AC Rear Window Drain
Discussion in '1st Gen Tundras (2000-2006)' started by tvpierce, Apr 17, 2022.
  1. Apr 17, 2022 at 2:20 PM
    tvpierce
    tvpierce [OP] Formerly New Member
    Maine
    Hi all. I have a leak -- most likely from my rear window. I've looked at the sticky with PHM's instructions on cleaning the drains on the rear sliding window on an AC. But when I look at my rear window, I don't see how it comes apart to get at the gaskets and drains.
    Any help is appreciated.
  2. Apr 17, 2022 at 5:24 PM
    shifty` We call it “riding the gravy train”
    And you're 100% sure it's not your 3rd brake light? Just asking.
    Anyway, there's a couple of drains up top. One on either side of the back window, where the roof rack cover slides under the window frame - you need to gently pull up the rubber roof rack cover to get access to the drain channel for cleaning.
    EDIT: Read this for more info on how to clean the channel and its water routing.
    tvpierce[OP] likes this.
  3. Apr 18, 2022 at 3:45 AM
    tvpierce
    Maine
    No, I'm not 100% sure it's not the 3rd brake light. I'll check that too while I'm back there.:thumbsup:
  4. Sep 7, 2022 at 6:07 AM
    Just bumping this because I needed to edit my post above to link to newer instructions for clearning the upper drains.
    @tvpierce did you ever figure out PHM's post about cleaning the lower sliding window drains? I gotta admit, I've looked at my slider 3-4 times now trying to figure out what drains he's cleaning in the sliding channel and I can't find it either.
    Granted, there's a lot of dirt and shit in my channel, so it may be clogged already, I'm just not seeing any physical hole anywhere along the base of the window on the inner-cab side.
  5. Sep 7, 2022 at 9:39 AM
    tvpierce
    Maine
    I haven’t looked into it yet.
    shifty` likes this.
  6. Sep 7, 2022 at 7:33 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I cleaned mine. They were pretty obvious. Can't find a pic of when I did it off-hand but I thought I took one. There's just a couple holes in the bottom of the track that the window slides in.
  7. Sep 7, 2022 at 8:03 PM
    Yeah, I'm coming up short on that one. How bizarre. I wonder if the later years just don't have them like the earlier years?
  8. Sep 27, 2022 at 1:25 PM
    04TundraOffRoad
    04TundraOffRoad New Member
    '04 AC SR5 4WD
    DIY retrofit headlights, Driver's and passenger's seats from Subaru WRX, 3rd gen Tacoma side steps, 33" tires, Rancho RS5000 suspension, Softopper Plan to fabricate mounts to add a 2nd gen Tacoma off-road bumper
    I am chasing down a leak in my rear window (and your post from June has been a HUGE help!). I had just seen that my truck has the drainage holes on the inside of the slider track, and I'll take a picture for you later today :)
  9. Sep 27, 2022 at 1:45 PM
    I'd love to see 'em. I can't figure out where the hell they are still.
  10. Sep 27, 2022 at 8:49 PM
    04TundraOffRoad
    '04 AC SR5 4WD
    Here's a picture of them! When I blasted air through the line, I was able to feel it come out the drainage hole at the corner of the window seal on the exterior of the cab. It seems I'm hoping that clearing those drains (assuming they were blocked) will fix my leak - it looked like it was coming from the slide track.
  11. Sep 28, 2022 at 5:05 AM
    Maybe my issue is not popping out a seal or something, or popping out the wrong side? How'd you manage to get that seal up? Mine looks like totally different window....
    Here's a pic of mine, in full sun, so it looks super crusty:
    (Driver side of center glass)
    (Driver side pane)
  12. Sep 28, 2022 at 4:19 PM
    04TundraOffRoad
    '04 AC SR5 4WD
    My picture is of the track on the passenger's side pane (and I have the seats taken out). They are also on the driver's side, but none in front of the middle pane. You're correct, I did pull the sliding track seal up to find these holes.
    I found these based on your post outlining all the possible leaks! Here's the post you had linked in there that shows the sliding track removed and talks about cleaning out the drain underneath: https://www.tundras.com/threads/the...ld’-a-chronological-story.46816/#post-1210451
    It looks like the seal may of had adhesive holding it in before, but mine was basically deteriorated, so it was easy to pull mine up.
  13. Sep 28, 2022 at 4:36 PM
    Yeah, mine just wasn't peeling up and I didn't want to damage anything.
    PHM's post is what I was working off of. I don't even see in the rubber track/seal where there's a hole in the drain on mine. It's super weird.
