Adding 2nd trans cooler
Discussion in 'General Tundra Discussion' started by Tundra_wil, Nov 15, 2023.
  1. Nov 20, 2023 at 2:58 PM
    #61
    Tundra_wil
    Tundra_wil [OP] New Member
    I don’t think mine has ever been above 205 even in AZ heat with the ac running
  2. Nov 20, 2023 at 2:59 PM
    #62
    Tundra_wil
    i thought about 5.29’s but hate the “break in” period I don’t drive the truck enough- I’ve been looking into a whipple lol
  3. Nov 20, 2023 at 4:36 PM
    #63
    ZPMAN
    Minnesota
  4. Nov 21, 2023 at 4:52 AM
    #64
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Towing or not, my engine's coolant never goes above 194 even in 115F in austin. On the other hand, I don't need to tow anything to easily achieve over 240 almost 249 sometimes in stop/go traffic around town. There is no way to cool it down by using non OD gears (1-4), idling brings it down to 183 in a few minutes but it is tense for me.
    So up to now, I do a drain fill every 3-5 motor oil changes but adding a 2nd cooler (maybe a hayden 699) might help this '15 unit. I've read pinning won't help my situation, is that correct?
  5. Nov 21, 2023 at 5:41 AM
    #65
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Are you reading pan temperatures?
    You can try to pin it open to see if the temps come down, maybe the thermostat is bad and not fully opening.
  6. Nov 21, 2023 at 7:36 AM
    #66
    Johnsonman
    Austin
    Sequoia
    No that was TC, but when TC gets that high, pan is about 220 yet after about minute idling at light, it may drop to 215/230 and so on after about 10 mins w/b back down to 183 for both.
  7. Nov 21, 2023 at 3:40 PM
    #67
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Updates: Scangauge got back to me. Codes are below. I tested them and they work great.
    To view current gear and lock-up status:
    Gear Position (#)
    TXD: 07E02185
    RXF: 046105850000
    RXD: 2808
    MTH: 000100010000
    Torque Converter Lockup (ON/OFF)
    TXD: 07E02185
    RXF: 046125850000
    RXD: 3001
    MTH: 000100010000
    Mike59 and nobodyintexas[QUOTED] like this.
