Accuracy of the computer's displayed MPG
Discussion in '2.5 Gen Tundras (2014-2021)' started by awhendricks, Aug 2, 2017.
  1. Aug 2, 2017 at 8:00 PM
    Fiestee23
    Fiestee23 A CHICK'S TRUCK
    SOCAL
    White sr5 4wd
    Um... no. Should I be?
  2. Aug 2, 2017 at 8:02 PM
    Mannishboy
    Mannishboy New Member
    Indianapolis, IN
    2015 DC 4x4 Limited, Blue Ribbon Metallic.
    TRD exhaust, TRD cai, TRD rear sway bar, TRD shift knob, Sequoia front sway bar, bed extender, bed step, Weathertech floor mats and window vents, spray in bed liner, Morimoto fogs, Access tonneau bed cover.
    Well, if not, your reading is displaying your average mpg since the day you bought it.
  3. Aug 2, 2017 at 8:03 PM
    Tundra_mike89
    Tundra_mike89 New Member
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Toytec boss coilovers Toytec shackles Total chaos uca's Method wheels Nitto ridge grapplers
    How do you reset it?
  4. Aug 2, 2017 at 8:06 PM
    Mannishboy
    Indianapolis, IN
    When in mpg mode on your dash, press and hold the select button on the steering wheel. I do it after every fill up. I also use the Fuelly app on my phone as well. Great app.
    Fiestee23 likes this.
  5. Aug 2, 2017 at 8:07 PM
    Fiestee23
    SOCAL
    White sr5 4wd
    Awesome. That will probably make me feel a little better. Lol :p
  6. Aug 2, 2017 at 8:07 PM
    Mannishboy
    Indianapolis, IN
    ... I'm assuming its a 3rd gen. Don't know about the others.
  7. Aug 2, 2017 at 8:08 PM
    Fiestee23
    SOCAL
    White sr5 4wd
    Yes it is...fuelly has been loaded as well
  8. Aug 2, 2017 at 8:09 PM
    Mannishboy
    Indianapolis, IN
    Lol, i did the same thing.
    Fiestee23[QUOTED] likes this.
  9. Aug 2, 2017 at 8:15 PM
    Mannishboy
    Indianapolis, IN
    After i fill up and reset, i usually get on the interstate right after. My mpg will read something like 20 mpg on the way home. It usually takes a day to settle down to a more accurate reading.
  10. Aug 2, 2017 at 8:25 PM
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    LEAD FOOT!!! :burnrubber:
  11. Aug 2, 2017 at 8:53 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I fill up every stop and clear my trip and MPG, hand calculation has been about 2 mpg less than the display. The only time it was basically spot on was when I was below a quarter tank. I typically fill up around a half tank.
  12. Aug 3, 2017 at 4:39 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    my display shows about 0.5 mpg more than I actually get. the display is just an estimation. I always calculate it by hand at each fill up so I know what I am really getting.
  13. Aug 3, 2017 at 12:45 PM
    Jagamov
    Jagamov New Member
    Greg
    2017 White Tundra Platinum
    I have calculated mine by hand 3 times and it has always been pretty much what the computer says within .2 or .3 mpg. That's good enough for me.
    Averaged 18.1 last tank and it was right on when I filled it up and did the math.
  14. Aug 3, 2017 at 4:21 PM
    jstrenn
    jstrenn New Member
    2017 Toyota Tundra Double Cab 4X4 TRD Off Road
    That little arrow by the pump is to indicate what side of the vehicle the fuel tank filler door is located. So in the Tundra it is on the left (driver side) of the vehicle. I think all vehicles have that symbol.
  15. Aug 3, 2017 at 4:27 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    Thank you.. Good thing I did not run the needle down there
  16. Aug 6, 2017 at 6:43 PM
    Abrams65
    Abrams65 New Member
    Cliff
    WV
    16 Tundra MGM SR5 CM OR/15 Corolla S
    ICI Magnum RT Steps, 18' LED Foglights
    Computer has only been close to being correct twice. Other than that always at least 1-2 too high
  17. Aug 7, 2017 at 10:55 AM
    Gearman
    Gearman New Member
    2017 tundra Limited TRD
    I have 2017 crew max limited with just over 1100 miles
    9.5 MPG Got me wondering?!?!
    91443753af8cc08119381940a148b2c6_cd7f19176690ca39d655f614c07ae12579a2772d.jpgPro
    ColoradoTJ likes this.
