ADS shocks
Discussion in 'Suspension' started by cain0725, Apr 11, 2021.
  1. Aug 29, 2023 at 4:18 PM
    #181
    2TunGet1
    2TunGet1 Tundra owner since 2000
    2020 Limited 4x4 CM QS / 2000 Limited 4x2 AC Black
    I kind of get the impression that in order to get the maximum benefit out of the 3.0, one would also need to install a full cage to protect themselves, lol. Not sure if my thinking is correct but the way the 3.0 is described, it’s really for racing and this big heavy truck is no race truck - at least mine isn’t!
  2. Aug 29, 2023 at 6:23 PM
    #182
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Nahhh. It’s more about the terrain and how much you’re making that shock go up and down. Shocks working hard will make heat. It’s the simple way they work. Since they control the suspension travel by cramming oil through the valve stack, friction is how damping is achieved. Like brakes, friction in a shock converts the energy to heat. Bigger shock, more oil. More oil volume in a big shock means it can work for more time before that heat builds up.
    Would a 3.0 be overkill? Yeah, if you never work a 2.5 hard enough to get hot!
    Marv hit the nail on the head. There is no comparison to stock, and you’re gonna be all smiles when you get your truck together. Looking forward to hearing your reviews!
    2TunGet1[QUOTED] likes this.
  3. Aug 29, 2023 at 6:27 PM
    #183
    Chad D.
    Chad D. New Member
    Western Oregon
    Somebody is gonna get a sweet deal here in about 6 months when you go full LT….
    3.0 coilovers with 2.5 bypass front is in your future, I’m betting. Then you will need a bed cage, 3” wide SUA Deaver leaf packs, and 14” bypasses back there…
    Dibs on them rear bypasses you have now….
  4. Aug 29, 2023 at 7:17 PM
    #184
    2TunGet1
    Do you think a good way to test if you really need 3.0 is to go do what I normally will be doing and then see how hot the reservoir gets? If it’s not too hot to touch then a 3.0 would be a waste?
    Sometimes I buy the overkill option to future proof my unforeseen endeavors but in this case, my shop guy said that 3.0 is completely unnecessary for what I will be doing. Plus no 700lb spring option.
  5. Aug 29, 2023 at 9:25 PM
    #185
    Chad D.
    Chad D. New Member
    Western Oregon
    IMHO, you’re 99.7% fine with 2.5”.
    If you really need 3.0, you’d already know it!
  6. Aug 29, 2023 at 9:27 PM
    #186
    Trdripper
    Trdripper New Member
    Bronze 2nd Gen
    King 3.0 front Coilovers with TC UCA King 3.0 rear Bypass shocks
    With 3.0s the front IMO deff is compareable to the rear now. That’s just my opinion. My 3.0 front Coilovers have a huge difference in dampening way more than my fox and king 2.5s ever had. But I do don’t do slow crawling and over landing as much as i am too 2wd
  7. Aug 29, 2023 at 9:29 PM
    #187
    Trdripper
    Bronze 2nd Gen
    I’ll be listing my King 3.0 F and R set here soon. Hopefully it will go fast… gotta budget for my next build haha
    Buy aside nothing wrong with 2.5s they’re fantastic on their own! Everyone can do as they wish
  8. Aug 30, 2023 at 12:33 PM
    #188
    Marvthehamster
    Marvthehamster New Member
    Tom
    CO
    2018 CM
    ADS/Deaver, Method's, 35's, RCI Armor, OTT Tune
    I'm not sure there's a good way to test if you "really need" 3.0's. I've never put my hand on my 2.5 resi after a good romp, but I'll bet they don't get too hot to touch. It doesnt mean that a 3.0 shock running the same section wouldn't have felt better and performed better...
    Some would consider 3.0 overkill, others might appreciate the extra performance and find it worth the upgrade from 2.5's. Do you absolutely NEED 3.0's for your purpose..no way. If you're really ONLY going to be doing "slow overlanding" with the truck I think you'd probably be fine with a basic set of 2.0 Bilstiens or Toytec's. Hell, the stock suspension will probably get you there just fine at that point.
