SE Toyota center console wireless charger.
Discussion in '2.5 Gen Tundras (2014-2021)' started by prerunnerseth, Nov 19, 2019.
  1. Dec 7, 2019 at 11:10 AM
    #241
    rcjh0891
    rcjh0891 New Member
    Joel
    DFW
    2018 Tundra Platinum Crewmax 4x4 MGM
    Go watch new video by Robmotive of him talking about it
    619Tundra likes this.
  2. Dec 7, 2019 at 11:33 AM
    #242
    MGMTundra251
    MGMTundra251 New Member
    2020 Platinum 4x4 MGM
    It’s worth every penny! You can buy a fast charger for $50 but it won’t look as good. This thing looks like it belongs on the center console. I agree that it should be installed by Toyota on higher trim.
    YotaMan and shellshock like this.
  3. Dec 7, 2019 at 12:07 PM
    #243
    Neutron
    Neutron Parrothead
    James
    New Bern, NC
    2020 Tundra Limited CM Smoked Mesquite
    S&B intake, Corsa exhaust, TRD rear sway bar, Spec-D tail lights, wireless center console charger.
    Its probably the only real practical and worth while thing SET put out
    shellshock likes this.
  4. Dec 7, 2019 at 1:56 PM
    #244
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    The wife ordered one for me for XMAS.
  5. Dec 7, 2019 at 1:58 PM
    #245
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    Ordered.
  6. Dec 7, 2019 at 2:49 PM
    #246
    Neutron
    Neutron Parrothead
    James
    New Bern, NC
    I ordered one from work. Its on backorder but 54 are in transit. Should be in next week.
    My cost was only 135 bucks
  7. Dec 7, 2019 at 3:07 PM
    #247
    MazingarZ4x4
    MazingarZ4x4 New Member
    WA
    2024 1794 Edition
    What? How u get em for cheap? U have connection?
  8. Dec 8, 2019 at 5:59 AM
    #248
    Neutron
    Neutron Parrothead
    James
    New Bern, NC
    I am a tech at a dealer i get stuff for cost
  9. Dec 8, 2019 at 4:14 PM
    #249
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    I ordered one from my local Toyota dealer, mine will be $138 if it ever comes in. I get a discount from being in the Landcruiser Club.
    Ely010606 and Flyinryank like this.
  10. Dec 9, 2019 at 11:27 AM
    #250
    Rlynch356
    Rlynch356 New Member
    Apex NC
    2019 Tundra TRD Pro
    That was easy to install and works great. Also added a blue sea 4.8 amp dual usb outlet to the rear instead of the 12v plug.
    yoshi82, Ostrich, Voyagermike and 4 others like this.
  11. Dec 9, 2019 at 11:30 AM
    #251
    bmann7
    bmann7 Silver Sky Platinum Pro
    WA
    2019 SSM Tundra Crewmax Platinum
    See signature line
    Great call - how did you make the wire connections to do that? I'd like to do the same when I do my installation!
  12. Dec 9, 2019 at 11:45 AM
    #252
    Rlynch356
    Apex NC
    2019 Tundra TRD Pro
    you can release the spade connectors from the white plug (12v connector supplied with the wireless kit, do not cut your existing one) they are clipped into, and just cut off the + and crimp on a shielded spade connector (the stock connector is smaller, the Neg can be reused as is. For the Blue sea plug you need to slightly enlarge the hole, i used a step bit from the backside, it just needs a little is all, no need to go crazy.
  13. Dec 9, 2019 at 11:55 AM
    #253
    mr_clark
    mr_clark New Member
    2018 Black Tundra Limited
    Those teasers at Sparks Parts!! Most recent email subject is -
    Your order has been shipped!
    Was so great to read that. Then there's an email from 3 minutes before -
    Order ETA - Order #XXXXX
    Message says no idea when the unit will ship. Sigh.
  14. Dec 9, 2019 at 11:59 AM
    #254
    TransNone13
    TransNone13 New Member
    Mines in too, worked out great! Fast Charging capable (10W) on a Samsung Note 9. I believe it is Qi wireless charging certified.
    yoshi82, LyonKing and 619Tundra like this.
