Adding tow/haul switch to 4.6 SR
Discussion in '2.5 Gen Tundras (2014-2021)' started by danny1911, Apr 27, 2016.
  1. Apr 27, 2016 at 5:08 AM
    danny1911
    danny1911 [OP] New Member
    NH
    2016 black tundra SR DC
    Does anyone now if you can add a tow/haul switch to the 2016 4.6 SR. I know that the tundras are prewired for brake control and is plug and play for factory control. So was wondering if truck is prewired for tow/haul?
    Thank,
    SiberianTundra likes this.
  2. Apr 27, 2016 at 7:38 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    I believe he is asking if his truck is prewired for the Tow/Haul button. I do not believe so.
  3. Apr 27, 2016 at 8:06 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    If it doesn't have the Tow Package, then I'd be surprised if it were pre-wired. If it has the Tow Package, I would suspect that it would already have a Tow/Haul button. The Tow Package Tow/Haul function changes how the the transmission shifts and the throttle tip in. As the engine and transmission are computer controlled, I would guess that the trucks with/without the Tow Package have differently software programmed to the ECUs. Then there's your final drive ratio....
    JohnLakeman likes this.
  4. May 14, 2016 at 2:00 PM
    Midwest_Medic
    Midwest_Medic New Member
    2015 Tundra SR 4.6 Double Cab
    Only way to tell would be to get behind where it goes and see if wires are there, there is a good possibility that it is prewired for the break controller, I know in the bumper plug there is just a place holder cap and behind it the wires are there for towing so you just need the $45 adapter there that fits in the slot. The fog lights are pre wired on trucks that dont have them the SR versions.
  5. May 15, 2016 at 8:08 PM
    kev8537
    kev8537 New Member
    Lewisville tx
    2016 red tundra 4.6
    Tow hitch, brake controller, trailer hitch connector
    It is pre-wired for the brake controller behind the panel on the right under the steering wheel.
    NewImprovedRon likes this.
  6. Mar 14, 2018 at 5:55 PM
    FrozenTundra
    FrozenTundra New Member
    Did any one confirm if its prewired for tow haul?
  7. Aug 24, 2018 at 10:45 PM
    Wirenut
    Wirenut New Member
    Charles
    2018 Toyota Tundra 4.6L
    I’m wondering the same on a 4.6L 2018 SR5 Tundra...no tow/haul button
  8. Mar 15, 2019 at 6:58 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    So how do we add one? I have A small trailer and was able to plug everything in and the lights work. But don’t have a tow button so had to be making sure my RPMs weren’t going over 2,000. How do we add this tow button feature?
  9. Apr 22, 2019 at 2:10 PM
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    2018 Crewmax SR5, I have a tow hitch with trailer plugs. How ever no brake controller or tow/haul button. Checked and all the wires are there. How to add Tow/ Haul button?
  10. Apr 22, 2019 at 2:16 PM
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    You just have to put it in manual mode to keep it in the proper gear for the proper rpms. Brake controller can be added. I did so on my 2019 SR5 crewmax 4.6L
  11. Apr 22, 2019 at 6:22 PM
    SiberianTundra
    Greg
    War Machine
    What are proper rpms? Like I towed boats before with my suv didn’t care about rpm
  12. Apr 22, 2019 at 6:27 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    I was always told around 2,000 anything over 2,500-3,000 is not good you could over -Tun the engine?
  13. Apr 22, 2019 at 6:49 PM
    salmonator
    salmonator New Member
    Tigard, OR
    2019 Tundra SR5 4x4 DC
    You can spin it a (lot) bit higher than 3k when you need to. The 4.6 doesn’t have a iot of Bottom end torque, you gotta let it rev and drink fuel.
    You will do more damage if you try to keep the rpm’s down and let the transmission shift back and forth. Just put it in S4 and drive it.
    If it’s trying to upshift/downshift a lot pulling up a grade, just shift down to keep it in the gear it needs to pull.