    I think you'll find that as the truck's capability to go faster over rougher terrain increases, so will your desire to go even faster over rougher terrain :)
    The 2.5's are gonna get you there, believe me. They're great shocks.
  9. Aug 30, 2023 at 12:35 PM
    #189
    Marvthehamster
    Tom
    CO
    2018 CM
    Haha, man I'm definitely thinking about it....
    I think some gears and/or supercharger could come first though. It's all kind of silly since the damn things are all headed for the junk heap at some point...
    I'd seriously be trading the tundra on a Raptor if they made one in a 6 seater config. I gotta be able to take my whole crew with me!
  10. Aug 30, 2023 at 3:27 PM
    #190
    Chad D.
    Chad D. New Member
    Western Oregon
    Gears, my man. Gears... Then blower if it's still not enough!
  11. Aug 30, 2023 at 8:20 PM
    #191
    Trdripper
    Bronze 2nd Gen
    I think I’m gonna do a review on my 3.0s vs my buddies 2.5s… his are ona. Silverado 1500 but it might be a cool video to see although they are different trucks
  12. Sep 7, 2023 at 7:21 PM
    #192
    2TunGet1
    Well fellas, I had a change in plan. I cancelled the order with the 2.5’s with the other shop and decided to call Matt with MCM Fab.
    I will be taking a 9 hour trip to him in Las Vegas later this month to have all the work done including the BMC, pinch weld, suspension. Decided to just go with the ADS 3.0 up front. Still deciding on the rear, if I should go 2.5 resi with clicker or bypass.
    I’ll be hauling all 4 of my new wheels with 37s in the bed on my trip, lol!
    reywcms likes this.
  13. Sep 7, 2023 at 7:27 PM
    #193
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    The owner of King himself said anything over 5k lbs should really be on a 3.0 coilover. The problem is packaging it’s a tight fit for sure. But I do just fine on a 2.5” but will probably go up in bypass size upfront when the phase happens.
    2TunGet1 likes this.
  14. Sep 7, 2023 at 7:57 PM
    #194
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Does that mean on a single shock/corner or combination surface area/volume of shock oil…lol
    I mean combined you have 2.5 x 2 you have 8.18 in^2 vs 7.069 in^2 piston area with more volume of fluid to dissipate that thermal energy.
    snivilous likes this.
  15. Sep 7, 2023 at 8:00 PM
    #195
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    He didn’t get into details but 3.0 coilover per corner I believe. But definitely not the first time I’ve heard this with the weight of these rigs.
  16. Sep 7, 2023 at 9:31 PM
    #196
    Chad D.
    Chad D. New Member
    Western Oregon
    Probably fair to assume that this will also depend on the expected use of the suspension. You and I both have 2.5” coilovers. I’d be willing to bet lunch that you’re asking a heluva lot more from them than I am!
    reywcms[QUOTED] likes this.
  17. Sep 8, 2023 at 5:10 PM
    #197
    Marvthehamster
    Tom
    CO
    2018 CM
    Bypass for the win, bro. You’ll never miss that extra money and they’re awesome. They do make noise so if that really bothers you….just go faster or turn your radio up.
    831Tun and 2TunGet1[QUOTED] like this.
  18. Sep 8, 2023 at 6:11 PM
    #198
    2TunGet1
    Does the noise engage during any type of driving? Slow, fast, light terrain, rough terrain?
    My only reservation is that my wife and kids will be with me during our adventures so I don’t want them having to hear it constantly. If it is only during rough terrain or at higher speeds, it would be fine, but all the time, maybe not.
  19. Sep 8, 2023 at 6:18 PM
    #199
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yes it’s always clicking. Sounds like loose marbles or like somethings broken. It’s not for everyone for sure but I enjoy it. It’s part of the experience
  20. Sep 8, 2023 at 6:43 PM
    #200
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    @Marvthehamster speaks the truth. Different manufacturers have different valves that emit different sounds. I never hear my rear Fox bypass shocks. Honestly I never hear the Kings in front either. However, I did hear the (rear) ADS bypasses when I had them but only at low speed with the window down. The sound of the bypasses is a small price to pay for the bump up in ride quality and a great excuse for sound system upgrades ;). The one time I took my wife and daughters, they never mentioned the bypass clicking.
