*ACHIEVED YES!!* I am trying to get 23 mpg to no avail
Discussion in '2nd Gen Tundras (2007-2013)' started by EmergencyMaximum, May 28, 2022.
  1. Jun 16, 2025 at 4:01 PM
    #151
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    The demand side (energy requirement) will tend to favor a steady speed I think (assuming average speed is a constant), so long as you don't need to use the brakes at all. The wild card is how efficient the engine is at different loads.
    It definitely feels more efficient to let speed drop on the uphill, but I doubt it really is.
  2. Jun 16, 2025 at 4:22 PM
    #152
    EmergencyMaximum
    EmergencyMaximum [OP] Synthetic member
    Flat terrain yes, steady speed is king, but when grade increases, I think you lose more energy trying to maintain that steady speed vs accelerating a little beforehand and start bleeding your speed as you begin the climb. Mine feels like she starts to labor when speed drops below 55 going uphill. (<--This is when i butcher the ascend). Around 52 is when she feels really tired and torque converter lets go.
    When doing freeway speed on rolling hills, I find it easiest for the truck to vary speed between 50 and 60. Downhill, I'd let her steady 55 or if it's steeper, she accelerates to 60 and when I'm in the valley, I input a little bit more pedal and let her slowly bleed speed all the way down to like 52. If I can time it properly, she is like a rollercoaster and transmission holds gear without straining the motor at all!
    I've been just contemplating about this scenario if I'm getting enough efficiency by cutting gas going downhill or like Mr.Punishment mentioned earlier, to keep steady pedal. 4.6L is so strong that keeping pedal while descending, she would easily gain 65 or maybe even 70 and thats where mpgs might fall off? I can tell above 60, she's pushing air harder than necessary.
    Ah, life problems....
    Cpl_Punishment likes this.
  3. Jun 16, 2025 at 6:51 PM
    #153
    82nd Airborne
    82nd Airborne New Member
    2012 SR5 DC
    I find it easier to just drive and enjoy the scenery
  4. Jun 17, 2025 at 5:58 AM
    #154
    rruff
    rruff New Member
    I get that it "feels" more efficient to bleed some speed going up rolling hills, because the truck labors less. But that could be deceiving.
    Looking at it solely from the energy-demand side, for rolling resistance and hill climbing it makes no difference how fast you go; energy is the same over the same distance. For aero drag though, energy increases with speed, so the slower you go the better. Varying the speed at all vs steady, will increase the total energy requirement. Meaning... if an average speed of 65 mph from point A to B is your parameter, then varying between say 55 and 75 is going to require more total energy than maintaining 65... even with hills.
    So the moral of that story is... just put it in cruise control. It's easy and probably close to optimal.
    But there are a few caveats. If coasting downhill in 6th exceeds your speed setting then the truck will downshift and engine brake. That will obviously not be ideal for mpg... but if you exceed the speed limit on the downhill, you'll need to brake anyway. Also, there are variabilities in the supply side... like, I don't know what the engine's efficiency curve looks like. Does it take more or less than 2x the fuel at 100hp vs 50hp? How about 200hp? etc. I can think of reasons why it might be more efficient at higher power, because there is less throttling. But there are other things like the need to shift going uphill that will surely bleed some energy.
    If you have a representative stretch of road around with little traffic, you might be able to test this. It will take some hours though, and you may find that traffic variability is still too much to get reliable data.
  5. Jun 17, 2025 at 6:27 AM
    #155
    EmergencyMaximum
    That's interesting, even if somewhat counterintuitive to my limited understanding. I don’t have cruise control or the mpg gauge on mine, but trying cruise control in my other car, mileage display showd a drop by a very heavy margin if the car is trying to maintain the speed going uphill. She would usually downshift and rpm rise another 500 or so and mpg is tanking.
    Cpl_Punishment and rruff like this.
  6. Jun 17, 2025 at 6:30 AM
    #156
    JRS
    JRS New Member
    2012 DCLB
    Use an OBD app to monitor engine load and injector duty. Use whichever tactic to keep those values low.
    EmergencyMaximum[OP] likes this.
  7. Jun 17, 2025 at 8:20 AM
    #157
    rruff
    rruff New Member
    Of course. But you'll have to make up for it elsewhere if you let speed drop on the climb, and it will "feel" better only because you've avoided the noise and vibration of the high powered segment.
    The total energy demand to get from A to B in X minutes is just simple physics. Locking speed at the average takes the least total energy, even with hills. The supply side (the engine and drivetrain) is more complicated, but I think there is a small improvement in efficiency at higher power levels as well, which would also favor maintaining speed up the hills.
  8. Jun 17, 2025 at 10:22 AM
    #158
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    KNABORES and kirkb like this.
