Adding fuel capacity
Discussion in '2nd Gen Tundras (2007-2013)' started by svmkla, Apr 23, 2017.
  1. Apr 23, 2017 at 5:32 AM
    svmkla
    svmkla [OP] New Member
    Jon
    Tundra SR5 Crewmax
    I've owned my crewmax for 8 months and want to install a larger and/or 2nd fuel tank. What has been anyone's experience with this? What has worked and maybe more importantly, what has not worked?
  2. Apr 23, 2017 at 5:44 AM
    svmkla
    Jon
    Tundra SR5 Crewmax
    Thanks will look
    SouthBoundSteve likes this.
  3. Apr 23, 2017 at 5:51 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    What tank do you currently have?
  4. Apr 23, 2017 at 6:13 AM
    svmkla
    Jon
    Tundra SR5 Crewmax
    I'm told 26 gal. Never ran it dry to test.
  5. Apr 23, 2017 at 7:33 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    That is the tank my truck came with also. I replaced it with the transfer flow tank. The only downside, other than cost, is that there is now 200lb semipermanent payload on the truck. If you have any questions let me know.
  6. Apr 23, 2017 at 10:42 AM
    TheBeast The Beach
  7. Apr 23, 2017 at 3:59 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Don't do this....
    Hasteen, ColoradoTJ and PaRunnerd like this.
  8. Apr 25, 2017 at 5:21 AM
    dino112265
    dino112265 New Member
    Walt
    5.7 v8 2013 Max Cab
    I am thinking about installing the 46 gallon aftermarket fuel tank myself. Does it impact your MPG at all with the extra payload?
    gosolo[QUOTED] likes this.
  9. Apr 25, 2017 at 7:30 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Gasoline weighs around 6-6.5 lbs per gallon (the exact value depends on the composition, temperature, etc.) So at 46 gallon, the total fuel is less than 300 lbs at the most (taking 6.5). Stock tank holds roughly about 170 lbs of fuel. So difference is less than 130 lbs (plus the hardware weight difference). Considering many members carry tools, etc. that weighs far more than 130 lbs, I would think the difference in mpg is very small.
  10. Apr 25, 2017 at 9:04 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Short answer is yes, but I'm not sure how much the tank is responsible for.
    With the Snugtop, sliders, winch & mount, fuel tank, Decked Drawers, skids, and tools, I've added in excess of 1K permanent lb's. Mpg is around 14.
  11. Apr 26, 2017 at 4:04 PM
    svmkla
    Jon
    Tundra SR5 Crewmax
    Thanks to all.
  12. Apr 26, 2017 at 6:19 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    You failed to include the weight increase of the steel tank itself, over the little plastic OEM tank. Increase is in excess of 200lb.
    chphilo[QUOTED] likes this.
  13. Apr 27, 2017 at 2:25 AM
    chphilo
    Western PA
    I din't know the specs of the tank. I did mention it though in the parenthesis about the weight of the hardware. Does the steel tank have tendency to rust, just curious. I am interested in this tank (there's a dealer in town), but can't justify it. I fill up the tank only once a month.
  14. Apr 27, 2017 at 5:15 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I got the tank lineXed after it got here and before install. I'm in AZ, so rust is not an issue, but when i move to Oregon i will definitely have to keep an eye on it. Transfer flow sells em with coating as an option, also.
  15. Apr 27, 2017 at 10:03 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Curious -- other than the wasted bed space and manually pumping, what else is wrong with that setup in your opinion?
    ColoradoTJ likes this.
  16. May 11, 2017 at 6:02 PM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    Don't have to manually pump. Just hook up a switch value to drain the bed tank into the factory tank and keep driving. Bed tank would be cheaper, easier and can be found in L shaped aluminum that fits behind and under your tool box and only take up 6-8 inches of bed room. I've been looking for a used one.
    zcarpenter92 likes this.
