Actuator Replaced Now Door Won't Open
Discussion in '2nd Gen Tundras (2007-2013)' started by Jposes, Mar 7, 2019.
  1. Mar 7, 2019 at 3:14 PM
    Jposes
    Jposes [OP] New Member
    Justin
    Austin, TX
    2012 Tundra Crewmax 5.7L 4x4
    I just replaced my rear passenger door actuator. Now it unlocks and locks great. Problem is, I failed to connect the rod from the door handle to the actuator. So, my door is closed and I can't get it open. Has anyone made this nincompoop mistake? How can I get my door open?
  2. Mar 7, 2019 at 3:21 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Sure you can’t open it feom the inside?
    Any thing on YouTube ?
  3. Mar 7, 2019 at 3:22 PM
    timsp8
    NY
    I think you’ll have to try to pry the door panel off and reach it from the inside. No way to do it from the outside or else it’d be that easy to break in to the truck. Since it’s closed you won’t be able to get the whole panel off but might be able to pull it back and reach it.
  4. Mar 7, 2019 at 3:22 PM
    Jposes
    Justin
    Austin, TX
    Can't open from inside or outside.
  5. Mar 7, 2019 at 3:23 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    The only way to open it,...
    Booney, porkitt, 15whtrd and 2 others like this.
  6. Mar 7, 2019 at 3:24 PM
    Les7311
    691EB966-CA55-4EE5-95DD-054395E8ED1F.jpg door wont open from inside or outside
    Try these search on YouTube I saw a few vids - didn’t view them
    Black Wolf likes this.
  7. Mar 7, 2019 at 3:43 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Welcome
    :rofl:Sorry to laugh but sounds like something I would do
    Maybe try inquiring at a stealership
    Let us know how you make out and post up a pic of your truck
    Les7311 likes this.
  8. Mar 7, 2019 at 3:44 PM
    Leo's first
    Groton ma
    :rofl::rofl:
  9. Mar 7, 2019 at 4:33 PM
    Jposes
    Justin
    Austin, TX
    Well I managed to get the door open. Created a little bigger problem. But I'm working through it.
  10. Mar 7, 2019 at 4:37 PM
    West Texas Tundra
    West Texas Tundra 2016 Bronze Beast
    Leo
    Odessa, Tx
    2016 Sunset Bronze
    20 inch CECO wheels Drop in K&N air filter 2 inch front leveling kit
  11. Mar 7, 2019 at 4:38 PM
    phabej
    phabej New Member
    2018 Platnium
    :eek2::angrygirl: shit. :fingerscrossed: aligning body parts ain't easy. Best of luck
  12. Mar 7, 2019 at 4:39 PM
    Jposes
    Justin
    Austin, TX
    I took these bolts off so I could pry open the door enough to be able to pull the panel open and get my hand in there. However, when I was able to reach the lever to open. Since the door was unbolted, it came crashing down.
  13. Mar 7, 2019 at 4:42 PM
    phabej
    phabej New Member
    2018 Platnium
    You didn't support it?? That's crazy
  14. Mar 7, 2019 at 5:15 PM
    Jposes
    Justin
    Austin, TX
    Got it all put back together and doors working great. Did break another part. But easy replacement.
    Bakershack, Booney and Sunnier like this.
  15. Mar 7, 2019 at 5:16 PM
    Jposes
    Justin
    Austin, TX
    This is the other part that broke. It keeps the door from swinging open too far.
  16. Mar 7, 2019 at 5:19 PM
    Jposes
    Justin
    Austin, TX
    On the bright side, if anyone ever runs into this problem, I can give advise on a couple things not to do. A 20 minute actuator replacement turned into 3 hour debacle. :(:boom:
  17. Mar 7, 2019 at 5:21 PM
    15whtrd
    15whtrd Mr. Blonde
    Glad you got it back together. What a disaster! I suggest anyone reading this, to actuate the lock/latch with a screwdriver and trying the handle “before” closing the door. after doing any type of work in the doorpanel.
  18. Mar 7, 2019 at 5:25 PM
    Sunnier and 15whtrd like this.
  19. Mar 7, 2019 at 5:44 PM
    Jposes
    Justin
    Austin, TX
    Found the door check online for $30. Not too shabby.
    Les7311, Black Wolf and 15whtrd like this.
  20. Mar 7, 2019 at 6:00 PM
    Smoofers
    Smoofers New Member
    N TX
    2018 TRD Sport
    I worked professionally in car audio and have removed door panels than I can remember. ALWAYS check your door handle function before you close the door.
    Jposes[OP] and 15whtrd like this.
  21. Mar 7, 2019 at 6:47 PM
    Les7311
    Did any of the YouTube videos worked?
  22. Mar 7, 2019 at 6:58 PM
    Jposes
    Justin
    Austin, TX
    I didn't take the time to watch any. With the front door open, the hinge bolts for the back door are exposed. I decided to unbolt the door from the frame so I could pry it open at the bottom enough to get the panel clips out. Then I was able to remove the panel enough to reach in and push the lever to open it. Once I had the panel off I should have bolted the door back to the frame. I didn't. So, it came crashing down when I pushed the lever to open it. The door check held it from getting banged up. But that door check is dead now. I had to remove the door check to be able to put the door back on.
    NewImprovedRon likes this.
  23. Mar 8, 2019 at 6:23 AM
    phabej
    phabej New Member
    2018 Platnium
    The good news at least it's do-able if you forgot to hook the actuator! :) just be more prepared.
    Jposes[OP] likes this.
  24. Feb 23, 2020 at 11:40 AM
    Toeyoda
    Toeyoda New Member
    2005 Tundra TRD
    Mine is a first gen but On the rear I just did the same thing except I can open the door from the inside. Can’t figure out why the handle won’t work. It seems as if there is a white piece of plastic that just hangs down and sits above the latch on the actuator. Does anything else hold it in place?? I just replaced my actuator from supposedly another 04-06 tundra but there are some differences. The part shown is fatter on the one that came out rather than the one I installed.
  25. Feb 23, 2020 at 11:41 AM
    Toeyoda
    Toeyoda New Member
    2005 Tundra TRD
    Here’s the inside see how it’s smaller
  26. Feb 23, 2020 at 1:05 PM
    SouthWestGA
    SouthWestGA New Member
  27. Oct 20, 2021 at 9:49 AM
    redtrout
    redtrout New Member
    Roger
    2015 Tundra Limited 4wd
    Ok, I did the same thing. Anymore extensive instructions? Should I order a replacement mechanism before I attempt to take it off at the hinges? I only have one vehicle and would rather not have to drive around without a door.
  28. Oct 20, 2021 at 11:52 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    I would open the door thats the same as the one thats stuck take the door panel off , roll down the window and practice fishing the latch release while you can see and associate feel an angle. After a couple good practices. Roll down the window on the stuck door and repeat your fishing for latch but now blind since the doors shut.
    that would be my non evasive suggestion to anyone.
    if you have a nylon wedge and mechanics mirror and a light that would help the going in blind part.
  29. Oct 21, 2021 at 8:36 AM
    redtrout
    redtrout New Member
    Roger
    Good idea NT, I will try that today, I think I have a steel ruler I might be able to modify into a slim jim of some kind. I have the nylon wedge. I wonder if there is a small camera I can connect to my phone??? I'm gonna look around. Thanks Nueve Tundra.
  30. Oct 21, 2021 at 9:09 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
