Added MTS/Crawl Control switch to Platinum CrewMax
Discussion in '3rd Gen Tundras (2022+)' started by Tundra_Lover7, Oct 19, 2022.
  1. Nov 9, 2022 at 3:50 PM
    #61
    GG.Offroad
    GG.Offroad New Member
    Austin
    Westminster, CO
    2023 Tundra Limited Hybrid Lunar Rock
    www.ggoffroad.com
    How certain are you the position switch is can bus? Those diagrams are amazing! thank you. I wish they had better descriptor on the wires. Im not sure why im still invested in this now that they found me a truck with OR haha I just know its gotta be possible
  2. Nov 9, 2022 at 4:08 PM
    #62
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    Mirrors are tied to can bus so likely this is too.
    ryanwgregg likes this.
  3. Nov 9, 2022 at 5:13 PM
    #63
    Tundra_Lover7
    Tundra_Lover7 [OP] New Member
    2024 Platinum CrewMax TRD offroad
    3 inch TRD lift, TRD Skid plate, RCI Trans/Cat converter skid plate, RCI Bed Rack, Nitto Recon Grapplers, OEM bed mat, BAK Revolver X4S Tonneau, OEM Mudguards, OEM Black Chrome exhaust tip, TRD pro flairs, TRD pro grill, Baja designs light bar, Rigid ditch lights
    Bummer that this was not as easy as replacing the 4wd module and switch. Did you happen to test if the multi terrain monitor is activated with the new module or do you still just have the normal panoramic view monitor? Would also like to figure out where this functionality resides. we're there any changes to your drive modes with the installation of the new 4wd computer? Thank you all for continuing to try to figure this out.
  4. Nov 9, 2022 at 6:23 PM
    #64
    virgilus11
    virgilus11 New Member
    2022 Tundra Capstone
    1/2" front spacer 37" Cooper ATX
    The MTS is working. At list it shows a different screen in the dash board and the option for sand, rock and the rest.
    DAC and Crawl not working.
    I stopped by another dealer tonight and they had one with Off Road package.
    I can see two wires that are coming out from the main harness right on top of rear passenger wheel. One is going to a small box that looks like a vacuum pump or something like that and the other one is going directly to the differential.
    It was pretty dark and could not see that well. Will stop by again, to take a better look. .
    I don't mind following if I knew that is only parts that you can buy and install but,, I just don'thave a good feeling about it.
    Snomej, ryanwgregg and 22whatwedo like this.
  5. Nov 9, 2022 at 8:01 PM
    #65
    bigblue14
    Craig
    You're doing the Lord's work - keep it up!
    Pgain88, GreatWhite23 and Snomej like this.
  6. Nov 12, 2022 at 6:51 PM
    #66
    virgilus11
    Well, no luck, for now. Been spending all day under the treuck taking harness apart. No plug or pins to continue farther from the main harness above passenger rear wheel to the differential. For now, I am taking my losses and ending with a nice looking control switch. The other way MAYBE, to run a separate harness from the 4 WD computer to differential and locking diff switch. Hopefully someone can make this work someday.
  7. Nov 12, 2022 at 7:38 PM
    #67
    virgilus11
    Is there a way to find the right harness with the vin number ?
  8. Nov 19, 2022 at 6:53 AM
    #68
    Eng1628
    Eng1628 New Member
    Will the MTM works?
  9. Nov 21, 2022 at 5:50 PM
    #69
    RockyR
    RockyR New Member
    Rocky
    2022 Tundra Platinum Midnight Black 6.5
    We are all hoping!! But unfortunately it hasn't worked out so easily.
  10. Nov 30, 2022 at 1:50 PM
    #70
    virgilus11
    I am at a dead end with the harness that my truck have.
    GreatWhite23 and ryanwgregg like this.
  11. Nov 30, 2022 at 3:15 PM
    #71
    bballjames
    bballjames New Member
    Inland PNW
    22 Tundra Platinum 4x4 Hybrid Crew Max 6.5ft bed
    Is this true? Would you share how it is possible?
  12. Dec 21, 2022 at 10:55 AM
    #72
    ESalt206
    ESalt206 25 Limited
    CO
    25 Limited Lunar Rock
    UnderCover Flex, mud flaps, Beat Sonic amp, Predator side steps. To come... heritage grille and 20in light bar
    Curious about swapping out the switch in my Limited.
    Do any of you that have done this have pictures of how this shows up on the 'standard' dash when you use the Multi-Terrain Select?
    And, now that the snow is here, if you have noticed any change in traction/performance in the new modes?
    chance12 and GreatWhite23 like this.
  13. Dec 21, 2022 at 11:24 AM
    #73
    virgilus11
    I installed the switch that have the DAC and multi terrain.
    I can say that when I put it on deep snow the ECU doesn’t cut the gas as quickly as before. I spin the tires A lot more
  14. Jan 10, 2023 at 4:42 PM
    #74
    mcabrera67022
    mcabrera67022 New Member
    max
    2023 Tundra
    Hey what’s going on Tundra dudes, got a 2023 tundra platinum 4x4 any update on this topic? Really interested in installing this, I purchased the switch will be installing this weekend, wondering if anyone here has figured out if CRAWL control works?
