Advice for towing sag and sway, pulling 7700lb travel trailer
Discussion in 'Towing & Hauling' started by Moosemeat, Oct 9, 2018.
  1. Jul 30, 2020 at 12:36 PM
    Smokey 314
    Smokey 314 New Member
    League City, Texas
    2020 Tundra TSS Off Road
    Sumo Springs
    Sounds good. Thank you
  2. Aug 10, 2020 at 5:33 PM
    sgtfluffy16
    sgtfluffy16 New Member
    Corey
    2019 Super White Tunda TRDPro
    Stock
    Have you hooked up a gage to watch your transmission temperatures while you're towing?
  3. Aug 10, 2020 at 5:34 PM
    sgtfluffy16
    Corey
    Stock
    Get a Bluetooth OBD2 and something to read the transmission fluid temperatures.
  4. Aug 11, 2020 at 8:57 AM
    lawfarm
    lawfarm New Member
    2018 Tundra SR5 Premium TRD Crewmax
    I just shared my experience with a similar setup on our cross-country trip; highly recommend the E4!
  5. Aug 11, 2020 at 12:51 PM
    Smokey 314
    League City, Texas
    Sumo Springs
    I have not
  6. Aug 11, 2020 at 1:07 PM
    sgtfluffy16
    Corey
    Stock
    You should! Watch those temps rise!
  7. Aug 14, 2020 at 7:08 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    You mean he shouldn't just stuff it in 'D' and let the transmission THINK for him?:eek::thumbsup:
  8. Aug 24, 2020 at 5:33 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    Towing 32', 8495 lb GVWR TT with E4 1k/10K Equalizer WDH (set up with 7 of 8 washers installed). Installed Roadmaster Active Suspension which helps porpoising over uneven roads. Air the Tundra tires to 45psi (vs 52psi max) and maintain speed at 60-65mph in S4 with Tow/Haul engaged - will go to S5 on level terrain. Run the OEM integrated brake controller at 9. Plan to install E rated tires when current tires need replaced. Tows well.
    Wbaird1984 and CMB like this.
  9. Aug 24, 2020 at 5:47 AM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    Do you know your GVW or GCW when towing that?
    Cpl_Punishment likes this.
  10. Aug 24, 2020 at 5:57 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    The 5.7L is really happiest towing at 3,000 rpm getting 9.5 - 10.5 mpg. The engine rpm's are not the issue, the transmission temps are the problem as others have said. I run at about 200F when the torque converter is locked in S4. When you are in automatic and shifting/downshifting between 4-5-6, you can see the temps rise rapidly to 250F+.
  11. Aug 24, 2020 at 6:07 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    Last time I went to the CAT scale, the GCW was 14,260 lbs loaded vs max GCWR of 15,360 lbs. Never run with anything in the TT tanks and careful about loading the Tundra & the TT. Pretty much maxed out.
  12. Aug 24, 2020 at 7:42 AM
    Dorks68
    Dorks68 New Member
    Derek
    2010 Rock Warrior
    Just got home from my first trip with our new trailer. Jayco 29’ overall, probably 6000-6500 lbs, truck bed loaded. Averaged 8.8 mpg. Ride rite air bags set at 50 PSI. No WDH. I feel like I didn’t even need it. Truck handled it like a champ. Passing people easily on the inclines.