    2TunGet1[QUOTED] and reywcms like this.
  21. Sep 8, 2023 at 6:44 PM
    #201
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    it is when they don’t click is when you know something ain’t right…
    2TunGet1 and reywcms[QUOTED] like this.
  22. Sep 8, 2023 at 6:50 PM
    #202
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Some extra comparison relative to the above comments (and I don't know your setup). I rode in a friend's LT Tundra that's caged and the bypasses were so insanely loud, that was the first vehicle I've been in where I did not appreciate the bypass sounds. Kings with huge tubes, full body with a cage. My tube chassis buggy with ADS bypasses (albeit much smaller tubes) it's 50/50 if the clicking is noticeable but it's not God awfully loud. Point being there's a lot of variables between what you consider acceptable, what shocks, what tube setup, how many tubes, how the bypass is mounted, etc. that play into the house level.
  23. Sep 8, 2023 at 6:51 PM
    #203
    snivilous
    SW UT
    Drive another 2 hours east and get a supercharger and tune while you're near Vegas :D
  24. Sep 8, 2023 at 7:03 PM
    #204
    2TunGet1
    You guys are killing me! I gotta pull the reins in a little! The idea did pop into my head to make a little stop at Dirty Deeds “on the way” to MCM Fab, lol!
  25. Sep 8, 2023 at 9:28 PM
    #205
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    I don’t hear the bypasses with the windows up but they do click at all speeds - even on “flat” pavement. I kinda like the clicking and sometimes lower my window so I can hear the money I spent working. :)
    The clicking is really not bad. My kid has sensory issues to sound and has never said anything about the clicking. ​
    reywcms and 831Tun like this.
  26. Sep 9, 2023 at 6:27 AM
    #206
    Marvthehamster
    Tom
    CO
    2018 CM
    As others have already said, yes they click pretty much constantly. Any movement of the piston that’s strong enough or quick enough to move oil is gonna make the bypass valves operate. It’s most noticeable (for me) when I’m driving in town and with windows down. I think it’s best described as a metallic “clicking” or “clacking” sound. I was a bit worried about it before installing them too, but it’s just become part of the normal sounds of the truck at this point. While in the subject of noisy parts, you should know that the poly bushings in the deaver springs are very likely to squeak. As someone pointed out previously (can’t remember who, perhaps another thread): race truck parts make race truck noises. Modifications come with some potential downsides, depending on your use case.
    As far as I am aware, ADS is the only manufacturer that makes a rear bypass shock that bolts in to the factory mounting locations. It’s really pretty cool to have that kind of bolt on capability.
    Paging @Chad D. About his bypass regrets…
  27. Sep 9, 2023 at 1:38 PM
    #207
    Chad D.
    Chad D. New Member
    Western Oregon
    Chad D. regrets not buying rear bypass shocks…
    I’ll be correcting that in the future.
    reywcms likes this.
  28. Sep 9, 2023 at 4:01 PM
    #208
    2TunGet1
    I guess the question is - cost aside, is there any use/application that the rear 2.5 resi would be better for? General off-road, Overlanding, slow crawling, etc.? Is bypass just better, regardless of what you’re using it for?
    brodesiansneverdie likes this.
  29. Sep 9, 2023 at 5:15 PM
    #209
    Chad D.
    Chad D. New Member
    Western Oregon
    If you will never use more shock travel than the few inches between the 1st compression and the rebound bypass tubes, a smoothie will be the same. As soon as you venture beyond that “ride zone” the bypass will have more benefit.
  30. Sep 14, 2023 at 10:16 AM
    #210
    brodesiansneverdie
    brodesiansneverdie New Member
    2020 White Tundra SR5 CM
    Toytec Aluma 2.5/2.0 SPC UCAs U748s Method 705s Toyo AT3 285/75r17 RCI Aluminum skid OTT tune Softopper Decked V2 Diode Dynamics
    Wrong; the correct answer is "If you live east of the Mississippi River because you'll never be able to drive fast enough to use them"