  9. Jun 17, 2025 at 5:24 PM
    #159
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    It has to be more efficient to recoup your speed on the downhill than to downshift to maintain it on the uphill then brake to maintain it on the downhill.
  10. Jun 17, 2025 at 5:45 PM
    #160
    rruff
    rruff New Member
    I already said that.
  11. Jun 20, 2025 at 11:33 AM
    #161
    NewUsedTruck
    NewUsedTruck Still a New Member
    AK
    2011 CM 5.7l TRD
    PO crashed it
    I used to do hypermiling. After saving like 2 miles worth of gas per tank for all the trouble, decided I might as well have fun driving "safely". On the other hand, if Vin Diesel rear-ends you, he's almost always at fault. Just maintain good insurance ig
  12. Jun 20, 2025 at 3:17 PM
    #162
    EmergencyMaximum
    Gang, saving 2 miles to a tank isnt hypermiling. That's margin of error. Now, let's crank some numbers:
    I usually fill up when there's about 18gallons used on my tank. (It leaves about 1/4 of tank remaining.)
    #1. 17mpg.
    This is my personal "feel good idiot" driving. 17mpg X 18gal = can travel 306mi.
    #2. 20mpg.
    This is my typical calculated economy. 20mpg X 18gal = can travel 360mi.
    Savings of 54miles per tank. That's over 2.5gals worth of fuel saved every fill-up.
    #3. Hypothetically I hit 22mpg this time.
    22mpg X 18gal = can travel 396mi.
    396mi - 306mi = 90miles worth of extra miles. This is hypermiling vs idiota driving.
    TK1979 likes this.
  13. Jun 20, 2025 at 3:20 PM
    #163
    NewUsedTruck
    AK
    2011 CM 5.7l TRD
    PO crashed it
    Lol... it was hyperbole bro
    And I never saw *that* kinda mileage change! Good on ya!
  14. Jun 20, 2025 at 4:11 PM
    #164
    EmergencyMaximum
    Sorry gang, didn't realize you were kidding. I take mpg's very seriously.
  15. Jun 22, 2025 at 10:43 PM
    #165
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    i don't have the bandwidth to take mpgs seriously
    NewUsedTruck and rruff like this.
  16. Jun 30, 2025 at 3:53 PM
    #166
    EmergencyMaximum
    After my adventurous dwellings among eternal 3rd gen failure discussions came to end, I decided to powerdive back into mpg's.
    Today's fillip:
    487 miles / 22.11gal
    Result:
    MPG's.
    This one is interesting. First part of the naked was highway driving and backcountry with traffic lights. Second part of the tank took me across vast rolling hills and valleys with some very disappointing city driving mixed in. I think I helped raise world temperature by 0.02degrees with my brake pads due to sudden red lights. Might be a record this time. Every second light turned red for me with no roll. It was heart breaking.
    But nevertheless...end result was surprisingly positive. This was without AC, so it might not very for everyone.
    TK1979 and rruff like this.
  17. Jul 1, 2025 at 8:24 PM
    #167
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    I read in a Reader's Digest magazine (which was an older issue, dated 1960's or early 1970's IIRC) that it was more fuel efficient to "maintain RPM's and not speed on hills." *It may have been dated just after the first "Energy Crisis" when readers had a reason to figure out how to get more out of a tank.
  18. Jul 1, 2025 at 8:31 PM
    #168
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    I hypermile. Money is tight, we do what we can to stretch the money.
  19. Jul 2, 2025 at 5:14 AM
    #169
    EmergencyMaximum
    When torque converter is locked up, maintaining rpm will maintain speed.
    TK1979 likes this.
  20. Jul 2, 2025 at 5:26 AM
    #170
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    Yes, thank you for changing your focus.
    And who's fillip? ;)
    Congrats on 23.
    Or, 22 point whatever.
  21. Jul 2, 2025 at 5:28 AM
    #171
    EmergencyMaximum
    Fillup typo phone corrector feature
    Thank you
  22. Jul 2, 2025 at 7:50 AM
    #172
    rruff
    rruff New Member
    It's important to note that you can always save gas by going slower, easy up hills, coasting, etc within reason. It's a very different question if you need to go from A to B in X amount of time.
  23. Jul 2, 2025 at 12:09 PM
    #173
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Leave earlier? I've heard it's a possibility but I don't know very many to actually do it.
  24. Jul 2, 2025 at 12:20 PM
    #174
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    ABSOLUTELY NOT
    - my dad
  25. Jul 2, 2025 at 3:26 PM
    #175
    rruff
    rruff New Member
    Some don't bother to take the trip at all.... :D:thumbsup: Mucho $$$ savings...
