecting stability, the tire size is killing the pulling power
  12. Aug 10, 2019 at 4:53 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Ok so I can fix the stability and power is what I will have to deal with. Told wife I needed to RE gear the truck. She LOL
    Hbjeff likes this.
  13. Aug 10, 2019 at 4:53 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
