Adding Lights to rear bumper
Discussion in 'Lighting' started by Bmedic50, Apr 13, 2017.
  1. Apr 14, 2017 at 6:00 PM
    FlashCulprit
    FlashCulprit ColoradoTJ's whipping boy/Gino's illegitimate son.
    Joe
    Salt Lake City, UT
    2010 Super White SR5 TRD 5.7 4x4
    Correct. This particular relay will do that. The positive just needs to be tapped into the 12v positive connected to the reverse light switch wire.
    I will say. Be weary of doing so when you mount your lights. Make sure they are pointed downward to not blind anyone behind you. Haha
    Cat3ILS likes this.
  2. Apr 14, 2017 at 6:26 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Cat3ILS[QUOTED] and FlashCulprit like this.
  3. Apr 14, 2017 at 6:35 PM
    FlashCulprit
    Joe
    Salt Lake City, UT
    Cat3ILS and BlueBottle[QUOTED] like this.
  4. Apr 14, 2017 at 6:45 PM
    Bmedic50
    Bmedic50 [OP] New Member
    Brandon
    2017 TSS Crewmax
    I researched a bit more, the lights I bought only draw 1 amp total. Since the OEM bed light LEDs draw about the same, I should have no problem tapping into the bed lights without a dedicated power. Additionally, the OEM lights already have a fuse so I think I should be gtg.
    Tomcat likes this.
  5. Apr 14, 2017 at 8:30 PM
    Tomcat
    Tomcat Ever see a motorcycle outside a shrinks office?
    2010 SR5 4X4 5.7 20" wheels Metallic Gray
    Bakflip
    Where are you going to mount the lights? Do you have a backup cam? I need more lights for my backup camera and I'm not sure where to mount them.
  6. Apr 14, 2017 at 9:06 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    Dang Mark, she nuked your junk? No wonder you got divorced!
  7. Apr 14, 2017 at 9:49 PM
    Bmedic50
    Brandon
    2017 TSS Crewmax
    I'm using them for on demand light when I'm camping/ fishing etc. so I bought the flush mounts to place in the bumper. Cut out some holes so it should be fairly clean.
  8. Apr 14, 2017 at 9:58 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    She nuked it alright!
  9. Apr 14, 2017 at 10:08 PM
    Tomcat
    Bakflip
    Do you have a picture of the light placement? I like to fish...
  10. Apr 15, 2017 at 3:34 PM
    Bmedic50
    Brandon
    2017 TSS Crewmax
    I'm about a week out. Bumper end caps are at the Powder Coater right now.
  11. Apr 15, 2017 at 5:52 PM
    Tomcat
    Bakflip
    Thanks buddy.
  12. Apr 15, 2017 at 6:06 PM
    Bmedic50
    Brandon
    2017 TSS Crewmax
    I'll post as soon as I get them in but I basically cut holes in the bumper about 5 inches from the end.
    Cat3ILS likes this.
  13. Apr 15, 2017 at 7:25 PM
    Tomcat
    Bakflip
    Thanks. I will wait for the posts. I have wired lights before but never cut a bumper up. What did you cut it with? I'm thinking drill four holes and cut between them with some type of grinder with a cutting wheel installed.
  14. Apr 16, 2017 at 6:06 AM
    nowayout
    nowayout New Member
    NY
    15 Dbl
  15. Apr 16, 2017 at 7:01 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I also installed the blue sea fuse box. They have various sizes I went with the 12 circuit box. I ran a 4 gauge power wire from my battery terminal to the Blue sea box. The big advantage of the Blue sea is all your additional fuses are in once place and you can do various amp fuses. I then installed the individual relays in the same area on the passenger side engine compartment. This way all my fuses and relays are easily accessible. I also drilled a new hole on the passenger side firewall for a firewall bushing. Then I can run any wires from the relays into the new access point on the passenger side. Personally I wanted to keep my new relays, Blue sea box and wires on the passenger side where there not crossing any of the wiring on the driver side. Once you enter the cab on the passenger side it's very easy to go inside the truck and run the wires to your center console or wherever you want. I've seen several people mount the Blue sea over the stock fuse panel but I liked to keep that area clean and free of additional wires. Here are some pics of my Blue sea, firewall bushing, & my rigid bumpers flush mounts. My rigid flush mounts did recommended a 15amp fuse. I wouldn't tie your rigid lights off of any of the stock lights power. I hope this helps you with your mod. I also used liquid electrical tape to cover all the positive and negative screw terminals on the Blue sea after I finished wiring my lights. IMG_6990.jpg
    Cat3ILS and NewImprovedRon like this.
  16. Apr 16, 2017 at 7:33 AM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    I'm doing this currently with reverse lights. You need to hook up one light and see how much current it draws. Do thr math for both lights, then measure your current on the existing circuit. Then add all the currents together and see if your within the limits of the circuits fuse.... sometimes it's obviously over sometime u cab get away with it
  17. Apr 16, 2017 at 7:35 AM
    nowayout
    nowayout New Member
    NY
    15 Dbl
    @1UPPER nice set up. Do you have any pictures of where you put the firewall bushing on the passenger side?
  18. Apr 16, 2017 at 7:52 AM
    1UPPER
    TEXAS
    Flux capacitor!
