Adjusting KING front coil overs for Tundra lean
Discussion in 'Suspension' started by TheBeast, Feb 2, 2018.
  1. Feb 2, 2018 at 5:14 PM
    TheBeast [OP] The Beach
    well that was a PIA....
    had a pretty good lean after I installed my KINGs coilovers. After suspension settled I had 3/4" lower on driver side (stock KINGs from them). roughly 8 threads showing on each side.
    KING instructions says to jack up the car and remove allen screw then use provided tool to lower collar....well it didn't budged at all and the tool even bent...
    Called KINGs and they said on that year Tundra they come pre loaded and you have to remove them from the truck...damnit !
    my mechanic had to remove the front coil over and used a spring compression tool to be able to move the collar down. Added 4 full turns driver side to have 12 threads showing driver and still the 8 passenger side. (5 full turns add 1" per King)
    30 min job ended up being couple hours...
    Now to wait for the suspension to settle and get new alignment...
    on the other hand my buddy's FOX coil overs were done in 20 min...
    Watt maker, Filthy13, joonbug and 3 others like this.
  2. Feb 2, 2018 at 5:18 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I heard about that. Thanks for sharing and let me know if 4 turns was perfect? So @dcsleeper408 knows how to set my kings before installing them. :D
  3. Feb 2, 2018 at 5:19 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    My toytec/radflo can be adj on the truck.
    zcarpenter92, rons23 and dcsleeper408 like this.
  4. Feb 2, 2018 at 5:20 PM
    LOL...however I have the small tank so your adjustments might be different ;)
    Also after alignment it might go up a bit when camber is adjusted.
    PM me if you have any questions.
    dcsleeper408 and BlueBottle like this.
  5. Feb 2, 2018 at 5:20 PM
    yep, same as my buddy's FOX.
  6. Feb 2, 2018 at 5:21 PM
    I will say if you can get them adjusted before installing even better.
    downsports and filthy motorsports do it for you I believe.
  7. Feb 2, 2018 at 5:21 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Damn #bigtankproblems :D
  8. Feb 2, 2018 at 5:23 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    One of you guys needs to get me a job paying your level of income :pout:
  9. Feb 2, 2018 at 5:24 PM
    my mechanic was very cool and only charged me his original estimate. Charged me one hour for a 4 hours job...
  10. Feb 2, 2018 at 5:26 PM
    also there is a fine medium where you want to correct the lean but don't add too much pre load or else the ride will suck.
    from what I found online 12 to 13 threads driver side is fine but I wouldn't go higher.
  11. Feb 2, 2018 at 5:30 PM
    Damn, I would be pissed if I couldn’t adjust my Kings on the vehicle. My problem is not being able to get a jack high enough to stretch out those 14” COs.
    First world problems I guess.
  12. Feb 2, 2018 at 5:34 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    There’s a lot in the Bay Area! @joonbug said you can stay in his garage until you get up to running speed!
    Yup. I only put about .5 cm more preload for this reason.
  13. Feb 2, 2018 at 5:37 PM
    Vizsla
    Vizsla 2 = 2.5
    To late, I adjust mine on the truck easy as pie. At ride height put these on your coils, and give a few turns. Cut up old jeans to pad fingers where they touch coils.
    Jack up truck by frame so it droops out, adjust. You need the right tool, it is awkward due to the upper control arm, but very doable. This is what I use for Fox. Behold the beauty forged in fire...
  14. Feb 2, 2018 at 5:49 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    That's a good problem to have.
  15. Feb 2, 2018 at 5:59 PM
    I use this if not lost. I’m liking @Vizsla design. Might be a tad cheaper as well.
    boostedtrdpro and TheBeast[OP] like this.
  16. Feb 2, 2018 at 6:00 PM
    @Vizsla the KING tool broke inside the collar...pos tool..probably not heat treated
    are you running fox or Kings ? fox were super easy on my buddy Rock Warrior (same mechanic too)
  17. Feb 2, 2018 at 6:02 PM
    when we called KING they said spring compression tool mandatory on Tundra but Tacoma no need, it can be done on the truck....my luck..I guess..
