Add a quick disconnect to grille lights?
Discussion in 'Lighting' started by rocsteady, Dec 5, 2022.
  1. Dec 5, 2022 at 6:31 AM
    rocsteady
    rocsteady [OP] New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    For those of you electrically inclined around here; I installed the "Raptor" lights from YotaLeds this weekend but in doing so realized that it will make it a little bit of a p.i.a. to remove the grille.
    I have the front camera and it has a simple "male/female" connector that is simple to unplug so you can leave the camera and some wiring attached to the grille when removing for whatever mod/repair necessitated grille removal. Although not complicated to remove the leads that go to the battery positive and negative and the ground, wondering if it's feasible to "add" a quick disconnect.
    BlueRibbon4x4 likes this.
  2. Dec 5, 2022 at 6:34 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    RainMan_PNW, reywcms and Tundra234 like this.
  3. Dec 5, 2022 at 6:41 AM
    rocsteady
    Dave
    New Jersey
    Geno to the rescue! Thank you, I will give it a try. What's the worst that can happen? Be worth it to keep grille removal as easy as it is I think.
  4. Dec 5, 2022 at 3:14 PM
    BlueRibbon4x4
    Geno
    They will work. I used them on my raptor lights, and I’ve taken the grille off more times than I can remember.
