adding a tach to a 02 regular cab instrument cluster?
Discussion in '1st Gen Tundras (2000-2006)' started by jv384, Aug 25, 2024.
  1. Aug 25, 2024 at 7:40 PM
    jv384
    jv384 [OP] New Member
    2002 Regular Cab
    Bilstien shocks all around, wheels & tires
    My truck, 02 RC, with the 5vz, doesn't have a tachometer in the instrument cluster from the factory. I was wondering if it would be possible to install an instrument cluster from the 4.7 that has the tach, or even the fancy Sequoia one? Has anyone done this? I guess that it would be plug-and-play but I would need to calibrate it for my truck. Let me know! Thanks once again
  2. Aug 25, 2024 at 8:09 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    You'll probably need a v6 cluster as the tachometer count is different due to the IC on the circuit board.
  3. Aug 26, 2024 at 5:02 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I was under the assumption that this was plug and play but another member just the other day tried to install a V6 cluster in his V6 truck and the tach did not function but the cluster wasn't from the same year truck. If you were going to try it you need to try your best to get one from the same year as your truck and from what I've heard it needs to be from a V6 as well.
    Looking at the other guys post he seems to have bought a V6 cluster for an 02 and it didn't work, you may shoot him a PM and if he isn't returning it, see if he'd be willing to sell to you or something to see if it will work for you since it matches the year you need.
    LINK
    shifty` likes this.
  4. Aug 26, 2024 at 10:53 AM
    jv384
    2002 Regular Cab
    Just ordered a 02 cluster with Tach for a v6, I'll keep you guys updated!
    NickB_01TRD[QUOTED] likes this.
  5. Aug 26, 2024 at 10:56 AM
    shifty` We call it “riding the gravy train”
    Sh1tb0x m4nu4l likes this.
  6. Aug 27, 2024 at 7:07 PM
    Sh1tb0x m4nu4l
    Sh1tb0x m4nu4l New Member
    2004 base model manual tundra longbed
    Thanks lol, I fixed the lights it was just the dome fuse but the truck leaked all the tranny fluid out of the driveshaft seal so it's disabled for a few days lol
  7. Aug 29, 2024 at 3:11 PM
    jv384
    2002 Regular Cab
    Alright everyone, I just received my new cluster in the mail. Time to install. Now, how do I go about making sure the miles read correctly?
  8. Aug 29, 2024 at 3:18 PM
    NickB_01TRD
    Nick
    KY
    Well I'd say it'd probably be best to verify that the cluster works in your truck first. How far off is the mileage? (I guess you won't know till you plug it in) I'm not sure how difficult that's going to be to get lined out.
  9. Aug 30, 2024 at 10:01 PM
    jv384
    2002 Regular Cab
    That's the plan! I have 43,000 right now, the new dash is 200,014. I haven't plugged it in, but it says it is written in sharpie on it.
  10. Aug 30, 2024 at 11:20 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    You could contact a speedometer repair shop. Some can reprogram mileage.
    They may require you bringing it to a repair facility and having them ship both in to change the mileage.
  11. Aug 31, 2024 at 6:43 PM
    jv384
    2002 Regular Cab
    Alright everone, IT WORKS!. I just plugged it right up! Literally just a simple swap. I got a cluster for my exact make and model and engine! Now, does anyone know a place that will fix my milage?
    Mustanley likes this.
  12. Aug 31, 2024 at 7:01 PM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    Simple
    dbittle and KNABORES like this.
  13. Aug 31, 2024 at 7:11 PM
    Yes, @assassin10000 told you this already above. That’s one of very few options. Odometer tampering is basically illegal to do yourself. You need to find a specialty shop/service.
  14. Aug 31, 2024 at 11:50 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    the ODO display on some of the older toyotas can be swapped from the older cluster. i've done it on first gen tacos. like 2 screws to pop it out after disassembling the cluster
    shifty` likes this.
  15. Sep 1, 2024 at 2:05 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Alas, still no pictures...
  16. Sep 1, 2024 at 3:18 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Resetting the odometer involves EPROM programming.
