Adding a keyless sensor to lock & unlock from the tailgate handle?
Discussion in '2.5 Gen Tundras (2014-2021)' started by brkncly, Mar 7, 2023.
  1. Mar 7, 2023 at 3:23 PM
    brkncly
    brkncly [OP] New Member
    Oregon
    Anybody know of a way to add a keyless sensor to lock & unlock all the doors and tailgate when your at the tailgate? It would be nice to be able to lock & unlock from the tailgate instead of having to walk up to the front doors. Any recommendations or how to go about doing this mod or is even possible. Any help would greatly be appreciated.
  2. Mar 7, 2023 at 5:52 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    If you have the electronic tailgate lock (OEM or Pop N Lock) you can unlock the gate from the fob.
  3. Mar 7, 2023 at 6:45 PM
    brkncly
    Oregon
    Yeah that’s the way I’ve been locking & unlocking it. It would be nice when I have fishing waders or a jacket on that I don’t have to pull the keys out.
  4. Mar 7, 2023 at 7:11 PM
    Saltyhero13
    The idea was talked about recently within the past year. Nothing on the market that I've seen. Probably a few ways to do it but all custom.
    Unless you use the FOB to unlock, technically the truck doesn't unlock until you touch the front doors (driver or passenger) and the FOB is within proximity. Also the tailgate handle isn't touch sensitive.
    The simplist way would be to add a hidden physical switch or low draw motion sensor wired to the door unlock/lock circuit but this approach would open up security issues if people discovered the switch. You want the switch to be active only when the FOB is nearby.
    From what I recall, one of the issues is the FOB isn't detected from the rear of the truck so you would need a range extender/booster to let the truck know you are in the vicinity.
  5. Mar 12, 2023 at 10:16 AM
    brkncly
    Oregon
    I wonder if I were to take a donor front door handle and harvest the touch pad and incorporate it into the tailgate handle if that would work? Wonder if is still run into a proximity issue unless I was to add another proximity sensor towards the back, what are your thought? Thanks!
  6. Mar 12, 2023 at 10:34 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    What year is your truck?
    Does it already have the touch unlock on the front doors?
  7. Mar 12, 2023 at 2:24 PM
    brkncly
    Oregon
    2020 & yes it has touch lock, unlock on both front doors.
  8. Mar 12, 2023 at 4:33 PM
    Saltyhero13
    You can test the FOB sensor proximity by moving the key towards the cab until the doors unlock. I think it is biased to the driver side slightly so test both sides
    As far as harvesting it is unnecessary unless you want touch capability with your tailgate but you don't need it to enable what you are trying to do.You really only need to trigger the door unlock circuit.
    I also doubt it will be easy to integrate the harvested parts but I haven't seen the internals of the door handles. Gutting the door handles may not work since certain door handle materials need to be used for touch sensitive surfaces. I suspect you'll be better off looking to integrate touch sensitivity some other way using standalone parts that are more accommodating to the form factor and space available if the handle sensors are too big.
  9. Mar 12, 2023 at 4:58 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Saltyhero13 likes this.
  10. Mar 12, 2023 at 5:44 PM
    Saltyhero13
  11. Nov 7, 2024 at 7:09 PM
    yazen27
    yazen27 New Member
    Yazensky
    Tundra trd sport
    I think if you install a sensor handle on the back of the unit connected directly to the front handle wires I think it might work.