  14. Apr 22, 2019 at 7:12 PM
    Ckeller1963
    Ckeller1963 New Member
    2012 Tundra TRD 5.7
    I have been searching for almost a year if anyone has added a tow haul switch. Found nothing and finally took the chance. I bought a switch from dealer and found pre wired plug. Plugged it all in and of course it didn’t do anything. By the way mine is a 2012 with 5.7 that didn’t come with a tow package from factory. Found that out after I bought it last year. So if anyone has any idea how to get the truck to see the new switch that would be really helpful.
    KELZ84 likes this.
  15. Apr 22, 2019 at 7:14 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    Your the 2nd person i hear of to take the plunge to purchase the tow/hitch switch and it not work. Idk why they would have that switch available where it should go and it doesn’t work at all. That baffles me.
    Ckeller1963[QUOTED] likes this.
  16. Apr 22, 2019 at 7:23 PM
    Ckeller1963
    2012 Tundra TRD 5.7
    I even asked one of the techs at the dealership today when I picked it up. He looked at me like why wouldn’t it work. I could tell he kinda thought it was dumb for me to even ask. I have to admit I was pretty confident after asking him. That went away fast. I’m going to try and go in tomorrow and see if any other techs have a idea. If not I will watch these and hope someone finds something some day I guess.
  17. Apr 22, 2019 at 7:24 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    Yes let us know!
  18. Apr 22, 2019 at 7:27 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Any chance there might be a relay/fuse that needs to be added along with the switch?
    Just a thought...
  19. Apr 22, 2019 at 7:31 PM
    TundraTSS19
    San Antonio, TX
    I'm pretty sure it's more than just is taking a switch and relay. There is probably PCM software involved as well.
  20. Apr 22, 2019 at 7:31 PM
    Ckeller1963
    2012 Tundra TRD 5.7
    That was the last hope I had. I just went and pulled every fuse I could find that had anything to do with tow. Everything looked find. The only thing I couldn’t confirm is if one of the blanks on mine is where it would go if it came factory. So I have been trying to find other fuse box layouts to see if they look anyway different then mine. Have not found much luck confirming that yet tho.
  21. Apr 22, 2019 at 7:34 PM
    Squatting Pigeon
    Holden
    North Texas
    Well, damn. :notsure:
    If it was simple there would be 30 write ups for it on this forum by now. Haha
  22. Apr 22, 2019 at 7:40 PM
    Ckeller1963
    2012 Tundra TRD 5.7
    Yeah I have a feeling it’s going to take some very expensive programming.
    Squatting Pigeon I think your right on the amount of write ups. That should of been my red flag for sure. Thanks for the ideas guys.
    GODZILLA and Squatting Pigeon like this.
  23. May 8, 2019 at 8:25 AM
    MRQZTNDR93
    MRQZTNDR93 New Member
    San Diego CA
    2022 TUNDRA SR5 TRD OFF ROAD
    hello i have a 16 4.6 SR5
    I bought the tow hual switch from the dealer to see if it did something to the prewire connector here and nothing happen
    i tried :(:(:(
  24. May 8, 2019 at 10:16 AM
    TundraTSS19
    San Antonio, TX
    If you had read the entire post it could have saved you time and money to realize this has already been attempted with the same results twice.
  25. May 8, 2019 at 10:27 AM
    MRQZTNDR93
    San Diego CA
    just seen this post for it no worries i returned the switch lol
  26. May 8, 2019 at 10:29 AM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    Well thanks for trying lol I’m another thread someone said it was for parking sensors ‍♀️
  27. May 8, 2019 at 11:07 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    I started reading this thread myself, and read enough to know that this would to be like adding an "Easy Button". :D
  28. May 8, 2019 at 1:14 PM
    MRQZTNDR93
    San Diego CA
    so extra wires for nothing lol at least ill add the trailer brake
    KELZ84 likes this.
  29. May 8, 2019 at 3:55 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    TrooperDC4x4 and MRQZTNDR93 like this.
  30. May 10, 2019 at 8:51 AM
    MRQZTNDR93
    San Diego CA
    thats my next move im just trying to decided whether to do a Bluetooth or just the regular one