  18. Aug 13, 2017 at 7:18 PM
    awhendricks
    awhendricks [OP] New Member
    Austin
    2017 Tundra Limited 4x4
    Well I had one fill up where the computer was -.3 with manual calculations, and the next one was off +.7. The computer showed 18.4 and manual calc showed 17.7. I attribute this to two total different pumps and stations.
  19. Aug 14, 2017 at 4:24 AM
    #49
    chphilo
    chphilo Tundra addict
    Western PA
    Personally, I found that the computer reading and 'hand-calculated' value to be very close to each other.
    I think hand-calculated values are reliable only for a larger number of consecutive fillups. For the life of me, I cannot get the gas pump to shut off at the same level (I experimented with various gas cans). I also find that different gas pump seem to have somewhat different flow rate. Larger the flow rate, sooner the shut off occurs, I found.
  20. Aug 16, 2017 at 3:55 AM
    #50
    Berettafan
    Berettafan New Member
    2017 CM
    do you guys with bigger tires understand not only your speedo but your odo and mileage on truck display are wrong unless you've done something to correct them?
  21. Aug 16, 2017 at 4:34 AM
    #51
    Netmonkey
    Georgetown, TX
    not for me. the 295/55/20's made the speedometer and odometer readings spot on (verified by GPS). the 275/55/20's actually gave an incorrect reading. if I went any larger, then I would have to correct the speedometer.
  22. Aug 16, 2017 at 5:09 AM
    #52
    I would be a little concerned as well.
    87 octane?
    Air pressure in tires 38-42 psi?
    None of that flex fuel right?
    My 12' was pretty darn good overall.
  23. Aug 18, 2017 at 10:58 AM
    #53
    Gearman
    Gearman New Member
    Mid grade fuel (88 octane)
    Tire psi good.
    Tires were swapped out four some BFG AT ko. Stock size
    Have heard that these tundras are not so fuel efficient...... I didn't purchase for economy. But did expect better, since ideally only drive on weekends, it will be awhile before we go through a fewtanks to see where she settles in at. Hoping for 14-15
    Ely010606 and ColoradoTJ[QUOTED] like this.
  24. Aug 18, 2017 at 12:44 PM
    #54
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I think that is a very realistic goal. I get 15-15.6 with 87 pretty much all the time no matter what kind of driving I'm doing. We will see if that improves in the fall when I don't have to run the A/C all the time.
  25. Aug 18, 2017 at 5:00 PM
    #55
    Berettafan
    2017 CM
    Those bfgs are considerably heavier than stock. Makes a difference.
  26. Aug 18, 2017 at 5:48 PM
    #56
    big_jarv
    big_jarv New Member
    2021 TRD Pro
    Thanks for sharing I didn't know that!
  27. Aug 18, 2017 at 5:53 PM
    #57
    I'm averaging long term on dash at 10.8. Pretty much accurate. Keep in mind...short term dash computer stats don't mean squat. Always hand calc to be real for trips.
  28. Aug 29, 2017 at 4:42 AM
    #58
    Gearman
    Gearman New Member
    Yes they are 15lbs more per tire.
    In our experience on 6 different vehicles, the BFG ATs affect approximately 1 mpg
  29. Aug 30, 2017 at 5:05 PM
    #59
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Mine is tracking MPG for someone elses car. And when I say car I mean some 4 cylinder that gets really good gas mileage. I calculate every tank by hand and I average around 12.7mpg. My computer tells me I am manufacturing fuel and that I am getting around 19.4mpg. Not even close.
    big_jarv likes this.
  30. Sep 4, 2017 at 6:12 PM
    #60
    Highimpact
    Highimpact New Member
    2017 CM Limited TRD
    1700 miles and I was excited to see mine finally creep up to 13.4 from 12.5. The mileage on Tundras suck LOL
