Advice on replacing door opening weatherstripping?
Discussion in '1st Gen Tundras (2000-2006)' started by Iceman98133, Mar 10, 2020.
  1. Mar 10, 2020 at 7:05 PM
    Iceman98133
    Iceman98133 [OP] New Member
    Richard
    2001 Toyota Tundra trd
    None
    Just wondering if anyone here has ever replaced the door opening weatherstripping on a 2001 Toyota Tundra trd crew cab, if so any pointers would help .
  2. Mar 10, 2020 at 8:14 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  3. Mar 11, 2020 at 6:33 AM
    Iceman98133
    Richard
    None
    I ha e to wether stripping just want to know if it comes with the glue on it or if I need to by some
  4. Mar 11, 2020 at 11:30 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Where did you get it? Stealership? AFAIK, it just pops in.
  5. Mar 11, 2020 at 11:34 AM
    Iceman98133
    Richard
    None
    I bought through the dealership
  6. Mar 11, 2020 at 12:54 PM
    Iceman98133
    Richard
    None
    So I don’t need to glue it?
  7. Mar 11, 2020 at 6:50 PM
    RR60
    RR60 New Member
    2003 SR5 Tundra long bed
    No glue needed. Not hard to install. Only problem I had was I had to adjust the door striker. It was hard to close the door all the way. And still had to slam the door a little harder for about a year.
  8. Mar 11, 2020 at 6:52 PM
    Iceman98133
    Richard
    None
    Thanks for the advise all advise is appreciated
    GNTundra likes this.
  9. Mar 14, 2020 at 1:35 PM
    Iceman98133
    Richard
    None
    Thanks guys just finished drivers side and door closes fine.
    Jack McCarthy and bmf4069 like this.
  10. Apr 20, 2023 at 7:15 PM
    rgkharrison
    rgkharrison New Member
    Robert
    2005 Tundra - Double Cab
    Any pointers for a double cab? I’m doing the drivers door and struggling like heck around the 90 degree bend in the top corner. Had almost all of it in but that corner wasn’t tucked properly and there was too much excess to fit. Started over and couldn’t get that corner to sit properly even when nothing else was in.
  11. Apr 20, 2023 at 9:48 PM
    Marxi
    Marxi New Member
    Mark
    La Mirada, CA
    2004 4.7L V8 Tundra DC 2WD
    Headlights, radio head unit and rear speakers, rims, power tailgate lock/unlock, Tailgate release handle with rear cam, front cam on grille’s Toyota logo
    Had the same problem when I did my 04 Dbl Cab driver’s side door. So I left it like that but then wind noise comes thru that area. I caulked that corner on the outside and the wind noise stopped. Also no leaks when I take it to the car wash so I guess it’s ok. I also had the same problem on the opposite corner (bottom front) and did the same. The cab is very quiet now.
  12. Apr 21, 2023 at 12:29 PM
    ericryder
    ericryder Nailbender
    Eric
    HILLSBOROUGH
    '04 SR5 3.4 5 speed access cab
    Head unit and door speakers aluminum ladder rack
    " Had almost all of it in but that corner wasn’t tucked properly and there was too much excess to fit. Started over and couldn’t get that corner to sit properly even when nothing else was in."
    No personal experience, but watching Scott do a Lexus or Toyota on VEHCOR YT - he mentioned being careful to not stretch it as you install.
  13. Apr 21, 2023 at 12:57 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Not sure this is a pointer but I do recall having to relieve the inside B trim with my fingers as I then guided it in. At a point in time, I considered taking the B trim off but eventually it all worked out.
