Added MTS/Crawl Control switch to Platinum CrewMax
Discussion in '3rd Gen Tundras (2022+)' started by Tundra_Lover7, Oct 19, 2022.
  1. Feb 26, 2023 at 10:04 PM
    #91
    GoFast157
    GoFast157 New Member
    I hear you. And will go this route if nothing else. Mostly just being stubborn and would like an oem option. Huge fan of not splicing or cutting as little as possible when building a vehicle. Especially with what the truck cost. And if we can get to that point, surely we can add a 4hi bypass to the circuit. :headbang:
  2. Feb 28, 2023 at 6:59 PM
    #92
    chance12
    chance12 New Member
    GA
    23 Tundra CM Limited
    so i'm a little confused...is there any benefit to swapping out JUST the MTS/Crawl control switch on a NON-offroad model?
    To clarify, the truck only has the drive mode and tow/haul selector.
  3. Mar 1, 2023 at 6:11 AM
    #93
    MeekaMN
    MeekaMN New Member
    New to forum, my 2023 Limited non Off Road package, installed MTS/Crawl switch and nothing happened. Might need the MTS module like my gx460 when adding this. From my research, the MTS switch will work on higher trim models with the hybrid motor to get MTS.
  4. Mar 7, 2023 at 12:11 PM
    #94
    Tundra23PNW
    Tundra23PNW New Member
    23 Tundra Platinum
    3-1" Wescott Lift (temporary) RRW RR5-H 17X8.5 0 offset HYBRID BEADLOCK Toyo Open Country RT Trail 35x12.5 r17 Toyota Pro Grill CaliRaised Ditch Lights and brackets
    So I have a 23 Tundra Platinum and decided to try the switch out. Installed easy and everything lights up even shows the MTS modes on the Digital dash. I have not confirmed if it actually changes anything in the drivetrain though. It will definitely not have the crawl control since the platinum doesn't have the factory rear locker. Ill try to up date once I get out and try it in 4wd.
    GoFast157 likes this.
  5. Mar 8, 2023 at 8:32 AM
    #95
    LimitedFL
    LimitedFL New Member
    Kal
    2023 Limited
    Did you have to take the center console apart to install the switch or just pry the switch out with the pry tool like some members had done?
  6. Mar 8, 2023 at 9:16 AM
    #96
    Tundra23PNW
    23 Tundra Platinum
    It was super easy and you dont have to remove any of the center console. I just used a trim tool to pop the module out. The wires on mine were super short so it was a little tight to unplug it and plug the new one back in but overall maybe 5min job.
  7. Jun 17, 2023 at 7:36 PM
    #97
    virgilus11
    virgilus11 New Member
    2022 Tundra Capstone
    1/2" front spacer 37" Cooper ATX
    Sorry for the late reply. As I mentioned earlier, the multi terrain looks like is working but not the Crawl or DAC
    ryanwgregg likes this.
  8. Jun 30, 2023 at 10:24 AM
    #98
    Midnightyota
    Midnightyota New Member
    On a standard sr5 sx does the addition of the MTS controller prompt a visual of the sand, snow, mud, modes on the dash?
  9. Jun 30, 2023 at 10:36 AM
    #99
    Buellride
    Buellride New Member
    Olympia
    THE BOULDER
    BD Lights, Banks PM, Fuel Vector 18" on 295/70R18 Cooper AT3 XLTs, Black-Out badges, TRD front grill
    Yes
  10. Aug 3, 2023 at 4:52 PM
    #100
    BigBuck
    BigBuck New Member
    2023 Tundra
    84970-0C010. Put this in my 23 tundra sr. It lights up when the interior lights are on but doesn’t seem to do anything else. Just wondering if any of you have any advice on what to do next.
    Jorts likes this.
  11. Aug 4, 2023 at 3:03 AM
    #101
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    Will this mess with any of my factory options. I have avs, and want to make sure if I switch the switch, my comfort, sport+, etc will work fine
  12. Aug 4, 2023 at 5:33 AM
    #102
    Tundra_Lover7
    Tundra_Lover7 [OP] New Member
    2024 Platinum CrewMax TRD offroad
    3 inch TRD lift, TRD Skid plate, RCI Trans/Cat converter skid plate, RCI Bed Rack, Nitto Recon Grapplers, OEM bed mat, BAK Revolver X4S Tonneau, OEM Mudguards, OEM Black Chrome exhaust tip, TRD pro flairs, TRD pro grill, Baja designs light bar, Rigid ditch lights
    I have the platinum trim with the AVS and all the driving modes still work. Comfort, sport +, custom, eco etc.
    For the question on the SR trim, I believe a prior post indicated that the switch did not activate the MTS. Make sure you try putting the truck into 4H or 4L first then try hitting the MTS button.
