AC Rear Seat Delete
Discussion in '1st Gen Tundras (2000-2006)' started by MNtundra, Jun 10, 2021.
  1. Jun 10, 2021 at 8:32 PM
    MNtundra
    MNtundra [OP] New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    I am doing it! bye bye useless cramped seats, hello additional cargo space!
    I remember someone mentioning somewhere that those two rear vents with flaps served a distinct purpose for equilibrium of your climate? Well they are useless and will not seal if the flap is bent! mine is. so they are getting deleted and capped/sealed off. Plus due to the way they truck lined my bed, I cannot remove the bed bolts... so mr. dremel is gonna cut them into pcs... Is this a really bad idea?
    01erionracing likes this.
  2. Jun 10, 2021 at 8:35 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Those vents are pressure vents. They vent excess cab pressure when you shut the doors.
    You ever tried to close a house door with all the windows shut, and storm door in front of it? With the windows open you can easily shut the door. Windows closed, and it takes more force to close the door. If that makes any sense
    DarkMint, 1lowlife and MNtundra[OP] like this.
  3. Jun 11, 2021 at 12:14 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I agree, don't block or rid the truck of those vents..
    Changes in air pressure, cold fronts or accident impacts, I'd think those vents would be needed...
    Good luck on your seat delete...
    DarkMint and Tundra2[QUOTED] like this.
  4. Jun 11, 2021 at 12:16 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I didn't even consider the moment of impact pressures... excellent point @1lowlife!
    1lowlife[QUOTED] likes this.
  5. Jun 11, 2021 at 12:39 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I think others have stuffed those with some sort of foam rubber, or foam to help with excess cab noise if they did a rear seat delete. Was it @theblurry1??
  6. Jun 11, 2021 at 5:12 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    My work van doesn't have those. You basically have to slam the last door to get it to close or the pressure will only let it half close.
    I imagine it'd be the same with those vents blocked.
    Darkness and Tundra2[QUOTED] like this.
  7. Jun 11, 2021 at 5:18 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Drill you some pressure holes in the roof! It doesn't rain where you live, even if it did just caulk it!
    bmf4069[QUOTED] likes this.
  8. Jun 11, 2021 at 6:01 AM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Fixed it for you. And you forgot to mention it becomes built-in eco-friendly AC/air-circ.
    bmf4069 and Tundra2[QUOTED] like this.
  9. Jun 11, 2021 at 6:03 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Gotta drill holes in the back glass also to allow proper air flow. Otherwise you've made a big ass cup.
    bmf4069 likes this.
  10. Jun 11, 2021 at 6:04 AM
    DarkMint
    Ben
    How could I forget?? My mind is slipping here. Thanks.
    Careful not to crack the glass while you're drilling. Take it slow, and by hand only.
  11. Jun 11, 2021 at 6:05 AM
    DarkMint
    Ben
    On a more serious note, mayhaps you can remove that weird little nipple thing between the two air vents to help with air pressures? Or take that dremel and chop out a larger section in that center area if the little hole ain't big enough.
    Tundra2 likes this.
  12. Jun 11, 2021 at 6:11 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Weird nipple thing is a seat hook if memory serves. It's just a single bolt hole. It's been over a year since I had the rear seat out so memory fuzzy.
    Current Air flow isn't the problem here. OP is taking about blocking those off which would create a lack of air flow.
    DarkMint[QUOTED] likes this.
  13. Jun 11, 2021 at 6:13 AM
    DarkMint
    Ben
    Ahhh right right.
    Tundra2[QUOTED] likes this.
  14. Jun 11, 2021 at 8:20 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    It is, I learned that the hard way after stuffing towels in there to block noise. I later revised it by using a large pore sponge instead (the kind people use for fish tanks). It muffled sound and didn't block the effect. The trick was to not stuff it so far in that it prevents the flap from moving, just enough to cover the opening at the top.
    Tundra2 and bmf4069[QUOTED] like this.
  15. Jun 11, 2021 at 8:24 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Now im wondering, and maybe this is crazy, if you could mount a check valve somewhere and eliminate these. I think a one way letting air out might work, I can't imagine enough vacuum being created in the cab to prevent doors from opening or anything. You need the air to get out to use your AC on fresh air mode, so air out is the more critical.
    Might need to be a good sized valve though.
  16. Jun 11, 2021 at 12:54 PM
    MNtundra
    Tony
    Minnesnowta
    I am going to keep the rear windows cracked until I can find a one way valve. Here are some more progress pics and things I learned. I had a flap that had contorted over the years so it never sealed fully. Well did you know the flaps are replaceable? yup!
    Rear Vents - GONE
    Seat Belts - GONE
    Carpet - GONE
  17. Jun 12, 2021 at 3:05 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Looking forward to seeing the end result. This is something I keep going back and forth on..
  18. Jun 12, 2021 at 11:07 AM
    Richid
    Richid New Member
    I drove around for a few days when I removed the seat. You can tell how much these are needed when you roll up the windows!
    I think you'll need to find something that provides the same effect of equalizing the pressure - maybe add a cabin filter too?
    I cut and formed a piece of ABS plastic - notched holes for the vents, covered in foam and finished with some cheap fabric. Dog protector hangs from the front seats and cut a rubber mat to cover the carpet. Perfect for the doggos.
    Some have suggested removing the metal boxes on the floor, but I keep the jack and tools in there and it doesn't add much space since the driveshaft/fuel tank reliefs are so large.
    Good luck!
  19. Jun 12, 2021 at 5:06 PM
    MNtundra
    Tony
    Minnesnowta
    I AGREE!
