ACC Power location?
Discussion in 'General Tundra Discussion' started by supermotobobby, May 29, 2017.
  1. May 29, 2017 at 8:15 AM
    supermotobobby
    supermotobobby [OP] New Member
    Bobby
    2022 Tundra Platinum 4x4
    Where can I tap into an ACC power on my 2010 Tundra CM?
    Rica25 likes this.
  2. May 29, 2017 at 8:40 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    In the ignition switch harness, black or light green are ignition powered. Grey in the same harness is accessory/heater/blower. Should be able to access it pretty easily if you remove the dash cover and knee bolster under the steering column. If you do the green, make sure it's the light green. The darker green in that harness is your starter wire.
    Rica25 likes this.
  3. May 29, 2017 at 8:54 AM
    supermotobobby
    Bobby
    Awesome, thank you!
    Rica25 likes this.
  4. May 29, 2017 at 10:26 AM
    dumbassdave
    dumbassdave Member
    Dave
    2016 Crewmax Limited
    Pudge, Backslider and NewImprovedRon like this.
  5. May 29, 2017 at 6:16 PM
    zidaro
    zidaro New Member
    E. Sierras, CA
    '10 Crewmax
    yes
    add-a-fuse tapped into the cig. lighter fuse at the dash kick panel is a great place to tap ignition hot power for switches.or a relay.
    Rica25 likes this.
  6. Nov 10, 2017 at 8:29 AM
    crishard
    crishard Occasional Member
    Cris
    2014 Barcelona Red CM
    3" level in front, ICI Bumper & Skid, 12k lb winch, UCAs, Radtech 2.5s, Kenda 35s, Dual Batteries, 3500w inverter
    Is the darker green wire the starter wire for gen 3 also?
    Rica25 likes this.
  7. May 24, 2020 at 4:22 PM
    spudfriend
    spudfriend New Member
    Dave
    2007 5.7 CM
    New headlights, interior LED swap and bed cover.
    So I'm new here. I've had a backup camera system I've wanted to install in my stock 07 for a few months now. Just haven't had time to get to it. I've got the video cable running from the rearview mirror display into the headliner, down the right column, through the firewall and along the length of the truck to the camera in the tailgate. That didn't take me that long to do when I just spent some time getting it done. What I can't figure out though is how to grab 12v ACC power on the passenger side somewhere. From reading the thread here it looks like the Add-in fuse circuit is the easiest and fastest way to do this. If I use an add-in fuse, do I still need to extend a bit of wire from the passenger kickplate through the firewall to the fuses in the engine? Also does it matter what fuse location I use? I assume I'll need to use something that carries 12v ACC, but I'm not sure how to go about doing so. I already know from reading other posts that I can tap into the blue signal wire (pictured) and the ground is easy, but I'm lost on how to patch in for 12v ACC. I just want the camera on when I throw the truck in reverse. Several other posts helped me figure out how to get the AV cable through the firewall. Thanks for any help. I bought the rear view safety rvs-718BT kit here. Here are a few pics of the setup.:[​IMG] [​IMG] [​IMG] [​IMG]. So far I've not had any issue backing, but I'm always looking to make it easier to hook up our trailer. Thanks,
