Adding 33's with only a leveling kit
Discussion in 'Wheels & Tires' started by amymills21, May 13, 2018.
  1. May 13, 2018 at 7:51 PM
    amymills21
    amymills21 [OP] New Member
    2018 Tundra TRD Sport 4x4 Crew Max
    2.5" Procomp Leveling Kit, 18" Fuel Sledge wheels -12 offset, Faulken Wildpeak A/T3W LT275 70 R18, Backflip MX4 Matte finish trifold, Husky All-Weather floor mats
    I want to add a 3/1 leveling kit to my 2018 Tundra TRD Sport 4x4. I currently have 31" tires, but I would like to move up to a 33" tire. The dealership told me if I add larger tires, it is going to mess with my gearing. Does anyone know if this is true? I want to add a little something to make the truck look better, but I don't want to mess with the warranty or cause any issues with the truck.
    619Tundra likes this.
  2. May 13, 2018 at 7:56 PM
    Welcome from Texas, let's see your ride, you can fit 35's , as far as 33's is concerned, no it will not affect your gearing, that would be 37's on up
    zcarpenter92 and Sunnier like this.
  3. May 13, 2018 at 8:01 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    I ran both 305/65/18 which is a 33 and now am running 295/70 which is a 34.5. Both fit fine w minor trimming. Just don’t get any wheels with an aggressive offset. Try to stick between +18 & +25.
  4. May 13, 2018 at 8:01 PM
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    I just got a 3/1 on my 14 CM with 295/70 which I believe are right around 34.5. No issues whatsoever and the truck rides amazing. Can’t say if it had any effect on the gearing as it was sitting on 20’ with 33’s when I get it but I can tell
    You it’ll light up the tires with ease when I want to. Here’s a pic, hope it helps.
    Jego, Deacon Blues, omed13 and 25 others like this.
  5. May 13, 2018 at 8:02 PM
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    Forgot to add that my wheels are 18x9 +25
  6. Jul 8, 2018 at 1:25 PM
    Mo_Martz
    Mo_Martz New Member
    Great Country of Texas
    2017 White Tundra CM
    That looks exactly what I’m going for! Awesome rig
    Kawboykev and Blueknights75 like this.
  7. Jul 8, 2018 at 3:45 PM
    Blueknights75
    Ron
    Clayton, NC
    Beautiful truck!
  8. Jul 8, 2018 at 5:16 PM
    BRTundra
    BRTundra New Member
    Tony
    Baton Rouge, LA.
    2017 Tundra Platinum 5.7L CM
    I've got 33x12.5x20 tires with a level and it only rubs occassionally on reverse. Wheels have a +12 offset. Hope this helps.
  9. Jul 8, 2018 at 6:21 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Go with 295/70’s or 35’s, 33’s will look small with a 3/1. The bigger tires will make the truck feel a lil sluggish, but we do have better OEM gearing for adding big tires than other brands.
    757TUNDRA likes this.
  10. Jul 8, 2018 at 6:32 PM
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    Thank You!
  11. Jul 8, 2018 at 7:26 PM
    Pale_Horse
    Pale_Horse Sooooooooo White.
    FL
    White 2013 TRD OR 4x4 DC
    Cupcake chit.
    If you go more than 2.5” of lift I would reccomend going with 35” tires or the 295s.
    Lifted tundras can really swallow up tires. A lot of people run 33”(285s) on stock suspension no lift.
    PermaFrostTRD and Dyollp like this.
  12. Jul 8, 2018 at 9:42 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I have 33s on stock suspension, gears, and wheels.
  13. Jul 9, 2018 at 1:50 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I've got 275/70/18 all stock and no issues at all, they're 33" but factory 11" width.
  14. Jul 13, 2018 at 9:31 PM
    Bakelite
    Bakelite New Member
    Sam
    2018 Toyota Tundra TSS 4x4
    I'm definitely wanting to run 35's with a 3/1 but am unsure if possible. I have the 20x9 tforce rims I'd like to keep if possible as I like those rims. I do have fender flares as well, and the goal would be flush if possible. Not sure what I need to do to accomplish this. Praying that cutting is not needed. Any suggestions?
  15. Jul 13, 2018 at 9:48 PM
    Redlineaz
    Redlineaz New Member
    Shouldnt be an issue at all, many people are running 33's and 35's with just a level kit.
  16. Jul 13, 2018 at 9:49 PM
    Redlineaz
    I think you should be fine, depending on your offsets or how aggressive your wheel sticks out now, if its not too aggressive you might get away with just having to trim the inner bumper, but not having to do a body mount modification.