  13. Aug 4, 2023 at 8:00 AM
    #103
    BigBuck
    BigBuck New Member
    2023 Tundra
    Yeah I’m not getting anything to come up whether in 4wh or L. It lights up with the rest of the ambient lighting but that is all. When I ordered the part it even said it was compatible with the SR trim. Not sure if I’m missing another component or it needs programmed.
    Woocawachie and (deleted member) like this.
  14. Aug 23, 2023 at 3:48 PM
    #104
    Ipaddick
    Ipaddick New Member
    Canada
    After changing this out I got a cel any ideas why/how to clear it?
  15. Aug 24, 2023 at 4:41 PM
    #105
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    Would love to know how this turns out. Have an SR myself. Wonder if it’s software locked or there’s mechanical components that aren’t installed
  16. Sep 5, 2023 at 7:40 PM
    #106
    BigBuck
    BigBuck New Member
    2023 Tundra
    I ordered the next control switch down trim wise. I believe it only has mode and tow/haul. The parts dept said I could hook it up in the parking lot and if it didn’t work I could box it up and return in. I’ll keep you posted!
    Woocawachie likes this.
  17. Sep 5, 2023 at 8:30 PM
    #107
    chance12
    chance12 New Member
    GA
    what do you currently have in your truck?
  18. Sep 5, 2023 at 8:32 PM
    #108
    BigBuck
    BigBuck New Member
    2023 Tundra
    Stock it comes with a change dish where the control switch is. But when you pull it out the wiring plug is attached to it.
  19. Sep 5, 2023 at 8:33 PM
    #109
    chance12
    chance12 New Member
    GA
    so you've got an SR I assume?
  20. Sep 5, 2023 at 8:34 PM
    #110
    BigBuck
    BigBuck New Member
    2023 Tundra
    Yes, 23 SR.
    chance12 likes this.
  21. Sep 9, 2023 at 4:39 AM
    #111
    Woocawachie
    Dickens
    Philadelphia
    Keep us updated
  22. Sep 10, 2023 at 7:43 AM
    #112
    BigBuck
    BigBuck New Member
    2023 Tundra
    Will keep you posted. Will be a couple weeks till I get it picked up.
  23. Sep 18, 2023 at 1:51 PM
    #113
    Bstillrob1
    Bstillrob1 New Member
    2022 Tundra SR5 4x4
    I ordered the 84970-0C010 MTS /DAC Crawl switch last week. It arrived today and was a 5-minute install. Only the Drive Mode and Tow Haul light up. All switches illuminate when I turn the lights on. I have a 2022 SR5 4X4 non-TRD.
    spliffgates likes this.
  24. Sep 18, 2023 at 1:54 PM
    #114
    Ipaddick
    Ipaddick New Member
    Canada
    Put it in 4x4 then try mts.
    Bstillrob1[QUOTED] likes this.
  25. Sep 18, 2023 at 3:05 PM
    #115
    Woocawachie
    Dickens
    Philadelphia
    Same question
  26. Sep 18, 2023 at 3:15 PM
    #116
    Bstillrob1
    2022 Tundra SR5 4x4
    I put it in 4h & 4l, nothing.
  27. Sep 18, 2023 at 4:43 PM
    #117
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    Just put one on Friday, MTS comes up with the options for mud, sand, etc, but like folks have said previously, Crawl Control nothing, as I don't have the locking diff.
  28. Sep 22, 2023 at 6:27 PM
    #118
    BigBuck
    BigBuck New Member
    2023 Tundra
    Tried the lower model switch today with only the mode and tow/hall buttons. (23 SR). It didnt work either just like the switch with MTS etc. Lights up with ambient lighting but nothing else and does not work in 4WD. Hi or low.
  29. Sep 23, 2023 at 6:10 AM
    #119
    Woocawachie
    Dickens
    Philadelphia
    :( Oh well… I guess manual S8 gear will do for now when towing. Probably does the same thing.
    BigBuck[QUOTED] likes this.
  30. Oct 31, 2023 at 6:57 PM
    #120
    nondem
    nondem New Member
    Randy
    Tallahassee, Fl. USA
    2023 Platinum 4x4
    Seat Jackers
    So, I hate to be redundant but several different models are in debate on this thread and I'd like to get clarification before I buy the MTS Switch.
    I have a 2023 Platinum 4x4 non-hybrid, no AVS/TRD - just the standard suspension. If I get the MTS switch will I get the MTS options/visuals on my LCD gauge cluster? Since I have all the cameras, will the special off-road view modes work? Will the added MTS modes work on the drivetrain aside from DAC & crawl control?
