Added another 150lbs payload to my Tundra!
Discussion in 'Towing & Hauling' started by BrakeDust, Feb 13, 2021.
  1. Feb 13, 2021 at 9:45 AM
    BrakeDust
    BrakeDust [OP] New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    So it seems the doorjamb payload already includes the driver. That means when it says "Passengers & cargo = 1270lbs" I actually have the full 1270 for wife, dog, cargo & trailer. Gas already included as well.
    It's a big difference.
    This came from a post somewhere where a guy had pulled up to CAT scales and the truck weight _less_ than the door jamb by a couple hundred pounds.
    So what's the truth?
  2. Feb 13, 2021 at 10:01 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Payload listed includes the driver and some gas, but it may not account for a full tank. Now the figure is whatever they use for average driver weight, so it you are a 240lb man, you weigh more than their allotment for sure. I will give an educated guess that they use 180lbs for driver.
    Best to actually weigh the truck. Any accessory added that weighs more than stock or added comes out of available payload. So a spray in bed liner, topper, those heavy bigger tires- all takes away from your payload.
    Wallygator likes this.
  3. Feb 13, 2021 at 10:06 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    GVWR will tell you everything you need to know
  4. Feb 13, 2021 at 11:01 AM
    usaf.2012
    usaf.2012 New Member
    AK
    2010 Black CM Tundra RW
    10" BAMuffler // Bilstein 5100s all around & front on Mid setting // Toytec shackles // BHLM
    My door sticker says "occupants and cargo" which would imply the driver is not accounted for. Also I have found nothing in the owners manual that states Toyota factored in any weight for the driver. In fact I have found the opposite under the Cargo and Luggage section and where Toyota spells out the "steps for determining correct load limit".
    Terndrerrr and Cpl_Punishment like this.
  5. Feb 13, 2021 at 11:15 AM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    A driver is not a passenger. So I vote for your interpretation. I also drove with a super sack worth (one ton) of rubber mulch in my looong bed with no problem.
    Edit: perhaps the stickers on Canadian and USA models are different.
  6. Feb 13, 2021 at 11:34 AM
    Cpl_Punishment
    Cpl_Punishment Young men never die.
    Rosy
    2020 MGM SR5 CM 4X4
    The truth is weigh your truck with a full tank of gas, whatever you normally carry in it and yourself and subtract that from your GVWR (probably 7200 lbs) to figure out how much additional weight you can carry
    AggiePhil likes this.
  7. Feb 13, 2021 at 12:33 PM
    BrakeDust
    Hill Country, TX
    Yes, 7200. Indeed that's the only thing that matters.
  8. Feb 16, 2021 at 3:57 PM
    68 RS/SS
    68 RS/SS New Member
    MIke
    New Hampshire
    2020 TRD Sport DC
    I did too, I divorced my wife