  18. Feb 2, 2018 at 6:07 PM
    Those tools are not for wrenching on a lot I guess. I lube mine up the night before, and on my shocks you have 0-1” preload and on the rear, 1-3” preload.
    TheBeast[QUOTED][OP] likes this.
  19. Feb 2, 2018 at 6:08 PM
    well lesson learned, hope it helps other members.
    ColoradoTJ likes this.
  20. Feb 2, 2018 at 6:09 PM
    So what shock of Kings does this happen on? Factory replacement or the 1-3” lift?
  21. Feb 2, 2018 at 6:11 PM
    Otaku4life69
    Otaku4life69 Welcome to the Dark Side.
    David
    Bay Area CA
    2017 Black SR5 CM
    Pro Comp 7" lift, King Shocks. Moto Metal 961's, 37" Pro Comp Xtreme MT2's, Custom Leather seats, Corsa Exhaust
    On my custom length Kings from Filthy Motorsports everything was spot on with the measurements I provided. I still need to test them off road.
    TheBeast[OP] likes this.
  22. Feb 2, 2018 at 6:12 PM
    OEM fit. they come pre loaded already with 2.05" built in on each side...KING not aware of Tundra lean...
  23. Feb 2, 2018 at 6:14 PM
    yep. should have done that. or go with downsouth motorsports
  24. Feb 2, 2018 at 6:20 PM
    Otaku4life69
    David
    Bay Area CA
    2017 Black SR5 CM
    Filthy Motorsports was great to deal with. There video on King shocks on YouTube is about an hour and a half and he explains all you need to know. They really want you to get the exact shock for how you are planning to use them. I highly recommend them.
    1UPPER, ColoradoTJ and TheBeast[OP] like this.
  25. Feb 2, 2018 at 6:26 PM
    Vizsla
    Vizsla 2 = 2.5
    I run Fox, but they are supposed to come off to adjust now as well. F that. Believe it has something to do with both running the single split ring. It’s no secret, that is how you adjust them. Normally I would not recommend something outside the box, but literally, snug them up, jack up, little lube, and it’s super easy.
  26. Feb 2, 2018 at 7:11 PM
    That is who I deal with directly, for King stuff.
    I may be putting on some 2.5” RR on my tow rig. Since going to 20’s, the craptastic rancho Shocks that cone factory really show just how craptastic they are.
    Otaku4life69[QUOTED] likes this.
  27. Feb 2, 2018 at 7:36 PM
    n2deep
    n2deep Pavement Princess
    I have adjusted my Kings a few times on the truck without any issues and 700lb springs.
  28. Feb 2, 2018 at 7:40 PM
    damn..lucky you. It wouldn't budge at all for us hence why we called KING which is around the corner.
    was that up or down when you adjusted it ?
    btw, how many threads extra on driver side for you to correct that lean ?
  29. Feb 2, 2018 at 7:43 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Did the truck come with 20’s, or did you add em?
  30. Feb 2, 2018 at 7:55 PM
    Well they came with 18’s, which I really like. Then I are a big bowl of dumbass the other day on a rather steep hill on ice. I was creeping forward from a stop and the truck just took off out of control. I should have just let go of the steering wheel or jumped out and said “Jesus take the wheel” and it probably would have been a better outcome.
    Anyway, I broke one wheel from hitting the curb hard and bent the other one. So I needed some wheels or wheels and tires. After the performance on ice with the Michelin AT2’s, I went with tires and wheels from a 2017 Denali. I did see some 18’s from a midnight edition Chevy 2500, but they didn’t want to separate the duratrac tires.
    Before
    After
    I had to remember to not run as much pressure in them as the 18s. When I was up at Sean’s house at the moving party, there was 75 psi in the rear tires. Way to much for those light loads. I dropped back down to 55 psi in the tears and it rides a hell of a lot better, even towing.
    That was an 1100.00 oops
