Adding USB ports or Wireless Charging
Discussion in '2.5 Gen Tundras (2014-2021)' started by gdiep, Jan 13, 2020.
  1. Jan 13, 2020 at 8:30 AM
    gdiep
    gdiep [OP] I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Those of you that have added USB ports or the Wireless Charging, it looks like you guys tapped into an existing source like a cigarette lighter port. Do you also put in a fuse in line with whatever you are putting in and if so, what size fuse?
  2. Jan 14, 2020 at 11:10 AM
    gdiep
    Syracuse, New York
    So I am asking a dumb question? Does anyone add an inline fuse when they tap into the cigarette lighter for an additional usb port or when they add the wireless charging mod?
  3. Jan 14, 2020 at 11:24 AM
    prerunnerseth
    prerunnerseth New Member
    Apex, NC
    2015 MGM Limited 4x4
    Most people are going with the SE toyota wireless charger these days and it comes with a plug and play adapter with an inline fuse.
  4. Jan 14, 2020 at 11:42 AM
    Rlynch356
    Rlynch356 New Member
    Apex NC
    2019 Tundra TRD Pro
    jwc72 likes this.
  5. Jan 18, 2020 at 7:50 AM
    Predator Tundra
    Predator Tundra New Member
    Fallon, NV
    2020 Platinum
    Wireless charger has an in-line fuse in the harness. I’m replacing my rear 12v with the oem dual usb here shortly and well... it has the factory fuse? I used blue sea dual usbs on a few other vehicles and never added a fuse. Didn’t see the point. Never an issue
  6. Jan 18, 2020 at 8:08 AM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    I have usb type c for mine because of work equipment. Those lighter sockets are fused already. I am going to add always on battery one that does not turn off with the ignition though and since its new wiring it will get its own fuse.
  7. Feb 16, 2021 at 4:21 PM
    I did.
  8. Feb 17, 2021 at 5:19 AM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