  17. Jun 8, 2017 at 6:28 AM
    bigazadventures
    bigazadventures New Member
    Sheldon
    Gilbert, AZ
    2014 Red Tundra Crewmax
    ICON Stage 4, Camburg UCA, Method Mesh 18, Toyo AT2 295 70 18, K&N, 30" Rigid LED Bar with front bumper flush mount, Decked in bed drawer storage. Transferflow 46 gal tank.
    I have had the 46 gal Transferflow on my 14 CM for just over a month now. LOVE IT! Wish I would've done it sooner. I have not seen it affect my MPG. I can go 400 miles before the low gas light comes on and I have another 50-100 miles to go before I start looking for a gas station. My current MPG with how I drive and all my custom work is at 11.3 MPG. So mathematically, I can go 520 miles. Which is a huge improvement over the previous stock 26 gal.
    aperezsh, JTP, Jsena and 1 other person like this.
  18. Jun 8, 2017 at 12:12 PM
    dmeneses1983
    dmeneses1983 New Member
    Dennis
    2016 Silver Tundra
    Anyone here get close to 17 mpg with lift and tires
    Jsena and JTP like this.
  19. Jun 8, 2017 at 12:14 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I couldn't get no where near 17 mpg before the lift and tires. :confused:
  20. Jun 8, 2017 at 12:15 PM
    dmeneses1983
    Dennis
    2016 Silver Tundra
    Ahh....I guess it's wishful thinking....best I can do is roughky 15
    Jsena likes this.
  21. Jun 8, 2017 at 7:33 PM
    JTP
    JTP The Big Black Moose
    Sterling, Alaska (Formerly DFW Texas)
    The Big Black Moose
    Ahhh, No
    12 is what Im getting running down the interstate at 75 to 80
    Eclipsed & Floating and Jsena like this.
  22. Jun 8, 2017 at 7:34 PM
    JTP
    The Big Black Moose
    Im going to spend the 1200 bucks and go with the stock tank replacement up to the 37 gal tank. I need my bed space.
    Jsena likes this.
  23. Jun 8, 2017 at 7:39 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Where did you find a transferflow and how much are they?
    JTP likes this.
  24. Jun 8, 2017 at 8:00 PM
    JTP
    The Big Black Moose
    Id like to know, have a look as well to compare.
  25. Jun 8, 2017 at 8:05 PM
    Eclipsed & Floating
    Voluptuous Whitey
    I've been looking and they are about 1200 or so for the under truck tank. I'm having a hard time with that and want something less expensive and maybe even removable
    JTP[QUOTED] likes this.
  26. Jun 8, 2017 at 8:16 PM
    JTP
    The Big Black Moose
    Its a bit pricy but I am going to Alaska with this truck permanently. Fuel can be far and wide depending on where you are.
    I am also going to need my bed space for another fuel tank, hose, and pump set up for airplane fuel. I have a full size ARE camper shell with the structure inside for roof rack coming so I will build a little shelf above the airplane fuel tank for storing gear.
    I think that I can use the left slide window to fill that tank and to pull my hose in and out through. Will see how I can engineer it.
  27. Jun 8, 2017 at 8:20 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Looking forward to your setup. Sounds creative but definitely doable.
    What are you doing in AK? I spent a summer theere in 2000 in the Talkeetnas and Chugach. You'll love it I'd you've never been
  28. Jun 8, 2017 at 9:21 PM
    bigazadventures
    Sheldon
    Gilbert, AZ
    I spent $1745 total for the tank, shipping, the install and a full tank of gas to make sure it worked.
  29. Jun 8, 2017 at 11:39 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Transfer flow is 46 gal and will cost you less than the 36 gal Toyota tank.
    I'm not sure why anyone would get the Toyota tank unless it was free.
    For me, since the truck came with the stupid stock 28 gal tank, it was an obvious choice to upgrade.
  30. Jun 9, 2017 at 4:47 AM
    Well of course he isn't going to go buy a Ram. :D
    Spvrtan and zcarpenter92 like this.
