Adding Info button switch?
Discussion in '2nd Gen Tundras (2007-2013)' started by LAWNKILLER, Oct 17, 2018.
  1. Oct 17, 2018 at 2:26 PM
    LAWNKILLER
    LAWNKILLER [OP] New Member
    Andy
    KC
    2010 Crew Rock Warrior
    Rica25 and mtndds98 like this.
  2. Oct 17, 2018 at 2:32 PM
    I'd verify if you have the harness hanging behind the blanks first. If so you should be good to go as long as you don't have sonar option.
    Rica25 likes this.
  3. Oct 17, 2018 at 2:42 PM
    LAWNKILLER
    Andy
    KC
    Yes, I have a plug, 8 wires I believe.
    Thank you for the response.
  4. Oct 17, 2018 at 2:58 PM
    LAWNKILLER
    Andy
    KC
    Ok, Thank you for the response.
  5. Oct 24, 2018 at 8:38 AM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    Says it fits 08-13. What makes it different from an 07? I'd like to add these functions too but looks like I'll have to do the MOSFET fix to be cluster first too.
  6. Oct 24, 2018 at 4:21 PM
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
    you should have the plug, but you may still not have all the functions. i can change the temp from Fahrenheit to Celsius now but can't do the dte etc. iirc, there is a mod that has to be done to the cluster on some rigs.
    Rica25 likes this.
  7. Oct 25, 2018 at 10:14 AM
    LAWNKILLER
    Andy
    KC
    I now have Average MPG, instant MPG ( which is depressing to watch) and DTE (Distance To Empty).
    RainMan_PNW, Rica25 and Mountun Goat like this.
  8. Oct 29, 2018 at 10:19 AM
    blackoutt
    Indy
    OEM+
    Sweet! I ordered a switch and will try it as is. I verified by 07 has 8 wires. If it doesn't work I found the thread with details on how to run the extra wires to the cluster.
    Rica25 and LAWNKILLER[OP] like this.
  9. Jan 11, 2020 at 12:51 PM
    DJW
    DJW New Member
    Dennis
    2010 Tundra TRD SR5
    2010 Tundra SR5 TRD. Drive monitor display doesn't work, temperature display only shows Celsius, clock works. Have INFO,SELECT RESET,SETUP and SONAR buttons. SONAR button works Sonar comes on lights up and beeps. The other buttons do nothing. Ordered new 84977-0C090 Drive Monitor Switch replaced it same results as above. Started down the path removing trim pieces and got to the JL1 Connector pins 17 and 19 already have white wire in the 17 and yellow wire in the 19 pin. Now what?
    Rica25 likes this.
  10. Jan 14, 2020 at 5:55 PM
    559WeekendWarrior
    559WeekendWarrior New Member
    Menger
    2010 SR5 5.7L PreFlex Warrior
    Custom Build Tubing 3.5 with 3.7 Trd Intake 2014-2019 with Turbo Head Shield Air Filter, Jet Performance MAF, Throttle Body Spacer With Econoaid Throttle Body Booster Gasket. Exhaust 2.5 Cherry Bomb 7841 single with dual Side frame exit or in front of the rear passenger tire. Pedal Commander plug in play for the gas pedal. Last is leveling kit 3-1 front and rear with 32-33 MT tires.
    I got one no to long ago for mine and the only thing that work is just the temperature only. their are a few different model but that shouldn't be a problem and that thing is brand new. I can only go from °F to °C only. Any reason why it's that only and no mpg or etc are not showing up? It's a SR5 2010 5.7L
    Kiddnapped Tundra likes this.
  11. Oct 29, 2020 at 6:37 PM
    kwjsimpson
    kwjsimpson New Member
    Kansas
    2013 Tundra Crewmax SR5 5.7 V8
    18” Mayhem wheels, remote start
    Did you ever find out what was wrong? I just bought a 2013 SR5 that is having the same issue. Sonar works great, but the other buttons do nothing. I removed the buttons and confirmed they’re good on the meter and all the wiring exists on the plugs at the buttons and under the dash. Singalong confirmed to the next harness, but haven’t tested up to the display yet.
  12. May 17, 2021 at 1:30 PM
    Harold_Z
    Harold_Z New Member
    San Antonio TX
    2012 Tundra Overland Build
    I experienced the same problem, only the temperature gauge works and doesn't have the MPG and other infos.
  13. May 17, 2021 at 2:24 PM
    Guys this is a mod that has been around for years, but on some trucks, there were 2 wires that you have to manually add for everything to work. I had to do it when I had my 2010. I will dig around and see if I can find that info.....its been a while.
    baraynavab likes this.
  14. May 17, 2021 at 3:58 PM
    mtndds98
    mtndds98 New Member
    2013 Silver Tundra CrewMax
    6" ProComp Stage 1 lift
    I would like to know the mod too. Thanks.
  15. May 17, 2021 at 4:15 PM
    kwjsimpson
    Kansas
    In my case it’s not a mod. Everything is there from the factory. All 4 buttons, all wires, and the display has the ability to see temp, mpg, avg, etc., but it only shows the temp and doesn’t cycle through the options as it should.
    Tested out the buttons and the wiring from the buttons to the harness plug under the steering wheel to the next set of wires. Signal is good to that point. What I couldn’t/haven’t taken the time to do is test if the signal is making it to the display or not. Not sure how to access the back of that. Assuming that requires taking the dash all apart? Anyone know?
  16. May 17, 2021 at 9:36 PM
    Harold_Z
    Harold_Z New Member
    San Antonio TX
    Found some videos on YouTube today that explained me, we gotta take the dash off and track the wires to see which part is missing.
  17. Oct 26, 2022 at 5:39 PM
    bvshearz
    bvshearz New Member
    Bob
    I just bought a 2011 SR5 double cab.... I have all 8 wires, nothing worked..can't cycle through anything.....couldn't even change temp from C*. to F*... bought a new monitor switch and does nothing...still won't change temp display. What else should I look at ...any answers
  18. Oct 28, 2022 at 7:53 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    Ok guys you need to do some wire modification on your trucks even if you have the 8 wires or 7 wires. That's is because there are some wires on your odometer that need to be hooked up. It not hard but they need to hook up.
    Let me search the other post that will show you what needs to be done. Hang tight for a sec. I put up a post on it as well.
    Okay here is the link. Follow this..
    https://www.tundras.com/threads/drive-monitor-wiring-mpg.88185/
  19. Oct 28, 2022 at 8:01 AM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    I have an 07 and had the plug with all the wires. The button alone didn't work, and I had to run some wires under the dash to get it working. Now I have all the functions. I followed the thread on that other tundra site (that I have since disavowed)
    but you can get the details here: https://www.tundras.com/threads/drive-monitor-wiring-mpg.88185/
