Adding Sub and Amp to an Non-JBL system??
Discussion in 'Audio & Video' started by offshore2005, Jan 4, 2019.
  1. Jan 4, 2019 at 8:10 AM
    offshore2005
    offshore2005 [OP] New Member
    TEXAS
    2022 Tundra Limited 4x4 RC leveling kit and 295/65/20 Cooper STT PROs
    My wife got me an Amp and 10” subwoofer for Christmas and I am getting ready to toss it in.. I have ordered the Toyota Tundra Add A Subwoofer Plug and Play Harness from taco tunes. Just wondering if anyone has done this yet, I am not the best with auto install.
    From what I understand you still keep your stock amp under the passenger seat and the harness plugs into it and your new amp.
    https://*********.com/shop/toyota-t...nd-play-harness-2014-2020-non-jbl-equipped-2/
    Harness I ordered..
    Thanks!
  2. Jan 4, 2019 at 5:23 PM
    Straight6NC
    Straight6NC New Member
    2015 Tundra X-SPS DC
    Speaking from experience, the stock head will be the downfall of the system even after adding an amp and sub. I battled for months trying to make it sound right until I changed the head unit and finally got it to sound right.
    Mnorris1206 likes this.
  3. Jan 4, 2019 at 5:26 PM
    offshore2005
    TEXAS
    That’s what I was afraid of... I have changed the dash speakers out so the door speakers will be next. I really don’t want to changed the head unit so I hope I can live with the way it turns out.
  4. Jan 4, 2019 at 5:28 PM
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 CM TRD SPORT 4x4
    2018 Trd Sport
  5. Jan 4, 2019 at 5:31 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    Is it a Taco Tunes amp? You will not keep the factory amp. Did she get you a shallow box sub? If not it will not fit behind the seat. After months of thinking about it I went with Tac Tunes amp. With the others you will need a LOC. Line out converter. Big improvement in sound with the Taco Tunes amp and Rockford sub. You will also need an amp wiring kit. Not sure what harness you got from Taco Tunes. Is it just for sub? You will also need to upgrade door speakers. I went with Infonity Kappas. Just did fronts for now. I never have passengers. In fact my rear seats are always up.
    ND90 likes this.
  6. Jan 4, 2019 at 6:26 PM
    offshore2005
    TEXAS
    Yes she bought me a sub and amp kit. The box will fit behind the seat of the crew max. It’s not from taco tunes. Just my plug and play harness is for adding an amp.
    Do you have links to the door speakers you put in?
  7. Jan 4, 2019 at 6:26 PM
    styx
    styx New Member
    Larry
    Knoxville, TN
    2017 SR5 DC TRD Offroad Magnetic Grey
    Raptor OEM Nerf Bars Leer Hard Tonnaeu Weathertech Vents Driver assist handle
    I have read several posts on this forum condemning the factory HU. I have worked with 4 of them in detail ......in a '17 Rav4, 2 T4R's... one of which is an '18 companion-ed with my '17 Tundra. Now I'm not talking about the bells and whistles like bluetooth and some of the other apps. I don't use this stuff and cannot comment on how good or bad they are. But for music from XM, USB, CD and FM I have found the factory HU to be quite good. Now the speakers and factory amp is another story. These 4 HU's produced a clean full spectrum signal but were low in power hence the need for an amp and good speakers that would handle the amps power.
    The upgrades I did were using 5 channel amps which require a bit more care in matching up the system as a whole. You are talking about just adding a sub and amp using the ********* harness made for that purpose. I believe you will be just fine adding the sub to your factory system and will be pleased with the results. You will need a line out converter unless the amp you use has high level inputs.
    Be warned though, you will get the bug to upgrade to a 5 channel amp and better speakers before long!
  8. Jan 4, 2019 at 6:31 PM
    offshore2005
    TEXAS
    What is this “line out converter” you speak of? And what does it do.... thanks.
  9. Jan 4, 2019 at 6:38 PM
    GNTundra
    Gino
    2013 White
  10. Jan 4, 2019 at 6:39 PM
    styx
    styx New Member
    Larry
    Knoxville, TN
    It will take the signal off the lines provided by the harness and give you a low level input for your amp via RCA connectors. Not expensive......$10 - $12. I have a few other posts on this audio/video page if you want to look them up.
  11. Jan 5, 2019 at 4:00 AM
    Straight6NC
    It will all depend on what you consider good sound quality. If you're an audio audiophile, you will want more. Adding the amp and speakers will definitely improve the sound quality and volume, but in the end, a head unit upgrade will liven things up. My DC did not come with JBL or NAV, so the head unit upgrade was a win win for me as I got NAV, DVD and the lines that show wheel positions when reversing.
    If you're interested in a Line Out Converter, I have an Audio Control LC7i I'm willing to let go for a good price.
    offshore2005[OP] likes this.
  12. Jan 5, 2019 at 6:01 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    No link but got them onCrutchfield. Infinfinty Kappa 60 6.5s components. Came with wire and door adapters. If you have a Taco Tunes amp you wont need a LOC. This is why I went with Taco Tunes. You will need their amp harness.
  13. Jan 5, 2019 at 6:06 AM
    offshore2005
    TEXAS
    Thanks!
    I don't have the amp from Taco Tunes but I have the add and amp harness from them.
  14. Jan 5, 2019 at 6:13 AM
    Mnorris1206
    08 tundra
    So true after just installing a after market head unit my trucks sound from just the stock speakers has so much more punch .I dont have any amp at all.
  15. Jan 5, 2019 at 12:06 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Then you will probably need a LOC
  16. Jan 21, 2019 at 8:53 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Here are pics of the sub box, amplifier and LC2i audio controller.
    timdske, RICHIEUSMC, GarTX526 and 3 others like this.
  17. Mar 31, 2020 at 7:38 PM
    andresanez1
    andresanez1 New Member
    If you don’t mind me asking what wires did you splice from the factory amp to the lc2i
    RICHIEUSMC likes this.
  18. Oct 14, 2020 at 6:08 PM
    RICHIEUSMC
    RICHIEUSMC New Member
    Spring Hill Florida
    2020 Tundra SR5 Double Cab 4x4
    How much would it cost to have someone do the sub n amp install ?
  19. Oct 14, 2020 at 6:26 PM
    Call 5 Star Car Stereo in Clearwater. :thumbsup:
    RICHIEUSMC[QUOTED] likes this.
  20. Dec 31, 2020 at 5:55 PM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2016 Pro MGM CM
    Toyo MT 285/70/R18, led's all around, Baja Design squadron sport fogs, spider trax 1.5 spacers, led foot well lighting, interior chrome delete, kc hilites 40inch light bar grill mounted, 20%tint all around, color lugs black lugnut caps, 2019 pro head lights, led lights all around, spyder co tail lights, DMX1057xr, super crew box with kicker 10” sub,jbl door speakers, factory amp bypass trd air flow accelerator with drop in filter, x3 battery, Toyota bed cover, swing case,
    How did this work out? I’m thinking of buying the harness.
  21. Jan 5, 2021 at 9:10 AM
    Tundra@21
    Tundra@21 New Member
    Percy
    2021 Cement Gray Tundra TRD OffRoad CM
    AFE Air Intake, TRD Exhuast System
    following this as i have a none jbl HU and i am adding a aftermarket amp and sub with the lc2i and the add an amp wire harness from *********..
    MichelleRae4x4 likes this.
  22. Jan 5, 2021 at 4:36 PM
    JcGc
    JcGc New Member
    2020 Crewmax 4x4
    4/2 Ready lift Kenda Klever 35 x 12.50 x 20 XF Off road wheels
