Adding Overhead Console From 2nd Gen
Discussion in '2.5 Gen Tundras (2014-2021)' started by WFD473, Feb 6, 2021.
  1. Nov 4, 2021 at 12:55 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    What year is your DC?
    thanks for the response!!
  2. Nov 4, 2021 at 2:44 PM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    2014 Tundra DoubleCab SR
  3. Nov 4, 2021 at 3:13 PM
    WFD473
    WFD473 [OP] Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    I'm fairly certain they're all the same from 07-21. I did 2 things to make a pretty good guess that it would work.
    1. Press against the headliner in the center moving front to back and feel for a cross-brace. I felt one with mine and it lined up with the mounting point of the bigger console perfectly.
    2. Remove the original console and put your hand between the roof and headliner. If you feel the cross-brace and the location looks right, you're golden.
    If you have any other questions, let me know.
    ToyoD and panicman[QUOTED] like this.
  4. Nov 4, 2021 at 3:15 PM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Great job!!!
  5. Nov 4, 2021 at 4:10 PM
    biebs96
    PA
    Man I loved that larger console when I had my second gen.
    Guess I’m looking for this part now :spending:
    tundras.com strikes again :rofl:
  6. Nov 4, 2021 at 4:16 PM
    biebs96
    PA
    On a serious note.. has anyone installed one of these with the rear lights in a crewmax?
    I am curious how the two lights look in the center of the roof.
  7. Nov 4, 2021 at 6:49 PM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    The plan was to find one with the rear facing lights, but they were all crazy expensive. So I settled on one without them.
  8. Nov 19, 2022 at 11:43 AM
    Mackadocious417
    Mackadocious417 New Member
    09 tundra 4x4 5.7 crewmax
    Fender flares, trd intake and air accelerator, sidesteps
    Thanks for your post. My pass side dome switch was stuck on and i pulled the bulb so it wouldn't drain my battery.... for a permanent fix, I will try n replace my large overhead consoles black switch part inside the large assembly with that part from the small one. I think one of the copper contacts is bad and hope to switch it out.
    WFD473[QUOTED][OP] likes this.
  9. Nov 19, 2022 at 12:42 PM
    Slag_Dynamics
    Slag_Dynamics Cut. Weld. Repeat.
    Arizona
    Gone
    Sweet mod! Thanks for the idea.
    WFD473[OP] likes this.
  10. Mar 17, 2024 at 9:52 PM
    shmabs
    shmabs New Member
    Did anyone find a part number for these? The part number referenced earlier seems to be a screw?
  11. Mar 18, 2024 at 12:14 PM
    BeauDacious
    BeauDacious 040 > all other colors
    Beau
    14 DC 4x
    Darn you folks...
    I had not seen this thread until last night. Now I am already 180 bucks lighter...
    WFD473[OP] and RobertD like this.
  12. Mar 24, 2024 at 1:32 PM
    Fergie
    Fergie New Member
    Picked up an overhead console at the pick n pull yesterday for $20 or so...need to clean it up a bit, but should be fun to install.
  13. Mar 24, 2024 at 1:48 PM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    What was it in?
  14. Mar 24, 2024 at 2:18 PM
    Fergie
    Fergie New Member
    ....a Tundra....
    Leo's first, 300BLK and WFD473[OP] like this.
  15. Mar 24, 2024 at 2:18 PM
    Fergie
    Fergie New Member
    2012 Double Cab SR5
    WFD473[OP] and Occidentalis like this.
  16. Mar 25, 2024 at 5:18 AM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    300BLK likes this.
  17. Mar 25, 2024 at 4:04 PM
    panicman
    Eric
    I have a new one in the box in my garage. It is a different enough color that I am really hesitant to replace my 2018's. I also have kittens thinking about cutting the headliner.
  18. Mar 25, 2024 at 5:35 PM
    Fergie
    Fergie New Member
    Went back out to the pick and pull to grab the two extra screw retainers since I'm off on Mondays....cost me the $2 entry fee and they gave me the two fasteners for free, so, the cost of gas essentially.
    A word of advice....dont accidentally cut the rear light wiring as it will blow the 7.5A fuse in the engine bay....I taped the cut wires up and tucked them away.
    There are three sets of retainers, the middle ones can be removed easily...not the others. Found the screws I needed too, so that was cool.
    This one was snapped before final tightening...and after replacing the fuse...
    I swapped over the old LEDs I had installed, and everything is GTG.
  19. Mar 25, 2024 at 5:52 PM
    #49
    RobertD
    Robert
    DFW, Texas
    :lalala:
    Damn it. I forgot about this. Ugh I really need to do better about calling the local places and trying to get some parts. This would be super handy to have.
  20. Mar 25, 2024 at 7:41 PM
    #50
    Occidentalis
    North Florida
    If you think you don't want to take the dive let me know what you'd need for the part.
  21. Mar 25, 2024 at 9:52 PM
    #51
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    Is the overhead console the same for crewmax and double cab?
  22. Mar 25, 2024 at 10:18 PM
    #52
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    Fergie, do you have a gap behind the rear light? Someone posted earlier that the console is not long enough to cover the rear light area.
  23. Mar 26, 2024 at 4:01 AM
    #53
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    They are essentially the same with the difference being the double cab has the integrated rear facing lights. The Crewmax has a separate dome light, so they don't have lights in that spot.
  24. Mar 26, 2024 at 6:28 AM
    #54
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    If installing this in a 2.5 gen double cab, you need one with the rear light as it will utilize that instead? And am I correct it does not fully cover the hole in the headliner where the original ceiling light was?
  25. Mar 26, 2024 at 6:58 AM
    #55
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    As far as I know, that's the case. I have a CM, so not 100% sure. Maybe the DC owners can chime in.
  26. Mar 26, 2024 at 7:57 AM
    #56
    RobertD
    Robert
    DFW, Texas
    @WFD473 can you take a picture for one of the rear doorways? Curious how this looks with the rest of the space. Also curious how close the rear portion is to the light in the crewmax incase I happened to find one with a light.
  27. Mar 26, 2024 at 8:09 AM
    #57
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Absolutely! I'm out of town right now for spring break and the truck's at home. I'll get that for you on Thursday when we get home.
    RobertD[QUOTED] likes this.
  28. Mar 26, 2024 at 8:18 AM
    #58
    RobertD
    Robert
    DFW, Texas
    No rush. Just at some point, thanks.
  29. Mar 26, 2024 at 8:22 AM
    #59
    JohnWhicker
    JohnWhicker New Member
    Man I love this console and I have it in my 2013. I may just buy a brand new one and add it to my 2021 but I need a professional installer. I am not good at these things :(
    What is the exact part # for this console please?
  30. Mar 26, 2024 at 8:28 AM
    #60
    Fergie
    Fergie New Member
    Yes, there is a slight gap; maybe 1/4" from the end of the console to the leading edge of the headliner. That sort of thing doesnt bother me, but it would for some. I can snap a pic of it when I get home(drove the shitbox beater this AM as it gets 30mpg vs 10mpg).
