AC Integration Control Panel
Discussion in '1st Gen Tundras (2000-2006)' started by -soysauce-, Jul 29, 2020.
  1. Aug 26, 2020 at 1:08 PM
    Professional Hand Model
    Hand Protectors
  2. Aug 26, 2020 at 1:09 PM
    Hand Protectors
    This. Junkyard time.
  3. Aug 26, 2020 at 5:42 PM
    shifty` We call it “riding the gravy train”
    Or www.car-part.com
    Make sure to search for same year, engine, drive type (2w/4w) and body style as yours. If you can get the VIN from the site for the vehicle you're looking at, you can run it through here to find out the truck's specs, understand whether it's like yours. This way you're not flailing around aimlessly.
    I'd also say, not all Toyo mechs are created equal. I have a dealership south of me with some real idiots, and a world-class terrible service station that's plagued with bad management for years. If you get one from a junkyard via car-part.com and it still doesn't work, there's a concrete chance they just misdiagnosed it from the getgo! At least buying used you're not out beacoup cashola on a brand new part when you have a working old part.
  4. Sep 24, 2020 at 8:42 AM
    -soysauce-
    -soysauce- [OP] New Member
    2001 SR5 2WD
    So I ended up finding a replacement in the part out section of this forum. Still not working.
    Since I was taking my truck in for a suspension rebuild, I told my mechanic to check out the ac problem. Just like Toyota, he says the clutch engages.
    He did find a leak in the condenser, though. He’s says that could be the reason it is blowing warm. Fingers crossed that he’s right.
    I bought the truck for 5k and have about 5k into it so far. Starting to get buyers remorse....
  5. Sep 24, 2020 at 11:26 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    And how much is your truck payment and full coverage insurance every month?
  6. Sep 24, 2020 at 3:57 PM
    Hand Protectors
    The simple math is these trucks age has them coming up on major reinvestments. You are still better off than having a $600+ turd payment for 5 years!
    I’m at around $7k outlay in two and a half years time (a turd down payment) plus no personal prop taxes!:yes:
    bmf4069 likes this.
  7. Sep 25, 2020 at 12:02 PM
    -soysauce-
    2001 SR5 2WD
    Good point.
    Just got a call from the mechanic. They installed a new condenser but are now saying that it’s still blowing warm because the evaporator is clogged. He wants another $550 for that :(
  8. Sep 25, 2020 at 12:07 PM
    Hand Protectors
    Those two usually go together as a one time proper fix. Hopefully no cross contamination has occurred.
  9. Sep 25, 2020 at 12:09 PM
    -soysauce-
    2001 SR5 2WD
    What do you mean by cross contamination?
  10. Sep 25, 2020 at 12:28 PM
    WTF? How did that not show up when they were checking low/hi side pressure? If something was clogged, they should've clearly seen they were getting no or limited pressure on one side of the system. If that didn't fix the problem, how are they charging you for parts and labor?
    Furthermore, how did they NOT notice something was wrong when vacuuming the lines? HVAC is a "closed" (but flowing) system. If something is clogged, that should clearly show up when testing pressure on one side or the other, eh? Next thing you know they're going to say the orifice tube or expansion valve is clogged. Sounds like you're getting worked!
  11. Sep 25, 2020 at 12:31 PM
    -soysauce-
    2001 SR5 2WD
    So far this this trip is at $1825
    That breaks down to
    labor for
    Bilstein 5100 Struts (front and rear)
    Robinson Coil Springs
    KYB Strut Mounts
    Energy Suspension Insulators
    JBA Upper Control Arms
    Moog Lower Control Arms
    SPC Cam Adjusters
    Toyota Genuine Lower Ball Joints
    Parts/Labor
    Clock Spring
    Condenser
    Evaporator
  12. Sep 25, 2020 at 12:48 PM
    -soysauce-
    2001 SR5 2WD
    He said the condenser was leaking and had to fix that leak. Once the leak was fixed they were able to find the evaporator was clogged.
  13. Sep 25, 2020 at 1:34 PM
    Hand Protectors
    You answered your question. Seems many of our AC problems on our trucks start this way. Could be the method the Service Tech uses or the simple matter of debris dislodging during work and causing the secondary issue.
    Either way this sucks. I am not an AC Tech so I am willing to be enlightened.
  14. Sep 30, 2020 at 12:37 PM
    -soysauce-
    2001 SR5 2WD
    Finally got her back. So I guess Toyota was wrong with their Climate Control diagnosis. All that searching for the right part was a waste of time. After replacing condenser and evaporator core she is blowing cold, just in time for winter.
  15. Sep 30, 2020 at 1:28 PM
    Hand Protectors
    After seeing the condition of the hidden backside (between front of coolant radiator) of mine with the radiator off she was solid except down near the bottom. While gently cleaning, the coil fins were falling off at the mounting bracket area.
    My truck is probably not too far behind you in this area.
  16. Aug 29, 2021 at 11:29 AM
    wojdakwilson
    wojdakwilson New Member
    I feel your pain brother. I'm going through a similar problem. I got my 2001 Tundra's AC checked out recently and was told the system works fine and I needed the climate control module. Magnetic clutch not engaging.
    As we know they discontinued the part, however, they could get just the wire integration electrical board for $800. None in wrecking yards in San Diego County and no 2001 modules on ebay. I got a 2003 module and installed it. Same result. Fortunately I was able to return it.
    I found 1800ecm.com in TX who rebuilt the board for $300. Reinstalled module and still no AC. I can see that the clutch is not engaging. Also I checked low line pressure and it registered warning.
    I looked at the electrical schematics and am slowly figuring out how the clutch gets its Mojo. Anyone can help with getting this clutch to work? Thanks.
  17. Aug 29, 2021 at 11:33 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Have you checked the relay, almost all the issues I get at work are the relays just bad. It’ll say MG under the hood fuse box
  18. Aug 29, 2021 at 11:37 AM
    wojdakwilson
    My blower fan works. Someone posted earlier that if that's the case it's not the relay
  19. Aug 29, 2021 at 11:51 AM
    #49
    wojdakwilson
    Blower fan works fine. Was told by another member that the contacts for this relay also turn on the blower, if the blower is working but clutch not pulling in, problem can not be relay. Yes/no
  20. Aug 29, 2021 at 12:16 PM
    #50
    empty_lord
    05 rollover special
    hmm actually closer inspection to the diagram, the A/C clutch relay is part of the interior fuse block. chances of it having failed? no clue. but most other toyotas the magnetic clutch has its own relay.
    its possible its just a bad compressor clutch.
  21. Aug 29, 2021 at 7:19 PM
    #51
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    #51
