Acceleration Trouble
Discussion in '2nd Gen Tundras (2007-2013)' started by BigRed2020, Oct 10, 2021.
  1. Oct 10, 2021 at 2:12 AM
    BigRed2020
    BigRed2020 [OP] New Member
    MA
    2007 5.7 TRD Limited 2WD
    Flow Master Super 40 Exhaust 3in RC Front Leveling kit
    What’s up y’all,
    My 07’ has recently been giving me issues while I’m driving. Every now and then I’ll be out and the accelerator basically stops working, I can slam it to the floor and nothing, then it’ll just up and start again.
    No check engine lights or anything are on. Truck drives great! no issues shifting or anything at 149k, but I’m hoping this is something minor...
    Any help?!
  2. Oct 10, 2021 at 4:45 AM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    Start by scanning the computer for any pending or history codes. Clean the throttle body and relearn base idle.
    BigRed2020[OP] and Bear like this.
  3. Oct 10, 2021 at 4:49 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    Look for mice, squirrels, chippies, etc under the hood, under the engine cover, air boxes (cabin air filter too!) and under the whole dash up by the pedals especially.
  4. Oct 10, 2021 at 4:51 AM
    BigRed2020
    MA
    I’ll definitely look into the computer today, thanks!
    That’ll be an interesting find if there are
  5. Oct 10, 2021 at 5:01 AM
    2mchfun
    Rodent damage, throttle position sensor maybe.
    BigRed2020[OP] likes this.
  6. Oct 10, 2021 at 5:08 AM
    blanchard7684
    blanchard7684 New Member
    Throttle position sensor
  7. Oct 10, 2021 at 8:29 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    This could be a bunch of different things. You'd need to look at some live data to see why the truck is hesitating. At 149K you'd probably want to change the spark plugs if you haven't, and don't be too surprised if you find that you have a dead coil or two (which may appear in the misfire counts before it sets a CEL).
  8. Oct 10, 2021 at 8:49 AM
    Dr_Al
    Dr_Al New Member
    Al
    I would look at the pedal assembly. The computer should throw a code if it commands the throttle to move and it doesn't. An occasional misfire may not draw a code but if the problem is enough for you to notice it then it should. But how would the computer know the difference between the pedal sending the wrong information or you just not pushing on the pedal?
    Also the brake pedal could be an issue. The software set so that if it thinks you are pushing on the gas pedal and the brake pedal at the same time it will set the throttle to the idle position to avoid a run away condition.
  9. Oct 10, 2021 at 10:07 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    1.) now when the "pedal" stops working are there any traction control lights on or beeping?
    2.) does this only happen from leaving from a stop or a sharp turn and hard acceleration?
    I would just do these easy things first if no to those questions above
    1.) check plug at back of pedal that its seated
    2.) while stopped push and hold "Squiggly vehicle" traction control button until you see on the left side VSC off lit up (this turns off all nanies and will make the Tundra raw , if problem goes away then most likely its a traction control issue if not caused by question 1 or 2)
    if problem persists
    3.) make sure battery terminals are clean/tight
    4.) check grounds are clean an not corroded
    5.) check that battery is getting charge from alternator should be 13.2 volts low - 14.8 volts high
    6.) check air filter (clean)
    7.) clean MAF with MAF cleaner
    8.) clean throttle body with throttle body cleaner
    if problem persist after an still no CEL
    check
    9.) throttle body wires are intact and clean
    10.) check Throttle body position sensors for correct values
    11.) check Peddle position sensors for correct values
    if all were good
    12.) collect live data with scan tool.
  10. Oct 11, 2021 at 8:21 PM
    BigRed2020
    MA
    Thanks everyone! Looking into it this week
