Adding a bed rail system to a CM with a spray in Bed-liner?
Discussion in 'General Tundra Discussion' started by johnxmccoy, Jan 23, 2017.
  1. Nov 19, 2020 at 8:42 PM
    MeetJoe
    MeetJoe New Member
    Maryland
    2021 CrewMax SX
    OEM TRD Pro Led Headlights OEM LED Fog lights iHacker Harness OEM Tube Step OEM trifold hard tonneau OEM Driverside Grab Handle and Pillar OEM Exhaust tip Wireless CarPlay CarLinkit 3.0 Snack Crumbs
    Resurrecting an old thread because I am currently going through this and wanted to share lessons learned.
    2021 SR5 SX CM with 5.5ft bed. Factory spray in liner. Truck did not come with bed rails. All bed rail holes were covered. There are a few guide holes that Were exposed which is why you see my cutting out a hole next to a “clean” hole. (Those are the guide holes for the two bed rail pins).
    I just bought a used OEM tonneau and wanted to make sure I had the threaded holes for the M6 bolts. Instead of open heart surgery, I decided to take my time to carefully locate the holes without destroying my brand new spray.
    There are 5 little square bumps in the bed liner which is exactly where the bumps are on a naked bed (I went to the dealer and looked at a used CM with no bedliner for confirmation).
    I took a sewing needle and a hammer and “eyeballed” where the hole would be on my truck. Tap tap tink... hit the side wall of the bed. Moved up/down/left/right and tap tap tap tap hollow. Meaning I found the hole. I did this to minimize the area of destruction on my new bed.
    wiggle it around and estimate if you are dead center, or left right up down, and the use an exacto knife to puncture the hole and clean cut just large enough to get the bolt in there.
    no drilling, no stripping, no M6 taps or rethreading.
    I’ve attached a few photos of the surgery and glory hole.
    If all goes as intended, I plan to install the tonneau and post a thread this week with full instructions and photos documenting the process for future reference.
    JMB and thearborbarber like this.
  2. Jan 11, 2021 at 8:16 PM
    2point5seconds
    2point5seconds Wish I didn't have so much money
    Sensei
    Nor Cal
    2019 Tundra SR5 TRD 4WD Double Cab
    Icon Stage 9 lift, 700 pound rated Eibach spring, Sumo Springs (rear), RCI engine skid plate. RCI Lower Control Arm Skid Plates, RCI Transmission Skid Plate, RCI Cat Guards, Rago dash plate. RAM phone holder. Bed rails. Tint. 17x8 Icon Rebound wheels. 315/70/r17 Falken Wildpeaks. AAC Trigger 6 Shooter, midland MTX-115 radio, Chassis Unlimited front bumper, OLB Bar light and ditch lights, Baja Fog lights, Smittybilt winch, Husky floor liners, bed rail, Cali Raised Bed Stiffeners, driver's side grab handle, Wheeler's Offroad front bump stops, Decked Tool Box
    I just did mine on Friday. I have a Double Cab though. Shouldn't matter.
    I put the rail up using the plastic tabs to hold it in place and made sure it was level. I then used a tap punch in the center of each hole and found the holes each time. It made a big enough hole to fit the bolt in.
    There are 5 bolts on the side rails and 4 on the front rail. Finished in about an hour at night with just a flashlight.
    Good luck!
  3. Jan 12, 2021 at 7:15 AM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    BravoDeltaRomeo likes this.
