Added TRD rear sway bar kit
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2015TRSPROSD, Jun 23, 2015.
  1. Jul 17, 2020 at 3:56 PM
    #61
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    Tried to get my tow hooks off today and it's not happening with my simple socket wrench. Will a 1/2" drive breaker bar work? Do I just need to invest in an air wrench?
  2. Jul 18, 2020 at 5:32 AM
    #62
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Always go the least expensive route first...breaker bar has your back!
    NewImprovedRon likes this.
  3. Jul 18, 2020 at 7:13 AM
    #63
    prevent
    prevent New Member
    2014 5.7L Tundra SR5 DC
    TRD Catback Stillen CAI DAP Tune Tow Mirrors Light sensor Dashcam TRD Pro Grill LED Interior lights + DRL’s
    I’ve done all my work so far with hand tools without any issues.
  4. Sep 11, 2020 at 11:48 AM
    #64
    Avi8or
    Avi8or New Member
    Johann
    MO
    2020 Limited Crewmax
    The issue I see with this kind of mounting is the sway bar trying to shear the U bolt in this position opposed to pushing on the axle tube or pulling on the U bolt as the installation was designed.
  5. Jul 11, 2021 at 2:31 PM
    #65
    TripleFire
    TripleFire New Member
    Got mine installed today. What a difference! BAM had the cheapest price I could find.
    I t
    I think rotating the brackets 90* absolutely reduces the effectiveness of the bar. Is it perceivable? I think I would notice it. It’s not a 1.5” difference. You’re moving the bar up about 3.5” and back 3.5 inches. The angle of the drop link matters. By moving the bar you’ve messed with that angle and not insignificantly.
    And since the bracket still hangs below the axle when rotated, there’s only ~5/8” of axle ground clearance saved mounting it that way. I’d rather maximize the effectiveness of the sway bar than have the extra clearance. If I off-roaded enough that 5/8” mattered I definitely wouldn’t install a sway bar.
    My apologies for the necro-bump.
    Wynnded likes this.
  6. Jul 11, 2021 at 7:10 PM
    #66
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    Any noticeable negative effect to ride quality by adding the rear sway bar?
  7. Jul 11, 2021 at 7:40 PM
    #67
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    It’s ever so slightly stiffer. I am very sensitive to suspension changes and I absolutely love the sway bar. It’s still very supple over harsh bumps. However I don’t think I would like it if I ever went to an E load tire. I have zero complaints about the factory ride with the sway bar with P load tires.
  8. Jul 12, 2021 at 11:53 AM
    #68
    cp44
    cp44 New Member
    Aaron
    NoVA
    Tundra TRD Pro
    I barely notice the ride stiffness, the better handling and stability outweighs it. I'm definitely happy with it and I even install the front TRD sway bar.
  9. Jul 12, 2021 at 11:55 AM
    #69
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    nobody bitches about a stiff ride like me. I installed one and even with Houston POS segmented concrete roads couldnt tell a difference. Should be stock like transmission cooler.
    szabo101 likes this.
  10. Jul 14, 2021 at 8:28 PM
    #70
    PA452
    PA452 New Member
    Thanks guys. Bought one today. Hopefully have a chance to install next week.
    batman900 likes this.
  11. Jul 14, 2021 at 8:57 PM
    #71
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    sway bar need to be level and the end links need to be plump, if you have it in an angle, it's going to break later.
    HulkSmurf14 likes this.
  12. Jul 15, 2021 at 7:34 PM
    #72
    PA452
    PA452 New Member
    I'm set on ratchets, sockets, and impact wrenches. But I ordered a new torque wrench for the job. :)
    batman900[QUOTED] likes this.
  13. Jul 15, 2021 at 7:44 PM
    #73
    adamreinhardt
    adamreinhardt Blk 17 Platinum 4x4
    Seattle
    2017 Platinum in Midnight Black Metallic
    Have now had my rear TRD installed for a day, very noticeable change for me as I drive a lot. Have the Pro suspension from 17 and before (Bilstein setup, not Fox) and they work together well. Will fork up for the front too. Was really interested in the Hellwig, has 3 settings and quick disconnect I believe. I have no garage or driveway or tools, but a shop did it for me for under a hundred bucks and less than an hour.
  14. Jul 16, 2021 at 9:39 AM
    #74
    Matala
    Matala New Member
    Mark
    Oxford MS
    2014 Tundra 1794 2wd
    Bone stock
    Help-a-noob
    What/who is BAM.
    TIA ✌
  15. Jul 16, 2021 at 9:44 AM
    #75
    adamreinhardt
    Seattle
    BA Mufflers is my guess, aka Dirty Deeds I thinks? I didn’t know it was an avenue for buying the sway bar, but I’ve heard nothing but great stuff about their exhaust systems.
