Adding trans cooler
Discussion in '2nd Gen Tundras (2007-2013)' started by NewRider, Dec 1, 2016.
  1. Dec 1, 2016 at 10:09 AM
    NewRider
    NewRider [OP] New Member
    Travis
    Roaming the Shenandoah's
    2014 Tundra Limited Crew cab w/Flatbed
    Flatbed
    I'm currently in the market for a tundra. The truck will be used as an every day driver and occasionally to tow various things (eventually a Tacoma trail toy) so I'd like to get the teams cooler.
    I've found an sr5 at a great price but as far as I understand that doesn't come stock with the cooler, only the Off Road model does. 1. Is this right? 2. Has anyone looked into adding the cooler on to an sr5 model? I'd assume they use the same transmission so the connections should be there and just be plugged in my mind..??
  2. Dec 1, 2016 at 10:13 AM
    TheBeast The Beach
    does it have the towing package ?
    NewImprovedRon likes this.
  3. Dec 1, 2016 at 4:03 PM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    The cooler comes with Tundras that have the tow package and I think it is integrated into the radiator. You should investigate further because I believe it is not as easy as just hooking up two lines to the tranny.
  4. Dec 1, 2016 at 4:37 PM
    NewRider
    Travis
    Flatbed
    I know a trans cooler is a separate cooler from the radiator. That's why I was guessing it's just be a matter of adding lines and the cooler. I ask because on tacomas the Off Road package has a "tow package" it it only really includes the 7pin connector, it doesn't have the cooler
  5. Dec 2, 2016 at 5:36 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    My 2008 SR5 has the tow package and showed up with discrete transmission and power steering coolers mounted on the passenger side.
    NewRider[OP] likes this.
  6. Dec 4, 2016 at 8:01 AM
    NewRider
    Travis
    Flatbed
    Good to know! That I can look for now that I have an idea of where
  7. Dec 4, 2016 at 6:25 PM
    computeruser6
    Dirk
    Escondido
    This is what my coolers look like.
  8. Aug 31, 2017 at 8:13 PM
    SHIfTHEAD
    SHIfTHEAD New Member
    Nate
    Fort Mill SC
    08 Crewmax Limited 4wd
    That subject line gave me a whole different image in my head...