  17. Jul 13, 2018 at 10:31 PM
    zapman29
    zapman29 New Member
    Jake
    2018 Toyota Tundra SR5 Crew Max TSS Off Road 4X4
    I just got a 3/1 lift and have 285 55 r20's and there almost same size as 33's. im told i could fit bigger, but my tires are pretty new so wont be getting bigger till these run out.
  18. Jul 14, 2018 at 8:46 PM
    WEAL
    WEAL 2018 CM SR5 4X4 SILVER
    2018 Silver SR5 4WD
    @Rngr188 What brand tire? I’m considering same size on stock 18” rims but know brands vary quite a bit. I like the Falken Wildpeak’s @ 33.4”....concerned about rubbing on stock set up. Have your same truck just 2018.
  19. Jul 14, 2018 at 10:28 PM
    Rica25
    Ricardo
    Tulare
    I had 275 70 18 Toyo at2s for about 3 months I got rid of them look to small with billstein 5100 and 1/2 inch front lift on top of 5100....... also rear has 1 inch block and installed now some 295 70 18 Nitto Ridge grapplers just few weeks ago ....also added front sway bar and new lower control arms..... today now the truck sits bad ass
    Balrz likes this.
  20. Jul 14, 2018 at 11:00 PM
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    :worthless:
    Tundra14Platinum and tumaro like this.
  21. Jul 14, 2018 at 11:02 PM
    Rica25
    Ricardo
    Tulare
    will post tomorrow morning I don't have updated pics
  22. Jul 15, 2018 at 4:17 AM
    SgtNewundies
    SgtNewundies New Member
    Eric
    Sunnier and Stroke250 like this.
  23. Jul 15, 2018 at 6:13 AM
    Rica25
    Ricardo
    Tulare
    yoneytan[QUOTED] likes this.
  24. Jul 15, 2018 at 6:59 AM
    Redbeard321
    Redbeard321 ballin' on a budget
    2016 Tundra SR5 Double Cab
    Dealers are dumb. A big ass tundra can handle some beefier tires no problem. The fact that they come with such small tires to begin with is silly.
  25. Jul 15, 2018 at 7:37 AM
    Rob371
    Rob371 New Member
    Rob
    Charlevoix, Michigan
    2007 Tundra Crewmax
    Steel bumpers front and rear,1.4" bilstien, KatSkinz Leather, rear airbags, halos.
    Been thinking of this for mine, just waiting for the Hankooks to wear out. I've got 1.4 inches up front on the bilstien 5100s and just added air bags to rear. Got the steel bumper so no concerns about interference there and that's partially the reason for the bilsteins to handle the weight of the bumper. I've got the 20 inch factory wheels and no plans to change them but the tires do look kind of anemic on there. I do have the factory flares so maybe a problem there. Anybody know? I'm concerned about towing too. I use it a lot for towing.
  26. Jul 15, 2018 at 8:00 AM
    NCinCO
    NCinCO Is it Friday yet?
    Gary
    Thornton, CO
    2018 Smoked Mesquite Limited CM TRD
    Here is what 275/75/18 (33.2") looks like with a 3/1 kit. It doesn't mess with your gearing. IMG_20180616_161432.jpg
  27. Jul 15, 2018 at 8:07 AM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Nice truck! Did you do a true 3/1 or Bilstein 6112’s in front? If you did a 3/1, which did you go with?
  28. Jul 15, 2018 at 8:14 AM
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    Thanks, I did a Pro Comp 3/1 lift.
  29. Jul 15, 2018 at 8:43 AM
    MOQS
    MOQS New Member
    Gary
    Missouri
    2017 SR5 4WD Crew Max
    3/1 leveling kit, DV8 front bumper, Smitty Built X20 winch, Spyder head lights, Eagle Eye tail lights, American Racing ATX 18" rims, General Grabber x3 33x12.5x18 tires. TRD Pro front grille. Rigid Industries 's R2-46 Driving Pair, BAK Revolver X2 Tonneau Cover, GoRhino RB10 Running Boards, Rugged Ridge 3.5" Fog Lights, Rear painted bumper(Black), Tinted windows, Weather Tech window deflectors
  30. Jul 15, 2018 at 9:55 AM
    Rngr188
    Chad
    Harrison AR
    Nitto Ridge Grapplers. I'm nowhere near rubbing.
    parker44 likes this.
