AC Compressor- Fix myself or take it to shop?
Discussion in '1st Gen Tundras (2000-2006)' started by russianbear, Feb 24, 2016.
  1. Feb 24, 2016 at 1:37 PM
    russianbear
    russianbear [OP] New Member
    Barrett
    Jacksonville FL
    2006 Tundra 4x4 Limited Double Cab
    Ive got a 2000 Tundra SR5 with a V8 thats needs the compressor replaced. I have worked on cars a little in the past but not sure if this is something I should try to do myself. Any suggestions?
  2. Feb 24, 2016 at 2:25 PM
    Mike Tread lightly.
    south carolina
    For AC have the system discharged at shop. You can replace the compressor your self but don't forget about the expansion valve. After you have all that take to the shop vacuum test for leaks put freon in and your good to go.
  3. Feb 29, 2016 at 9:40 AM
    garnaz
    garnaz New Member
    Or the drier.
  4. Feb 29, 2016 at 4:00 PM
    Mike Tread lightly.
    south carolina
    Most they will not warranty the compressor unless you buy a new drier with it.. Kind of a given anymore.