  15. Jan 10, 2023 at 5:38 PM
    #75
    Breathing Borla
    AZ
    It doesn’t
  16. Jan 10, 2023 at 8:38 PM
    #76
    GreatWhite23
    GreatWhite23 New Member
    ‘23 Limited
    Westcott Designs Lift and 295/65s
    Definitely watching this and hoping for future updates, along with a link to the original part. Just took delivery of my ‘23 Limited without any TRD options or locking diff.
    Would love the MTS function if it actually works though!
    chance12 likes this.
  17. Jan 10, 2023 at 8:42 PM
    #77
    GreatWhite23
    ‘23 Limited
    #77
  18. Jan 10, 2023 at 9:33 PM
    #78
    voodootaco
    voodootaco New Member
    Tacoma trd sport 4x4
    I know this is tundra forum but im trying to do same on my tacoma trd sport, purchase modules, harness and ECU and as soon i installed the ECU code error shows rear locker diff “open” i don’t have rear locker but the ECU has this problem , i guess my next step y to purchase only the actuator and see what happens
    GreatWhite23 likes this.
  19. Jan 11, 2023 at 6:35 AM
    #79
    23LMT471
    23LMT471 New Member
    2023 CrewMax SR5 TRD Off-Road Midnight Black
    I remember when I bought the ATRAC switch for our 2007 FJ Cruiser that did not come with it. Plugged it in and magically had ATRAC. It did have locker.
    Was hoping to find a 2023 Limited with TRD Off Road and all items we wanted but you know how that went. Good work people!
  20. Jan 11, 2023 at 12:31 PM
    #80
    nnguyen04
    nnguyen04 New Member
    Thanks to this thread, I spent on another mod I don't really need lol.
  21. Feb 5, 2023 at 10:56 AM
    #81
    chester90
    chester90 New Member
    Bealeton Virginia
    2022 Silver SR Tundra
    Would anyone who has purchased the MTS switch be interested in parting ways with their non-MTS drive mode selector? I have an SR trim truck that does not come with a drive mode switch. Theres a little storage pocket in its place but I pulled it today and confirmed that it does have a harness that the switch would plug into so I’m interested in plugging one in to see what happens.
  22. Feb 5, 2023 at 1:46 PM
    #82
    nnguyen04
    Dm
  23. Feb 24, 2023 at 2:29 PM
    #83
    TheGreenGoblin
    TheGreenGoblin I'm not fat...I'm cultivating mass.
    2023 Tundra SR5 TRD Sport CrewMax 4x4
    *Bakflip MX4 Tonneau Cover *Go Rhino RB20 Running Boards *Go Rhino RB20 Hitch Step *TRD Front Skid Plate *Talon's Cat Shield *OEM Mudguards *OEM bed step *OEM bed extender and bed mat *Lower Door Moldings *EGR SUPERGUARD Bug Shield *SunTek Full Front PPF Wrap *Miyabi Ceramic Coating *Tufskinz decals and door sill protectors
    Any update on the install?
  24. Feb 24, 2023 at 2:31 PM
    #84
    TheGreenGoblin
    Lol. I just found this thread last week...and the drive module just arrived!
    The '23 Tundra is my first truck, and I may have gotten a bit carried with mods. Garage is filling up quickly!
  25. Feb 24, 2023 at 2:33 PM
    #85
    TheGreenGoblin
    @virgilus11 It's been a few months since your last post. How is that switch holding up?
  26. Feb 24, 2023 at 5:03 PM
    #86
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    Plz report back if this works on the SR
  27. Feb 26, 2023 at 6:34 AM
    #87
    chester90
    Bealeton Virginia
    It did not work, it plugs in and illuminates but the buttons/dial don’t actually do anything.
    Woocawachie and ryanwgregg like this.
  28. Feb 26, 2023 at 9:16 AM
    #88
    Henry1jg
    MI
    Damn. Thanks for trying tho. We all appreciate it!
    ryanwgregg and GoFast157 like this.
  29. Feb 26, 2023 at 2:27 PM
    #89
    GoFast157
    GoFast157 New Member
    Forgive me if you covered this somewhere else or have given up. Just found this thread and have been looking into continuing this journey. Pulled plastics on my 22 platinum to get to the plugs on 4wd control ecu and have a look. Was able to get pictures of the plugs and the pins for the most part. Did not see anything labeled A7 as mentioned. Anyone have pictures or diagram of pinouts for this? Also with mention of only 2 pins for actuator, what about signal from locker verifying engagement? My thinking is much along the lines of adding pins if needed and either "fooling" the locker signal or actually finding an oem locker for less than the cost of an appendage. Mts switch is ordered. Waiting to get better info on wiring before purchasing the trd 4wd control ecu. I'd go as far as making a temporary jumper to plug into someones trd locker , with factory platinum 4wd control and if needed the trd 4wd control to see what changes. If we can figure this out I may be willing to cough up the money for the locker.
    Yoda_Lance likes this.
  30. Feb 26, 2023 at 8:23 PM
    #90
    Fxclm5
    Fxclm5 New Member
    Why not just go aftermarket so you can activate locker in 2wd or 4hi instead of only 4lo?
    GoFast157[QUOTED] likes this.