    Thank you. Here is a pic showing the placement of the Blue sea, relays and the firewall bashing hole. I still need to clean up some of my wires a bit.
    Cat3ILS and FlashCulprit like this.
  19. Apr 16, 2017 at 9:57 AM
    #49
    Bmedic50
    Brandon
    2017 TSS Crewmax
    Maybe I'm looking at this too simply but I'm essentially adding LEDs with a 1 amp draw. I cannot understand why I would need to add a separate fuse box and relays. The only lights on the circuit I'm tappinng into are the two OEM LEDs in the bed and the light on the top of the rear cab. These are the only lights I'm adding. I don't plan to create a nuclear power grid.
  20. Apr 16, 2017 at 10:01 AM
    #50
    Bmedic50
    Brandon
    2017 TSS Crewmax
    I use the gasket that came with the lights. Taped them in place and measured to ensure they were where I wanted them. Then used a marker to draw on the bumper. Attached a cutting wheel to my dremel and cut out the area for the light. Used a drill for the mounting holes.
  21. Apr 16, 2017 at 1:58 PM
    #51
    FlashCulprit
    Joe
    Salt Lake City, UT
    Longevity and isolation. Toyota didn't think you're going to add additional draw to any existing circuit.
    That's all. The advice we're giving you is to ensure a positive experience based on our own. That's all! What you're suggesting may work! We just don't want to say yes unless someone has tried it. I get where your hesitation comes from. But when it's electricity I like to play it safe.
    :thumbsup:
  22. Apr 16, 2017 at 2:03 PM
    #52
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Yup I'm with @FlashCulprit
    We are trying to give you the best advice but seems like you don't want to listen to it so you do what you feel and if you have any issues, don't say we didn't tell you so. Good luck.
    :boom:
  23. Apr 16, 2017 at 2:48 PM
    #53
    Bmedic50
    Brandon
    2017 TSS Crewmax
    It's not that I don't appreciate the advice. But I was looking for data and specifics. Theories are great but I was hoping to get educated on actual calculation for fuse/wire size based on amp draw.
    I did the research through other avenues and was able to figure out how to calculate it. Eventually I found this simple breakdown.
    https://www.oznium.com/forum/topic15761#___1__
    There are 3 existing lights on the circuit. each pull less than 1 Amp. The new lights also pull one Amp but I'm assuming that's 1 Amp per light. So essentially 5 amps total.
    Based on that, I need to ensure the smallest wire in the circuit is 17 ga and the fuse is 6 amps which doesn't exist so a 7.5 with 16 ga should work.
    BlueBottle likes this.
  24. Apr 16, 2017 at 3:15 PM
    #54
    FlashCulprit
    Joe
    Salt Lake City, UT
    Sounds good man. As I said, we're just detailing out our experiences.
    Make sure you post updates once you're done so we can see your set up.
    Bmedic50[QUOTED][OP] likes this.
  25. Apr 18, 2017 at 5:58 PM
    #55
    Bmedic50
    Brandon
    2017 TSS Crewmax
    Got the bumpers back from powder coat and installed the lights. Wiring will have to wait a day or two.
    Everything went together well but I was disappointed to see the mounting bolts weren't black sick these were the blackout edition of the lights. I'll have to change that out eventually to get the look I'm going for. Other than that, I'm fairly happy at this point. IMG_2904.jpgIMG_2905.jpg
  26. Apr 19, 2017 at 8:02 AM
    #56
    PaRunnerd
    PaRunnerd No N00B, No Pro.
    Dave
    Lehigh Valley, PA
    2014 Magnetic Gray Tundra SR5
    Plenty planned thanks to all of you.
    Brandon, the lights look awesome and the powder coat looks great as well. I've been contemplating whether to go that route or do a swap out but I think you may have swayed me. Do you recall what color of PC they used?
  27. Apr 19, 2017 at 10:13 AM
    #57
    Bmedic50
    Brandon
    2017 TSS Crewmax
    He didn't actually give me a color number. He's just had 3 different options (Black mat, black gloss, and black mat with texture). The last option matched the tube steps so I went with that. Sorry, wish I had more info
    PaRunnerd[QUOTED] likes this.
  28. Apr 19, 2017 at 10:52 AM
    #58
    Tomcat
    Bakflip
    Looks great. Thanks for the follow up.
  29. May 14, 2017 at 5:19 PM
    #59
    Bmedic50
    Brandon
    2017 TSS Crewmax
    Finally got the lights wired today. I spent some extra time researching my options. Finally called rigid industries to see what they recommend. They were extremely helpful and said to ensure I didn't tap into anything less than a 16ga. He also said that if the wire off the bed lights was too small, to simply wire up to the cab and grab power directly off the switch.
    That got me thinking so I looked behind the dash to see how the bed light were wired in. I was blown away when I saw they tapped into a wire the size of that you would see inside a telephone cord. I'm not sure what size it was but def smaller than 16ga. That ruled out that option.
    Last thing the rep said was that if I had a tow package, I could tap into the power and ground behind the trailer plug and utilize the relay option.
    That was what I ended up doing. Worked perfectly and I feel a lot better knowing I'm not pulling from the harness behind the dash.
  30. May 14, 2017 at 5:31 PM
    #60
    1UPPER
    TEXAS
    Flux capacitor!
    Rigid customer service has always been helpful when I've called them. Post some pics when you can.
