Adding 2nd trans cooler
Discussion in 'General Tundra Discussion' started by Tundra_wil, Nov 15, 2023.
  1. Nov 17, 2023 at 7:49 AM
    Retired...finally
    Mike59 and COTundie[QUOTED] like this.
  2. Nov 17, 2023 at 7:50 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Are you driving in S4 and seeing temps that high?
  3. Nov 17, 2023 at 10:47 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Threads like this make me paranoid that I need a scangauge setup. At least when pulling the camaper.
    ...but then I'd be (justifiably?) concerned and have to buy more stuff :monocle:
    tarathetundra likes this.
  4. Nov 17, 2023 at 11:02 PM
    tarathetundra
    tarathetundra New Member
    Nate
    2018 white CM
    37x13.50R18
    i actually have a scan gauge its pretty convenient to see trans temps and correlate driving with the temps im sure theres gonna be a deal on em for black friday
    Typically run the guage
    Converter temp. Pan temp
    Coolant. Intake temp
    nobodyintexas likes this.
  5. Nov 18, 2023 at 7:23 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Torque converter lockup status.
  6. Nov 18, 2023 at 8:15 AM
    tarathetundra
    Nate
    2018 white CM
    37x13.50R18
    No i don’t believe i have the option to see when in lock up with the scangauge could be wrong though.
  7. Nov 18, 2023 at 8:17 AM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    It is an available X gauge. I think it’s listed in one of the scangauge 3 threads. I have it on mine. You have to manually input the pid.
  8. Nov 18, 2023 at 8:18 AM
    tarathetundra
    Nate
    2018 white CM
    37x13.50R18
    Ahh i see i have the older model i believe the 2 that may be why
    Silver17[QUOTED] likes this.
  9. Nov 18, 2023 at 8:23 AM
    Silver17
    Northeast
    I would try the X gauge pid on the 2, good chance it still works.
    tarathetundra[QUOTED] likes this.
  10. Nov 18, 2023 at 8:26 AM
    Tundra_wil
    Tundra_wil [OP] New Member
    lmao yeah it made me more paranoid that I came see temps . But from what I read the oem cooler thermostat is set to open at 250 degrees and that’s way to high for me
  11. Nov 18, 2023 at 8:38 AM
    Silver17
    Northeast
    Everything I’ve read says it opens at 190-200ish. If you’re pulling hills for like 3+ straight minutes with an unlocked TC though the OEM cooler doesn’t have the capacity to keep it under control IMO. I’ve seen one other forum member install and 2nd cooler in series and it kept theirs well under control.
    I pull a similar size trailer with the OEM cooler and the thermostat pinned open. If running long hills with the TC unlocked I’ll still see up to 220 in the pan. Anymore, that’s just cause I’m trying to use S5 when I should probably just go to S4. With the supercharger installed, not only does it have all the towing power I would ever need, but because it takes less throttle input to maintain speed the TC stays locked much longer. There aren’t many hills it can’t pull in 4th with it locked up. You can make lockup as aggressive as you want with transmission tuning though.
  12. Nov 18, 2023 at 8:50 AM
    ZPMAN
    Minnesota
    What tire size are you running?
    landphil likes this.
  13. Nov 18, 2023 at 11:09 AM
    Tundra_wil
    35x12.5r17
  14. Nov 18, 2023 at 11:11 AM
    Tundra_wil
    yeah there’s some long climbs of 3+ minutes the truck doesn’t have the power in 4th so 3rd kills the temps I did switch to a synthetic ATF which I was told has a lot higher temp rating so maybe I’ll just leave it as I don’t tow that often. I might re evaluate come summer in AZ when it’s 120 out lol
  15. Nov 18, 2023 at 5:13 PM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    able to share that PID?
  16. Nov 18, 2023 at 7:02 PM
    Silver17
    Northeast
    Now that I think of it the SG3 will find it automatically if you do an auto scan under X gauges. If you have an SG2 than I’d ask scan gauge for the pid, they have responsive service for requests for pids.
  17. Nov 19, 2023 at 2:55 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Its on the scanguage site
    browse the x gauge page for Toyota
    I ran a bunch of them on my SG2
  18. Nov 19, 2023 at 7:21 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Trans temp options are there, but no lock-up status or current gear status. I sent them a request, will see if they respond.
    nobodyintexas[QUOTED] and sask3m like this.
  19. Nov 19, 2023 at 7:30 AM
    #49
    I remember Matt @Black Wolf posted about a deep pan for the Tundra a while back.
    I put a PPE cooler/pan on my truck....
    Black Wolf likes this.
  20. Nov 19, 2023 at 8:16 AM
    #50
    PML
    yourcovers.com
    Retired...finally and ColoradoTJ like this.
  21. Nov 19, 2023 at 11:11 AM
    #51
    Retired...finally
    What's your opinion on the pan? Inquiring minds lacking in Google-foo want to know.
  22. Nov 19, 2023 at 5:00 PM
    #52
    Didn't need one, but did some research several years ago for a just in case scenario. Family owned business providing a decent option was my reasoning to originally post about PML. I'd call them. Can't hurt. :thumbsup:
  23. Nov 19, 2023 at 5:41 PM
    #53
    Dropped my pan temps 15 degrees.
  24. Nov 19, 2023 at 5:47 PM
    #54
    Tundra_wil
    any part numbers for the pan?
  25. Nov 19, 2023 at 6:59 PM
    #55
  26. Nov 20, 2023 at 8:33 AM
    #56
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    PML pan is #11151. It’s a nice, heavy, and solid piece.
    Tundra_wil[OP] likes this.
  27. Nov 20, 2023 at 8:35 AM
    #57
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I'm sure they have a code...I watch lockup status on my SG3.
    they'll give you an xgauge code.
    _none_[QUOTED] likes this.
  28. Nov 20, 2023 at 10:30 AM
    #58
    ZPMAN
    Minnesota
    Might be a good idea to regear with 35s a bigger cooler along with a aftermarket radiator, i pull a 28' toy hauler and temps will climb fast (motor+trans)if i try using 5th unless going down hill slightly with 4.88 gears.20220723_060149.jpg
  29. Nov 20, 2023 at 10:42 AM
    #59
    koditten
    Kirk
    Midland of the Mitten
    What water temps were you seeing?
    I drag a 28' 5th wheel thru the smokies 2x/year. My highest water temp was 216*.
    I wish I knew transmission temps. Not sure I care. I do a transmission drain and fill every year.
  30. Nov 20, 2023 at 10:44 AM
    #60
    koditten
    Kirk
    I'm never in 5th. The truck hums perfectly in 4th @65-68/2900-3100rpm. 9.5 mpg.
