Add A Circuit Question
Discussion in 'General Tundra Discussion' started by Davidlspearman, Jul 16, 2018.
  1. Jul 16, 2018 at 11:34 AM
    Davidlspearman
    Davidlspearman [OP] New Member
    David
    2016 Toyota Tundra Dbl Cab MGM
    I am planning on adding a few things and wanted to tap into the fuse box both inside the cabin and outside (under hood) one as well. So here’s what I think I need in the pic below. I purchased it this morning and I didn’t have time to take the covers off to dbl check size and type of fuse. I did google it and it seems there’s a lot of different answers depending on year of truck and all. I have a 2016 Tundra Double Cab MGM. Will this work and if it will am I going to be able to get the lid / cover back on. Also I’m planning on adding the following items and any suggestions on products that would help or simplify the wiring and work long term would be great. Thanks !
    Alpine Powered sub Pwe-S8 (if anyone has one of these in their double Cab please send me pics of locations and wiring options)
    30” LED Bar - Lower Bumper
    Toyota Bed Light Kit
    Rear backup lights or a combo brake light / reverse light Bar
    KC Highlights Cyclone Underhood Light.
    dongziye likes this.
  2. Jul 16, 2018 at 11:38 AM
    ToyotaTundraMike
    2015 Tundra
    Can’t remember which one you need in the cab but under the hood of mine required a “low profile mini add a circuit”.
    Davidlspearman[OP] likes this.
  3. Jul 16, 2018 at 11:44 AM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    2010 Super White DC
    I just "hardwired" a dash camand used this add-a-fuse, which looks like the same type as yours:
    FAST Shipping ADD CIRCUIT BLADE STYLE APS ATT LOW PROFILE MINI FUSETAP FUSE TAP + 5AMP FUSE https://www.amazon.com/dp/B00I0MWPXU/ref=cm_sw_r_cp_apa_5AotBbGDSGTGV
    You will not be able to put the cover back on the fuse box in the cab. Just make sure you put it in the correct direction. It will "work" both ways once you have the new fuse and original fuse in, but only one direction will actually protect the circuit on the new added accessory.
  4. Jul 16, 2018 at 11:50 AM
    Davidlspearman
    David
    So if I want to add a fuse in the cabin fuse box, I won’t be able to reinstall the cover? That kinda sucks.
    Someone told me that when I run a wire theubthe firewall that all I need to do is take a razor blade to the left of the nipple on the main blood on make a small incision and then I can feed the wires thru. Any tips or thoughts?
  5. Jul 16, 2018 at 11:50 AM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    The ATM - "LP" shown is the mini -Low Profile you are referencing.
  6. Jul 16, 2018 at 11:57 AM
    Davidlspearman
    David
    The cover missing is a huge deal breaker if it means protecting the electrical system and add on’s from shorting out stuff. I just wanted to make sure I purchased the correct stuff. The only downside I guess to not being able to keep the lid on is the “fuse map” printed on the cover. I assume I can always look online or the Owners Manual.
  7. Jul 16, 2018 at 12:00 PM
    Davidlspearman
    David
    That’s a awesome tool. I’ve never seen one of those before. I want to make sure I do the best job possible cause I’m pretty OCD w stuff and having the right tools makes a huge difference in how stuff turns out.
    NewImprovedRon likes this.
  8. Jul 16, 2018 at 12:29 PM
    Davidlspearman
    David
  9. Jul 16, 2018 at 12:38 PM
    wmchaseb
    wmchaseb New Member
    Chase
    Louisiana
    2018 Plat MGM
    care to explain how you know if it is put in the correct way?
  10. Jul 16, 2018 at 1:00 PM
    BuckWallace
    Oregon
    2010 Super White DC
    Per the instructions on mine, the prong opposite the wire side should go in the "hot" side of the fuse socket. You can test which side is hot with a multimeter.
  11. Jul 16, 2018 at 1:54 PM
    PMG
    PMG New Member
    You can tape the cover back on if you really want to... It's out of reach and mine has been uncovered for almost 2 years.
  12. Jul 16, 2018 at 2:46 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    That's a great little tool. I have to get one.
  13. Jul 16, 2018 at 4:35 PM
    nk1794
    San Jose, CA
  14. Jul 16, 2018 at 4:58 PM
    big_jarv
    big_jarv New Member
    2021 TRD Pro
    Didn’t know such a tool existed!
    Thank you for sharing!
