AC issue diagnosis. Blinking light.
Discussion in '2nd Gen Tundras (2007-2013)' started by JoeyD87, Jul 2, 2019.
  1. Jul 2, 2019 at 12:22 PM
    JoeyD87
    JoeyD87 [OP] New Member
    07 Tundra 5.7 4x4 Crewmax XSP
    Yesterday my AC went out as I was driving. I looked down and the LED light on the AC switch was blinking. I turned it off and checked it out today when the motor was cooled off. I could turn the compressor by hand, it was smooth and had slight resistance that keeps it from free spinning. I observed the clutch engaging with the truck running and switch being turned on. It turned slow, much slower than the pulley. The light would start blinking after a few seconds. When I grab the front of the unit, the black part has a slight bit of movement or play (about 1-2 mm), not sure if this is normal. I checked the plug connectors on the compressor and the ground wire on top seems to be solid. What would you suggest I check out next? I thought about swapping the mag clutch relay but didn’t want to start spending money before I explored all my options. Thanks in advance.
  2. Jul 2, 2019 at 12:23 PM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Yes sur, I had the same thing. It was the relay for mine. It would blow cold for about 30 sec then hot and start blinking.
  3. Jul 2, 2019 at 12:31 PM
    JoeyD87
    Thanks!! Is your Truck close by? I’m curious how much resistance is normal on the compressor. It never fully engages enough to ever get cold, only 2-3 seconds. Bad relays typically allow it to work for longer like yours before they kick out.
  4. Jul 2, 2019 at 2:22 PM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    I had something similar in a 4runner - totally freaked out - almost bought a new vehicle since my mom was visiting and she hates being too hot. Googled it, someone said to change the AC relay... 5 minutes and $10 later, I had AC back.
    The clutch could be disengaging for a crap ton of reasons... I'd change the relay since that's the easiest and cheapest thing to try. After that you're going to need a set of gauges to start digging around for the problem
    Trooper2 likes this.
  5. Mar 11, 2020 at 2:34 PM
    Michaelb1100
    Michaelb1100 New Member
    2018 SR5 TSS 4x4 CrewMax
    MACH Force-Xp 2-1/2" to 3" 409 Stainless Steel Cat-Back Exhaust System, AFE Magnum FORCE Stage-2 Si Cold Air Intake System w/Pro 5R Filter Media
    I have had this same problem, I am now on my 3rd switch, 2 from Autozone, 1 from O'riely's and they are only lasting about 3 - 4 weeks. Anyone having the same issue with it happening more than once?
  6. Mar 11, 2020 at 8:14 PM
    TechWrench
    TechWrench New Member
    Gary
    Hawley, PA
    '08 Tundra White, DC SR5 5.7, TRD Off Road Pkg
    Toyota Bedliner, Under Cover Bed cover, Oem back-up camera system.
    Do you mean switch, or the Mag clutch relay?
  7. Mar 12, 2020 at 3:06 AM
    Michaelb1100
    I am guessing its the relay, haven't replaced the switch yet.Guess I can try that next.
  8. Mar 12, 2020 at 7:51 AM
    TechWrench
    Gary
    Hawley, PA
    OK, just to be sure I understand you correctly, you have replaced the Mag Clutch relay in the fuse box under the hood three times in the last three months?
  9. Mar 12, 2020 at 8:16 AM
    Michaelb1100
    Yep, I have. I just talked to my buddy and he is gonna look at it tomorrow, he is a mechanic.
  10. Mar 25, 2021 at 7:47 AM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Did you ever figure this out? The mag clutch relay is a special one... don’t think can be purchase from autozone.
  11. Nov 11, 2021 at 4:34 PM
    Howdywood
    Howdywood New Member
    2019 Gandalf the Grey Tundra TSS
    So where is this relay little easily replaced?
  12. Apr 15, 2022 at 4:36 PM
    SilverCrew
    SilverCrew New Member
    Kurt
    2007 Silver Crewmax
    All of the symptoms and not the relay (unfortunately)…. AC kicks on for seconds and light flashes and so on like above posts. So, I didn’t do any investigation based on all of the previous posts describing my issue to the T. New relay shows up and I smile briefly…. Straight to the engine bay I go against my wife’s wishes. Disappointment! My neighbor (also a Tundra owner) shows up. I asked him to press the AC button while I was up front and noticed very tiny sparks at the pulley as it briefly engaged. Assuming the compressor is seized. Anyone else experienced this? Any option other than replace?
  13. Apr 16, 2022 at 7:29 AM
    63spyder
    63spyder New Member
    Wayne
    2008 tundra
    None
    My 2008 with 400000 miles was doing the same thing, I replaced the relay, no change. Took it to toyota and had them diagnose it ,they told me it was the after market relay, nope. I finally traced it to the ac clutch. It had burned the magnetic coil . Seems you can't buy the ac clutch from Toyota, but you can it on Amazon. Two years later still works great
    SilverCrew likes this.
  14. Aug 20, 2022 at 6:25 PM
    Niner
    Niner New Member
    2008 Tundra
    Mine is doing as described above with blowing cold for a minute and then hot with blinking light. The only difference that no one else mentioned experiencing is a loud high pitched noise accompanying the blinking and hot air. Seized compressor??
  15. Aug 20, 2022 at 6:39 PM
    landphil
    landphil Moose bites Kan be pretti nasti.
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Sounds likely. With the engine shut off, you should be able to rotate the front plate of the compressor clutch (and turn the compressor) by hand, it should move smoothly with a bit of resistance.
    Niner[QUOTED] likes this.
  16. Aug 20, 2022 at 7:02 PM
    Niner
    Niner New Member
    2008 Tundra
    landphil likes this.