    As for cheapest price on sway bars, I generally check around to different dealerships. Mine was just about 200, free shipping. Can’t to a whole lot better than that, I’ve even seen used ones go for that
    Matala[QUOTED] likes this.
  16. Jul 16, 2021 at 3:08 PM
    #76
    Matala
    Matala New Member
    Mark
    Oxford MS
    Bone stock
    What dealership would that be?
  17. Jul 16, 2021 at 5:32 PM
    #77
    Unclebuck
    Unclebuck New Member
    2018 Crewmax SR5 TRD Offroad
    Brunswick Auto Mart. No affiliation with BA Mufflers. Have ordered from them multiple times, no issues.
    Bamwholesalepartsdotcom
  18. Jul 16, 2021 at 5:45 PM
    #78
    LuvCRVs
    LuvCRVs New Member
    San Antonio
    2021 TRD Sport
    Hard Tri-Fold Tonneau Cover, OEM Bed Mat, OEM All Weather Floor Mats
    I traded a SR5 TSS for TRD Sport. HUGE difference in handling and ride on the highway...for the better. So glad I made that trade.
  19. Jul 17, 2021 at 8:04 AM
    #79
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Lol, why u trade a SR5 to another SR5??? Just for some shocks and sway bars
  20. Jul 17, 2021 at 8:23 AM
    #80
    LuvCRVs
    LuvCRVs New Member
    San Antonio
    2021 TRD Sport
    Um...no...somebody doesn't know their trim levels!
    Beyond the front and rear sway bars and Bilstein shocks, it also has the 20" alloy wheels with all season tires, dual climate heat/AC, LED headlights and foglights, Smart Key , color match grill, hood bulge and front and rear bumpers, TRD Shift knob and of course the ever cool looking hood scoop.
    Bottom line though is it just a much better driving experience. There is a reason they use the word "Sport".
  21. Jul 17, 2021 at 8:34 AM
    #81
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    The trim is SR5, TRD sport is a package
    There are 6 trim: SR, SR5, TRD pro, limited, platinum, 1794. Package is TRD sport and TRD off-road
  22. Jul 17, 2021 at 8:40 AM
    #82
    Unclebuck
    So from a driving standpoint - it has front/rear swaybars and shocks...the rest are just cosmetics/conveniences/features that really dont do much for driving..:boink:
    I keed - As long as your happy with the vehicle, thats all that matters. :cheers:
  23. Jul 17, 2021 at 8:47 AM
    #83
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    that 20" rims count too, for those low profile tires...
  24. Jul 18, 2021 at 8:24 AM
    #84
    adamreinhardt
    Seattle
    I think Lewis Toyota but can’t remember, but it was in Oregon. If I’m looking for a Toyota-specific part, I check dealerships because there’s always one with a lower price or free shipping or faster ship times. But that all varies it seems
  25. Jul 18, 2021 at 11:32 AM
    #85
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I connected the end links first to the body, then to sway bar and use a jack to jack the sway bar in position to install the u bolts.
    NewImprovedRon and batman900 like this.
  26. Jul 18, 2021 at 10:24 PM
    #86
    adamreinhardt
    Seattle
    Thnx man, I appreciate that. I’ll add it to the list
  27. Jul 20, 2021 at 2:09 PM
    #87
    Matala
    Matala New Member
    Mark
    Oxford MS
    Bone stock
    The OEM part best deal search can be brain numbing for me. I, gave up, ha!
    Getting one from BAM $224.83 shipped.
    Thanks OP et al!
  28. Jul 22, 2021 at 4:20 AM
    #88
    MoneyMan55
    MoneyMan55 New Member
    Doug
    2021 AG Trail Edition CM
    Ordered my rear sway on 7/4 from Sparks Toyota. Not delivered yet, send a message asking about order. Sparks replied Toyota is only allowing them one sway bar a day? Whatever this means. Said my order would be two to three weeks out? Kicker is they already charge my CC. Thoughts?
  29. Jul 22, 2021 at 6:32 AM
    #89
    PA452
    PA452 New Member
    Can't speak for that dealership, but I called my nearest dealership and said I'd like to buy a rear sway bar late on a Monday afternoon. They had it in by Wednesday. This was a little over a week ago.
    MoneyMan55[QUOTED] likes this.
  30. Jul 22, 2021 at 1:30 PM
    #90
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I got it in 2019, and from Amazon. But shipping suck, box broke and hardware missing, I have to go Home Depot get a all tread nut cut in down for the end link spacer3A56FE08-9FE5-46B3-8DE5-8F54F2E76480.jpg
