AC/Furnace going out
Discussion in 'Home Improvement' started by ScottsTundra, Mar 28, 2020.
  1. Mar 28, 2020 at 7:08 AM
    ScottsTundra
    ScottsTundra [OP] New Member
    2017 SR5 Crewmax
    Headwaters seat covers, Undercover Flex
    So for the past two years, my air conditioner has froze up during the few weeks of high humidity that we have here in northern Arizona during monsoon season. I’ve been trying to ignore it, but I know it’s something I need to replace. Fast forward to a few nights ago, the furnace stops blowing hot air. I had a buddy come out and help me rig up the furnace to pump some hot air for the next few nights, as we are in a bit of a cold spell. I just had my first son a few weeks ago and I want to make sure the house stays comfortable for him. I would rather not try and replace parts here and there to limp it by for a few years.
    So as far as I can tell:
    The unit came with the house; Built in 2007
    It is a 5 ton Goodman
    I believe it would be called a package system? The AC and furnace is all in one unit and is roof mounted.
    The system has two zones. I have a two story house and one zone is for the upstairs and one for the downstairs.
    Does anyone have any insight on the price I should expect to spend on a new system?
  2. Mar 28, 2020 at 7:15 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    5 ton is on the larger end, I'd say for both condensor, evaporator and labor to remove/install units depending on EER efficiency choice, region of USA, $8-14K. Could be a lot less to let a professional give it a good look over. Goodman's in 07 used low quality copper that developed holes and leaks. If condensor, compressor or evap units are toast, it may be better to replace all. Luck.
    BravoDeltaRomeo and FrenchToasty like this.
  3. Mar 28, 2020 at 7:16 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Get 3-4 quotes and you'll have your price.
    It will vary greatly, as posted above.
    15whtrd and JohnLakeman like this.
  4. Mar 28, 2020 at 7:16 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Your going to be looking at 7-9k easy. Also goodman is craaaaap!
    I just bought and installed a 4 ton split system 17 seer dual stage heat, dual stage cooling, I got the unit at cost and did all the work myself(American standard, Tranes little brother) I spent about 5.5k total I think. Any other company is going to bend you over and not be gentle; usually double what the unit costs them; markup and labor.
    Is your unit a heat pump or a gas pack? I’m guessing it’s 410a, which needs the coils really clean to work properly. If you haven’t changed a filter or even ran a filter, or have never had coils cleaned, that could be your issue.
    The unit I pulled from my house was 19 years old and still cranking out the snowflakes and heat, but it sucked energy. My mom has a 21 year old Trane that still rocks out too. Buy a quality unit and maintain it
    BravoDeltaRomeo likes this.
  5. Mar 28, 2020 at 7:23 AM
    00Tyler10
    00Tyler10 WETT Expeditions
    Tyler
    Bowling Green, Ky
    2020 MGM Tundra Plat 4x4
    PTM Mirror Caps Spray in Bed Liner Window Tint XD Buck 20x9 Wheels 275/65/20 BFG K02s Bamf 10" exhaust
    You should stick with Goodman for best $$$ for what you get. Comments from people who say Goodman is crap have not opened these units up next to a carrier, trane, rheem etc... Goodman is owned by Daikin and backed by a 10 year warranty. They have copeland compressors and are fantastic units for the money.
    Replace condenser, furnace/air handler.
    Done That likes this.
  6. Mar 28, 2020 at 7:38 AM
    FrenchToasty
    Mo
    Bone stock
    Can you still buy Goodman’s on Scamazon and have handy Randy install them?
  7. Mar 28, 2020 at 8:27 AM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    American standard or trane. Well trane makes American standard.
  8. Mar 28, 2020 at 8:53 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Do you change the furnace filter often or use the very restrictive high end filters?
    I doubt that’s it but, my whole unit froze up in the summer all due to a dirty and restrictive filter. My HVAC buddy said they are really hard on units and to use the cheap HD or Lowe’s brand and change often.
    Good luck. I hope it’s nothing major.
    15whtrd and Grumpy Uncle like this.
  9. Mar 28, 2020 at 9:00 AM
    Grumpy Uncle
    Pat
    CO
    I was told the same thing by my HVAC guy.
  10. Mar 28, 2020 at 9:03 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Twelve to 15 years is about typical life on the condensor and AC coil in the air handler. Both of mine developed simultaneous refrigerant leaks at 15-16 years.
    New technology with variable speed compressors and variable speed air handlers can now provide incredible efficiency and energy savings both heating and cooling, and the efficiencies continue to improve. Problem is that if the furnace is in good shape, it will probably last twice as long as the AC. I replaced my condenser and coil 20 months ago with the highest efficiency Carrier I could get without going into features that couldn't be used with my existing Carrier furnace. Kept the same thermostat. Four ton Carrier 24ABC648 condenser and compatible coil, 16 SEER, installed and running: $5151.20
    If I'm still in this house in 15 years, maybe I'll replace both AC and furnace as a combination unit.
    YardBird, FrenchToasty and rebmo like this.