  15. Dec 9, 2019 at 12:01 PM
    #255
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Cant wait for mine to come in. I ordered on the 29th.
  16. Dec 9, 2019 at 12:08 PM
    #256
    TransNone13
    For what it's worth, I ordered from Spark Parts which was on back order. Kept checking in on eBay and scored one in stock, then cancelled my previous order. More might pop up...
  17. Dec 9, 2019 at 2:09 PM
    #257
    JPritch
    JPritch New Member
    Josh
    17 TSS Crewmax
    Question, I'm already tapping into the rear cigarette lighter with SE Toyota's rear-seat USB port. Would there be any issues with tapping into it again for this charger? I'd love to get this if I can.
  18. Dec 9, 2019 at 2:19 PM
    #258
    TDS65
    TDS65 New Member
    Alabama
    2018 Silver Sky Crewmax Limited
    mr_clark, you mind saying when you placed your order?
  19. Dec 9, 2019 at 2:21 PM
    #259
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Yeah you're good. That's what I did
    JPritch[QUOTED] likes this.
  20. Dec 9, 2019 at 2:22 PM
    #260
    prerunnerseth
    prerunnerseth [OP] New Member
    Apex, NC
    2015 MGM Limited 4x4
    Shouldnt be a problem. Neither uses a lot of power
  21. Dec 9, 2019 at 4:04 PM
    #261
    mr_clark
    mr_clark New Member
    On Friday the 6th. So not long ago.
  22. Dec 9, 2019 at 4:20 PM
    #262
    Rlynch356
    Apex NC
    2019 Tundra TRD Pro
    should not be a problem, but mind the amps at max load, the blue sea pulls 4.8, the wireless is probably 4-5 (has. A 10 amp fuse as well) really only an issue if your booking other stuff to the circuit
  23. Dec 9, 2019 at 5:08 PM
    #263
    TransNone13
    The charger is 10w, ie it will NOT pull more than an amp. 10 = 12x where x is the current pulled by the charger given a 12v system.
  24. Dec 9, 2019 at 5:38 PM
    #264
    Cblowery21
    Cblowery21 New Member
    H-Town
    2018 1794 4x4
    Forum discount code you say?:monocle:
  25. Dec 9, 2019 at 5:45 PM
    #265
    Rlynch356
    Apex NC
    2019 Tundra TRD Pro
    FWIW... we are talking about total load on a circuit, the blue sea is rated at 4.8 amps, the wireless charger maybe at 1 amp... so call it 5.8 amps .. I did say whatever else you are putting on the circuit (and I believe it wires to the dash ones as well, but cannot confirm that at this point bc I don’t have a circuit diagram)...
    so you still need to pay attention to the total load, not just the wireless charger (which it’s total usage listed is 10w, on a separate 3 amp fuse)
    watts / volts = amps
  26. Dec 9, 2019 at 10:09 PM
    #266
    rmvcard0303
    rmvcard0303 New Member
    Ray
    San Gabriel Valley, CA
    2019 White Tundra TRD Sport CM
    I’d rather not list. My wife might see it.
    Order was placed 11/25 and still waiting. I called Sparks today and said they are back ordered by 450 units. He added that they are only “alloted 1 order per day”. He says my order is one of the older ones so it should ship before end of the year. He adds that it’ll take a while for them to catch up.
  27. Dec 9, 2019 at 10:44 PM
    #267
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    :eek:
    Glad I got mine early!
    rmvcard0303[QUOTED] likes this.
  28. Dec 10, 2019 at 7:17 AM
    #268
    TransNone13
    Whoa, that's insane!
  29. Dec 10, 2019 at 7:31 AM
    #269
    prerunnerseth
    Apex, NC
    Guess I started something with this post.
    g6t9ed, Pudge, rmvcard0303 and 2 others like this.
  30. Dec 10, 2019 at 8:13 AM
    #270
    Green Thunder
    Green Thunder Smooth in the Cruise
    Washington
    2020 Burnt Green TRD Pro
    Food crumbs and dog fur
    Mine shipped on the 4th (not the 20th as in the pic). But it's still going to have seen more of the US than I have by the time it arrives tomorrow..
