Advice from the suspension gurus
Discussion in 'Suspension' started by Beardedbeast, Jan 10, 2017.
  1. Jan 12, 2017 at 8:05 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    And thats why you shim or buy new bump stops to account for that. And half the people buying these shocks aren't going to use them what they are for or max them out.
  2. Jan 12, 2017 at 8:12 AM
    xtyfighterx
    Ty
    North Idaho
    So buy getting a Lower spring rate you can preload less? Or did I mis read something?
  3. Jan 12, 2017 at 8:18 AM
    sc134
    sc134 O.P.S.
    2017 Tundra PreRunner
    Front 2.5 Fox Factory Extended Length Coilovers, Total Chaos Upper Control Arms, Swapped projector Headlights, Tint, Dual Carven Exhaust
    Okay I'll take better picture. I'm not sure of the spring rate just ordered the shocks and uca together as a mid travel set up.
    It probably is high spring rate because I tried adjusting and they were really hard. Even to compress so I left them like that.
  4. Jan 12, 2017 at 8:19 AM
    sc134
    sc134 O.P.S.
    I had fox before on my Tacoma and they were no where near as hard as these are to adjust. Even with the ring screw a bit untightened
  5. Jan 12, 2017 at 8:19 AM
    xtyfighterx
    Ty
    North Idaho
    Believe fox comes with 700lb spring I have to spray some lube on mine jack the front end off to take the pressure off then adjust it
  6. Jan 12, 2017 at 8:19 AM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    You do have the truck off the ground when adjusting correct? Also try to squirt a tad bit of WD40 on the threads when you adjust them
  7. Jan 12, 2017 at 8:20 AM
    sc134
    sc134 O.P.S.
    I had them withour the uca and tires while trying to adjust and it was near impossible. Unless I hit with a rubber mallet to turn the spanner wrench after on full turn I left it like that instead.
  8. Jan 12, 2017 at 8:21 AM
    sc134
    sc134 O.P.S.
    Truck was off the ground. Without uca or tires.
    I've done it before. Just these were really hard
  9. Jan 12, 2017 at 8:24 AM
    xtyfighterx
    Ty
    North Idaho
    Takes a lot of lube I was constantly squirting lol haha
  10. Jan 12, 2017 at 8:27 AM
    sc134
    sc134 O.P.S.
    I like how it sits right now. If I go higher I'll be doing it with a spindle.
    I was just surprised with the little bit of thread showing (0.75") it gave me that much lift.
    With my Tacoma it had to show about 2" of thread.
  11. Jan 12, 2017 at 8:27 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Other way around. Higher spring rate = less preload.
    CM-LENNY likes this.
  12. Jan 12, 2017 at 8:29 AM
    xtyfighterx
    Ty
    North Idaho
    That's what I thought I must of Misread something.
  13. Jan 12, 2017 at 8:30 AM
    xtyfighterx
    Ty
    North Idaho
    Same here I was also surprised. Take a hub to fender measurment to if you would what size tires do you have?
  14. Jan 12, 2017 at 10:42 AM
    sc134
    sc134 O.P.S.
    Here it is
  15. Jan 12, 2017 at 1:32 PM
    jberry813
    Lake Tahoe
    700# springs?
    Definitely take out some preload.
    ColoradoTJ likes this.
  16. Jan 12, 2017 at 1:48 PM
    More fucked up than a football bat.
    Is that the new runner build? Me likey.
  17. Jan 12, 2017 at 1:49 PM
    jberry813
    Lake Tahoe
    Those are individual shots of all the builds. Top to bottom is
    2012 Tacoma
    2004 Tacoma
    2015 Tundra
    2006 4Runner
  18. Jan 12, 2017 at 1:51 PM
    See that paint missing around the uni-ball on the back side? This is what Jerry is talking about, and stood out to him....if you wanna know.
  19. Jan 12, 2017 at 1:53 PM
    #49
    Like that 4Runner color man. Glad to see you around.
  20. Jan 12, 2017 at 2:04 PM
    #50
    jberry813
    Lake Tahoe
    Been a busy few months between work, house mods, truck mods, and holidays.
    The soccer mom short bus definitely got some love though.
  21. Jan 12, 2017 at 2:14 PM
    #51
    Very nice man. Flippen sharp.
    @bandit is starting a pretty epic Runner build. He has been busy.
  22. Jan 12, 2017 at 2:22 PM
    #52
    I just laughed so hard I blew snot out my nose. (Me sick)
    bandit likes this.
  23. Jan 12, 2017 at 3:17 PM
    #53
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    oooh this looks like fun :)
  24. Jan 12, 2017 at 3:32 PM
    #54
    sc134
    sc134 O.P.S.
    There's no paint missing ???
  25. Jan 12, 2017 at 3:34 PM
    #55
    Oh give him some time.....he just got it a while back.
    Unlike myself, paint is an option.
  26. Jan 12, 2017 at 3:35 PM
    #56
    sc134
    sc134 O.P.S.
  27. Jan 12, 2017 at 3:40 PM
    #57
    PermaFrostTRD
    Northern NY
    Hahahaha
    First paragraph might as well have been in Japanese.
    jberry813[QUOTED] and ColoradoTJ like this.
  28. Jan 12, 2017 at 3:43 PM
    #58
    This is me literally ripping my top off my TJ....and some paint off the fenders.
    This is me massaging the drivers side a tad.
    And I'm sure my beadlock ring on the passenger rear is scuffed nicely.
    I'm probably the only person on this board that carries a can of high gloss black spray paint...lol
    dejabrown, bandit and joonbug like this.
  29. Jan 12, 2017 at 3:48 PM
    #59
    He actually just gave you some good tech. There is some good science that goes into suspension setups that work.
    PermaFrostTRD[QUOTED] likes this.
  30. Jan 12, 2017 at 4:03 PM
    #60
    PermaFrostTRD
    Northern NY
    Yeah definitely got knowledge bonged.
    But as long as my truck can jump a rut headed out to some hunting spots I'm good. Definitely not a crawler or trail boss.
    When it's time for new struts I'll probably replace the fronts with the Billy 6112's. doubt I'll extend them much past the stock or 1+ setting.
